#1 |
I play in the mud
Member # 88672
How to: NP 205 twin stick CHEAP!
First of all, I know its been done before. I found information and pictures on several websites and manufacturers sites:
http://ivanribic.clubfte.com/page2.html http://jkwoffroad.com/offroadproducts.php#26 http://www.4wheeloffroad.com/techart...on_twin_stick/ http://www.offroad-tech.com/tech/twinstick205/ http://www.jpmagazine.com/techarticl.../photo_07.html I found enough information to figure out how to do it. I took a lot of pictures as I did it. It works great and I'll post the pictures. I did the mod to a spare 205 I had for parts I will move the setup into my truck during the next week or so. This particular 205 is a chevy from a standard transmission with granny low (t465?) ![]() This is how I got it no Idea what year etc. it is. Stock shift patterns: ![]() ![]() ![]() ![]() First the parts we are dealing with: ![]() Then begin disassembly: ![]() Bolt detail
#2 |
I play in the mud
Member # 88672
twinstick
Now we can play with the shift rails independently.
![]() ![]() ![]() ![]() ![]() Ok now we get on with modding the shift rails. ![]() ![]() ![]()
| Sponsored Links |
#3 |
I play in the mud
Member # 88672
twinstick
Ok now the shaft is out:
![]() ![]() now mark where the material is to be removed I gave it a shot of primer hoping to photograph it better ![]() ![]() ![]() ![]() ![]() Then reinstall the shaft the way you took it out. |
#4 |
I play in the mud
Member # 88672
twinstick
now lets see what shift patterns we can get:
![]() ![]() ![]() ![]() ![]() Heh I forgot to take a pic of RWD high and 4X4 high but trus me they are still there. Last edited by kitimatdude; 04-16-2007 at 07:36 PM. |
#5 |
I play in the mud
Member # 88672
twinstick
Now lets make a shifter for this bad boy.
![]() ![]() Its only a 1/2 inch bolt but its all I could find on a sunday, I'll get a proper 9/16 bolt tomorow. ![]() ![]() ![]() and thats all the parts you need! Last edited by kitimatdude; 04-16-2007 at 07:41 PM. |
#6 |
I play in the mud
Member # 88672
twinstick
Lets see how it shifts:
![]() ![]() ![]() ![]() ![]() ![]() There I'm out of pictures finally, any questions? Last edited by kitimatdude; 04-16-2007 at 07:42 PM. |
#7 |
Member # 49754
Great write up!!!!! thanks for another good source of info....
YJ 302 MOG 404's, fourlink 4.5 RE Coils, NP-435, 205, 42 iroks |
#8 |
It could actually take more than 6 minutes to finish a how too article.
#9 |
Member # 19933
Love the shifters.
'84 Yota 350 V-8 w/ spongebob air freshener |
#10 | |
Addicted to Gear Oil
Member # 56050
Nice write up
![]() I like use of 2 stock shifters to make the twin stick. To make it easier to read, can you edit and stack the pictures vertically, so it's not so wide? Thanks
1965 Scout 80 7.3PSD/ZF/203/205 Quote:
David H. Petraeus for President 2012 |
#11 | |
Member # 5832
![]() Aluminum? In Kitimat, just laying around? Get outta here! Welcome, Kitimat dude ...and what guidolyons said
#12 |
Empty 4Runner?
Member # 44480
Hell yeah!
KF7EFX 87 4Runner - FToy 086 - UHaul Toterhome http://www.12voltguy.com/ http://www.davezoffroadperformance.com http://www.mastercraftseats.com |
#13 | |
Member # 42045
nice write up BTW |
#14 |
Greasy yet refined!
Member # 5861
Excellent info
#15 |
trail tampon
good write up.
Fuck Cancer!! 83CJ7-350 on pane-465-205-chromo60&70-h1s-38.5" SX/boggers-linked rear-air shocks |
#16 | |
I play in the mud
Member # 88672
I got the bolt in it today but left the camera at home. I took the floor out of the blazer and looked it over it has rubber plugs where the freeze plugs go and the detent bolt for the FWD shift rail has a place to plug something in (4X4 light?) its a turbo 400 setup so the adaptor is wider, and the current shifter is bent different to be more forward. I dont see too much trouble working on it in the truck other than lining up the split pin in the shift fork. I want to extend my shifters and move them towards the driver as well. I'll do that as I go along trial and error
#17 |
Member # 56006
WOW...A Noob that knows his shit.....Good write up...Ill add it to my Favs
I think your allowed a stupid question now...LOL Last edited by JoshTurner; 04-16-2007 at 08:18 PM. |
#18 | |
I play in the mud
Member # 88672
You never know when you're going to ask a stupid question... |
#19 | |
Member # 56050
That should be a requirement to join PBB, you have to post a kick ass tech article ![]() From the looks of that bogger in the background, kitimatdude is not your average newb
#20 |
Member # 43196
Nice article. Going to do that this weekend on the 205 going into my Scout.
#21 | |
I play in the mud
Member # 88672
I'm running 2 frames in my k5 I have the drivetrain in the lower with a 4" spring lift. The upper frame is pruned off just ahead of th cab mounts. Its not a rock crawler. |
#22 |
I play in the mud
Member # 88672
Its kinda fun to do, it only took a few hours.
#23 |
I play in the mud
Member # 88672
I had my camera today
![]() I need maybe 1 more washer. The bolt is long enough that it bottoms out so I dont need to use loctite on it. I removed the floor panel in my k5 and scraped some of the crud off my 205. ![]() its not as accesable as I had hoped but I think I can do it in position. note the rubber plug where it was a frost type plug on the other transfer case. Anyone know if its stock that way? or has this been rebuilt before? I think the frost plug wwas more secure.
#24 |
Who???
Member # 64846
Thanks for the write up. I'm thinking about picking up a spare 205 and doing this mod to it and also changing the front output shaft to a 32 spline.
My Chevy Build......Going Commando |
#25 |
Member # 1684
Although what you did probably works just fine it should be 7/16" grind on both areas. It's just the throw the rail moves with one shift. No benefit I can see to do them different.
S.N.O.R.T. |
| Thread Tools | |
| Display Modes | |
