Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Truck and 4Runner
Old 01-25-2007, 01:11 AM   #1
4runner Freak
Short on Time!
4runner Freak's Avatar
Member # 46208
My new not so “home brew” steering arms 56k WARNING
In 2005 I designed this set of steering arms to place the tie rod and drag link above the springs, and to also use the Ackermann angle in them, which worked with placing the tie rod behind the axle.
The arms are milled to a 1” thickness through out.
The TRE connection points are milled at 10 deg and a thickness of .75”.
Modeled on a partial front axle
'85 4runner, finally lifted!
Done milling my steering arms!
http://www.pirate4x4.com/forum/showthread.php?t=548270
Working on DUAL-TRANNYS
4runner Freak is offline   Reply With Quote
Old 01-25-2007, 01:12 AM   #2
4runner Freak
Short on Time!
Member # 46208
I started to fab these arms in fall of ’05 when I took a Manufacturing process’ class. For the class we were allowed to bring in our own designs to the machine shop and set up the processes for manufacturing and then make them.
Well suffice it to say, each student only got 4 hours of machine shop time because of the size of the class. So I talked to the Prof and was allowed to be there for every student group, which gave me about 10 hours.
Of course I wasn’t able to finish them in that time frame so I asked the machine shop manager if I could come back over the brake and work on them then. He said that I would have to get approval from the Dean in order to use the machines outside of classes, so I did.
From the beginning.
I started with a 2”x3” block of steel and started machining using a bridgport mill.
So now all I have left to do is find someone that has the Toyota TRE taper mill and mill it for the TREs. Then press the cylinders into it.
Then comes the fun of converting my 4runner to crossover and praying that my geometry pays off.
Old 01-25-2007, 02:18 AM   #3
ashbyota84
ashbyota84's Avatar
Member # 85064
newbie here, my first reply, and all I have to say is AWESOME!!!
ashbyota84 is offline   Reply With Quote
Old 01-25-2007, 02:22 AM   #4
t0talkos
Member # 73342
Whats the advantage of having the tie rod behind the axle vs. over the axle.
85 Toyota for sale! 42" tsls, real clean!
[URL="http://www.pirate4x4.com/forum/showthread.php?p=6436151#post6436151"]http://www.pirate4x4.com/forum/showthread.php?p=6436151#post6436151[/URL]
t0talkos is offline   Reply With Quote
Old 01-25-2007, 02:27 AM   #5
SupraRunna
Member # 49630
this will allow you to push your axel forward much more without worry about your steering crossing over. only problem i could see is if you went to links instead of leafs...?
SupraRunna is offline   Reply With Quote
Old 01-25-2007, 02:28 AM   #6
ROCKILLER
ROCKILLER's Avatar
Member # 3273
No tierod to draglink interferance and almost impossible to bend a tierod.
Originally Posted by Alfred W. View Post
When a man has the scent of pussy in his nose...... The best advice in the world bounces off the block formerly know as his head.
ROCKILLER is offline   Reply With Quote
Old 01-25-2007, 06:29 AM   #7
300sniper
Pirate4x4 Addict!
300sniper's Avatar
Member # 26382
what about tie rod to oil pan clearance? i thought there was some issue with that unless the rig sits high. i have not actually looked for my self tho.
if that was done on a manual machine i am really impressed!
300sniper is offline   Reply With Quote
Old 01-25-2007, 06:54 AM   #8
metchosin joe
metchosin joe's Avatar
Member # 37213
a friend of mine made a set up like that and he had some oil pan clearence issues he had to make the tie rod with 2 bends in it
somthing like --\__/--
old toy, 42 PBRs, 60, 14ff,5.13s spooled and welded,duals, chromo output, ford springs front and rear, 8274, flat belly, exo, tera patrick reciever mounted pocket pussy with squirting option
metchosin joe is offline   Reply With Quote
Old 01-25-2007, 07:40 AM   #9
TBItoy
Member # 43587
Send a message via AIM to TBItoy
http://www.xkut-reamers.com/servlet/...ER-FOOT/Detail
Just bought this and retapered a pitman arm so the tierod end goes in from the top. Worked great and I got the reamer 2 days after ordering.
Yep. you'll have that....
TBItoy is offline   Reply With Quote
Old 01-25-2007, 08:19 AM   #10
OnTheSpot
Got gangsta lean?
OnTheSpot's Avatar
Member # 34900
Finally, someone that understands ackerman angle around here. Way to go, thoes should work out great!
Kickin' it old school carb'd 1F style
OnTheSpot is offline   Reply With Quote
Old 01-25-2007, 08:45 AM   #11
b2dude
meow
b2dude's Avatar
Member # 16270
Send a message via AIM to b2dude
huh? it just put's the tie rod behind the axle
awesome job on the arms...personally i think it'd be cool to put the drag link behind the axle.
now that i've re-read this...why aren't these more popular with sas setups? i know somebody else makes them, i saw some out at jv. i just thought it was to get the tie rod out of harms way, but to be able to keep the stock steering box location on an sas would be pretty cool.
b2dude is offline   Reply With Quote
Old 01-25-2007, 08:53 AM   #12
4runner Freak
Short on Time!
