#1 |
Member # 73680
231 Box 4 Rocks Build Thread (for dumbasses)
After a month or so of research and trying to figure out how to put this fuckin thing together i decided to put a thread together showing a detailed way of putting the Box 4 Rocks kit together. Believe it or not it's actually quite simple. Don't for those dumbasses who can't read I've got plenty of pictures (i bet TJP is bout SHITTING HIT PANTS RIGHT NOW!!! : Anyway, here goes:
Parts included in the kit: ![]() Backing plate and clocking ring bolts ![]() 231 to D300 shaft (23 spline in my case) ![]() new 231 guide rod for shift fork ![]() D300 clocking ring 1"x4" (i believe the measurements are correct) piece of aluminum used for blocking off the portion of the case after cutting off unuseable end. not included: Dana 300 ![]() NP 231 Front half Tools needed: Misc sockets and allen wrenches RTV loc-tite Alright: You only want to keep the pieces of the NP231 you see in this picture, nothing more nothing less--makes sure you have the pads....despite what the stealership has in their parts records they have differents pads for differents year shifter forks so not all 231's are the same (TRUST ME I KNOW) ![]() **DISREGARD SHAFT AND GUIDE ROD--they come w/ the kit With only front half of 231 case left bolt 'b4r' backing plate on; draw line with marking tool: ![]() Weld block into case ONLY!!! here's a picture of a case i found on pirate: ![]() after block has been welded to 231 case to reassemble parts like the picture shown:
#2 |
Member # 73680
Next attach D300 clocking ring to D300 t-case using loc-tite and RTV
![]() ![]() Next I made a sight tube on my 'b4r' backing plate like this: using two of these: ![]() and some tube i took the top screw and the bottom brass allen screw out and replaced like so: ![]() This is probably where you probably where you wanna put the 231 on the vehicle and then the D300 (at least that's what i'm gonna do). I would also maybe mock it up outside the vehicle a few times and mark the backing plate and the clocking ring to save some time since that D300 is pretty damn heavy. Now attach the backing plate to the clocking of the D300 using the bolts provided in the kit like so using lots of RTV: ![]() Then attach D300 to 231 no forgetting shift fork/guide rod spring for the 231 case using the bolts provided it should look something like this; remember RTV is your friend cause leaks 2 weeks later really suck balls: ![]() or about a thousand different ways depending on how it's clocked. Please feel free to add pictures and info for those who have already done this; this is not the all inclusive thread but i'm sure it will help a few out. |
| Sponsored Links |
#3 |
Member # 25416
Sweet just what I needed!!
Thanks. |
#4 |
Never Bored
Member # 83807
Nice build, just curious about how much time you spent?
93 New Holland Blue XJ with 1 tons, chopped and exo'd on 38's Eph 4:1-7 |
#5 |
Member # 73680
spent putting it together, not really long at all....research awhile, i don't think the install will be to bad....the shifters are gonna be bad i think....
#6 |
WINNAR!
I take it you found the correct pads??
Somebody check my brain! |
#7 |
Newbie
Damn Eric the shit missle isnt going to go anywhere with all that gearing......... I like it tho!!!!!!!!!!!! Can not wait until its done........ Going to put all other Cherokees to shame around here thats for sure!!!!!!!!!!!!!!!!!
James |
#8 |
Member # 45871
Nice.. cant wait to see it all mocked up
.... I guess I need to get motivated and start putting together my shit now
90 Comanche truggy a work in progress |
#9 |
Member # 73680
I learned this the hard way yesterday:
the input shaft on a 04 TJ 231 (5 spd i'm sure) is longer than that of 99 XJ 231 input shaft. Glad i live really close to a machine shop....bear in mind not all 231's are the same!!! |
#10 |
Mental Guru
Tech to the top BS to the bottom...
