Im looking into swaping in some sort of diesel into my 85 4runner, and this thread is more less just going to be a place that i can put links/info that I find so i dont end up forgetting stuff and having to search for things Ive already found. If any one has any links to builds/swaps they know of post them up, but mainly Im just going to start putting every thing I find in here.
What I want in the swap:
1.To be able to run a mix of homebrew bio and pump diesel
2.CHEAP- the cheaper the better, what is cheap? Right now I dont know.
3.Power comparable to a 22re (112 hp at 4600 rpm and 142 ft·lb at 3400 rpm)-3rz (150 hp at 4800 RPM with 177 ftlb at 4000 RPM), I would like 100-125+ horses and 125-170+ft/lbs more is better, yet still be reliable.
forums
http://toyotadiesel.com/forums/index.php
http://forums.tdiclub.com/ - Volkswagen TDIs
http://www.hiluxsurf.co.uk/forums/index.php- UK forum
http://www.toyotasurf.asn.au/forum/- Austrailian forum
http://www.sr5.net/bbs/index.html - Thailand forum, looks pretty outdated and clustered, but Ive seen alot of references to it.
forum discussions
http://www.dieseldoctor.com/messageboard/data/474.html - List of toyota parts sources, talk of 2l,2lt,3l swaps- pretty cluttered though
http://www.yotatech.com/showthread.php?t=13098 A guy who swaped a 2L-T into a 1993 4x4 single cab some good disscussion
http://www.toyotadiesel.com/phpBB2/viewtopic.php?t=1415&postdays=0&postorder=asc&start=0&sid=94f978644e74fed4720c33f330a6c331 - 2LII-T swaped into a 1989 pickup
http://forums.tdiclub.com/showthread.php?t=172946some biodiesel talk
http://www.vwdiesel.net/phpBB/viewtopic.php?t=579&postdays=0&postorder=asc&start=0 Tuning for power on a VW 1.9 TD
Builds/write ups
http://vpizza.org/~jmeehan/toyotadiesel/ - Toyota 2LII-T diesel engine into a 1989 Toyota XtraCab truck - Best source yet, Good FAQ
http://forums.tdiclub.com/showthread.php?t=158587&highlight=toyota 1.9L TDI into 86 4runner
http://www.pirate4x4.com/forum/showthread.php?t=354974 Rockclod's 1.6 VW Turbo Diesel into 85/87 truck
http://toyotadiesel.com/forums/showthread.php?t=186&page=4&highlight=volkswagen 1.9t engine code AAZ
into 84 xtra cab 4x4
http://forums.tdiclub.com/showthread.php?t=176999 1996 1.9 1Z TDI into 1991 Toyota truck
specs/FAQs
URL="http://www.geocities.com/MotorCity/Pit/9975/dataBySubject/DieselEngines.html - Lots of Toyota Diesel specs
http://tdiclub.com/TDIFAQ/ - TDI FAQ
http://www.showmesome.info/hilux/info/download_links.htm - Electronic parts catalogs -part numbers for japanese spec motors-
Manufactures/companys
URL="http://www.dieseltoyz.com/ - seems to deal mostly with late model toyotas
URL="http://www.acmeadapters.com/ - VW TDI to W series adapters
http://www.kennedyeng.com/ - Rumured to also make VW TDI to W series adapters
http://jarcoinc.com/ - Japanese front cut importers
http://www.asapmotors.com/ - another importer that can get Diesel toys
http://www.trademotion.com/partlocator/index.cfm?siteid=214074 - Cheap place to get factory parts
forums
forum discussions
Builds/write ups
specs/FAQs