Member # 46208
Just further from the rocks and it is much easier to accomplish Ackermann angle.
Old 01-25-2007, 08:54 AM   #13
4runner Freak
Short on Time!
Member # 46208
No plans on linking, but it never ends, does it?
Old 01-25-2007, 08:57 AM   #14
4runner Freak
Short on Time!
Member # 46208
I haven't even lifted my truck yet(Start this weekend hopefully) so I don't know how much interference I'm going to have. I'm going to lifting only about 4" so we'll see.
Thanks for the bent tierod idea. Some gussets and it shouldn't be a problem
Old 01-25-2007, 08:59 AM   #15
4runner Freak
Short on Time!
Member # 46208
Yeah, I actually have XKUT in my favorite sellers on e-bay. Just thought I'd see if anyone has one they want to lend out or get rid of, but if a machine shop wants more then $50 to mill it, I'll just buy it and do it my self.
Old 01-25-2007, 09:00 AM   #16
4runner Freak
Short on Time!
Member # 46208
I think he's talking about the interference between the tie rod and drag link.
Old 01-25-2007, 09:05 AM   #17
2manyprojects
bar crawler
2manyprojects's Avatar
Member # 39901
Prevents contact between the drag link and tie rod. If the steering box is not moved far enough forward, this can be problem when moving the axle forward on a "standard" setup.
Because there is no 2nd chances on Pirate!
my 90 project http://pirate4x4.com/forum/showthread.php?t=655094
Save a tree, eat a beaver.
There are two keys to life, leverage and lubrication. Sometimes you need both.
Last edited by 2manyprojects; 01-25-2007 at 10:25 AM. Reason: the hand is quicker than the eye
2manyprojects is offline   Reply With Quote
Old 01-25-2007, 09:20 AM   #18
b2dude
meow
b2dude's Avatar
Member # 16270
ahh yes...i get it now
Originally Posted by 2manyprojects View Post
Prevents contact between the drag link and tie rod. If the axle is not moved far enough forward, this can be problem when moving the axle forward on a "standard" setup.
you mean if the box isn't far enough forward
Old 01-25-2007, 09:29 AM   #19
red85toy
Member # 39738
that is wicked!
great job!
Thanks,
Rod Peterson
1985 Toyota Pickup
TLCA #9116
[URL="http://www.crazypetersons.com"]http://www.crazypetersons.com[/URL]
red85toy is offline   Reply With Quote
Old 01-25-2007, 09:36 AM   #20
TheBandit
Accurate to 1/10th
TheBandit's Avatar
Member # 30965
Very cool. Have you mocked it up to check clearances?
New! Tube Bandit Digital Readout for Benders
---Cancer Survivor Since 10/06---
TheBandit is offline   Reply With Quote
Old 01-25-2007, 09:53 AM   #21
Navajo1
Member # 17616
Lotta work considering you can buy Ackerman corrected arms like you made from 4x4labs.com, been around a few years already.
Proud team member of Eilers Machine & Welding - Fabricating parts for the US Military - Support our Troops
[url]www.eilersmachine.com[/url]
Navajo1 is offline   Reply With Quote
Old 01-25-2007, 12:31 PM   #22
4runner Freak
Short on Time!
Member # 46208
Yeah, I know.
I had designed them already by the time I found out about 4x4Labs, but it's the principle of the thing. I would rather make something if I have the ability rather then buy it.
Old 01-25-2007, 01:11 PM   #23
Wilson
Pirate4x4 Addict!
Wilson's Avatar
Member # 7233
Send a message via AIM to Wilson
Nice drawings and arms of course. I've heard a lot of talk about ackerman angle over the years and if I'm reading your drawings correctly it seems it would be nearly impossible to accomplish this with the arms in front? TRE center through Kingpin/Bj should intersect at the rear axle centerline, correct? The second drawing also make si tlook to me that tire size plays a role when the wheels are turned,or is ackerman only dealing with my first description?
ECV 7-11 Serving up a Tsunami of Swagger
Wilson is offline   Reply With Quote
Old 01-25-2007, 01:59 PM   #24
ogrescout
Member # 70373
Send a message via AIM to ogrescout
That is some sweet work. Man i wish i had access to stuff like that. Keep up the good work let us know how they work
ogrescout is offline   Reply With Quote
Old 01-25-2007, 03:33 PM   #25
Brian Ellinger
Brian Ellinger's Avatar
Member # 1088
Very nice. Give me a call, we've got the taper you need.
1st place Pro-Mod WEROCK WORLD Champion
Diamond Axle
http://www.diamondaxle.com
Diamond axled buggies take 2 1st's, at Worlds WEROCK!!
Front Range Off-Road Fab with NEW forum!
http://www.frontrangeoffroadfab.com
NEW BUILD FTOY #44
http://www.pirate4x4.com/forum/showthread.php?t=562295
Brian Ellinger is offline   Reply With Quote
Forum Jump