TJP-'89 MJ Project Life's Journey is Not to Arrive at the Grave Safely in a Well Preserved Body. But to Launch Hard at Red Line, Shedding the Tires, Get Wicked Air, Land Hard, Drift in Sideways with the Tires Smoldering, Totally Worn Out, Thrashed, Screaming "Holy Shit What a Ride!!!" |
#11 |
Mental Guru
clean up
#12 |
Member # 61408
are you running a pass drop 60. does the box for rocks kit allow the 300 to be clocked drivers drop or do i have to drop the $ for a flip kit as well. i have seen the shifter flip for the 300 but am not sure how well it works i would like to run the same setup but need it drivers drop. any help is appriciated
KEEP US POSTED ON THE SHIT MISSILE, props on the build
87 XJ sittin on all four jackstands 99 exploder Last edited by duffxj; 05-11-2007 at 12:57 PM. |
#13 |
Member # 73680
i just flippin it on the cheap w/ the kit from duffy w/ the shifters that he made....i really haven't figured out how people put an extra seal in the shift rails...i figured i would throw a little RTV around them and call it good if they start leaking at all....we'll see....i'm run a ford hp60
91 toyota pickup--a work in progress XJ, tons, 40's, EOR cage, locked, doubled...GONE |
#14 |
one of many
Member # 81266
Since you labeled it as for Dumb Arses, I'll ask a dumb arse (or inexperienced ) question: What are the "pads" you are talking about? I've never taken a T-case apart (yet). Got a pic of them by any chance? I am a better visual learner anyhoo! Thanks in advance, feel free to flame away.
#15 | |
Member # 61408
good to hear, post up some pics of the shifters once you get everything in place, im in the process of putting the same setup together
87 XJ sittin on all four jackstands 99 exploder |
#16 | |
Member # 73680
see the translucent square pieces in the third picture from the top by the shift, those are the pads that i speak of...
#17 | |
one of many
Member # 81266
#18 |
Do you have any shifter pics of the cases in the XJ?
I bought this kit used from a guy off of Pirate that attaches a 231 to a 300. But i cant decide if i want to run a chevy 60 or a ford 60.
1997 TJ - 78 HP60/14b, B4R 231/300 doubler, 42's, 110'' wheelbase....in the worx. |
#19 |
Member # 47428
updates?
#20 |
Member # 73680
I just drilled the tranny about a week ago, and i'm currently working on the tunnel cover for it, then onto the crossmember for the D300 when all that is done it should be good to go...
#21 | |
Pigs fly!
Yeah, that makes two of us.
![]() I decided to start over on mine, it wasn't worth fucking around with making little patch panels and shit. Quote:
You can also see why I decided to go to plan B, as shown at the top of this post.
'94 XJ with 4.6 stroker, NV4500, NP231doubler/D300, D60/14B, 4.56s and Detroits, 38.5 Creepies, 4-link rear & 3-link w/panhard front, dual roll cages. FOA coilovers all around. bacon express ![]() TELLICO RALLY POST #18 |
#22 |
Member # 41185
Holy crap!
I can see your XJ looking a lot like ASHMAN'S in the future!
WARNING TO ALL WELDERS!!!! My "Family" XJ Build My "HARDCORE" CJ build ![]() You play ball with the PBB or we'll shove the bat up your ass. |
#23 |
Pigs fly!
Well, I'll be framing out a new tunnel around everything and having removable skins on it. It'll look a lot more finished once everything is painted etc.
I've still got much more body that Ashman has, I guess it'll just be a matter of time before it goes away though. I'd like to keep it together as long as possible though. Doors still go on, A/C blows nice & cold, and the stereo's pretty damn good too.
#24 |
Member # 55363
i got duffys cheap flip shifters , and they come out pretty much where the stock tc shifter comes out , just needed to cut back about two inches as the shifters have lots of throw. Also need to bend them abit to clear my seat but seems to work well. You guys have any sealing problems I thought i used plenty of rtv but still got a slight leak around the clocking ring.
#25 | |
Pigs fly!
I also recommend putting some sort of sight tube on it so you can keep an eye on the fluid level; you can sorta see mine in the pic above. I can get the part numbers for the fittings and stuff I used if needed.
| Thread Tools | |
| Display Modes | |
