#1 |
Grocery Getter
Member # 59
My new trail/street rig build- '97 4runner
[edit]
Also see the build web page to see a consolidated and more final version of this build w/o sorting through this whole thread!] http://home.4x4wire.com/erik/97runner/ [/edit] I've been wanting to build a 3rd gen Runner for years. Now I finally get to do it. ![]() I picked up a fairly pristine high mileage (224k) commuter 3rd gen for only $6k a few months ago. Seems to be in perfect running condition. My '86 runner is getting retired and all of its goodies are going on the '97.Specs/plans: - 3.4L V6, 5-speed (stock) - ScanGuage2 for digital guages/engine monitoring - 140A alternator, probably just like OOP's 3.0L setup, assuming it fits the same. I'll try to use the one from my old rig first. - York OBA, which will require moving the battery and fuse box slightly. Bud @ Budbuilt is supposed to be building York bracket kits based on my setup... - Fully built/clocked passenger drop dual-ultimate t-cases from the '86 - Clocked FROR crossmember - Clockable Inchworm V6 adapter (can clock up to 20* using both Marlin clocked dual case adapter and Inchworm V6 adapter). - Marlin 23 spline input - Marlin VSS - 63.5" D44/Lock-Right/AlloyUSA/Longfield front (link) - 3-link/panhard front suspension, possibly with coilovers and air bumps - 2wd T100 oil pan kit (Sky) - Steering box? Undecided, might go with a forward-swing box... (FJ60 or ScoutII). Ordered a Scout II box from a PBB member. - Redneck ram hydro assist - PSC power steering pump kit (PORC) - 63.5" Trussed/shaved Tacoma/ARB/PolyPerformance rear axle w/ 1.5" spacers (link) - 4-link rear suspension, probably coils/shocks - Ford gas tank for better ground clearance and space for the 4-link - Aux air bags (center mount?) for heavy loads and lifting the rear up during high centers...? Links will have Johnny Joints at one end, bushings at the other. Lowers will be non-adjustable, 2x2x3/16" square tube. Uppers/panhard will be adjustable using Ballistic Fab tube adapters and bushing sleeves with threaded studs, and Johnny Joints with studs. 1.5"X.120" round tube. - Brakes: T100 booster, GM master, Sky rear disk kit and Allpro t-case e-brake. I may have to see if I can swap to a dash mounted e-brake handle vs. the stock 4runner center console one??? - ABS will be removed - 37" MTR's - May switch from 8" to 10" rims - Staun beadlocks? Here are some comparisons between the old and new rigs as they currently sit: Measurement ____'86 _____'97 __ difference tire size ______ 37 _____ 31 ___ +6" frame height ___ 26 _____ 16 ___ +10" belly height ___ 23? ____ roof height ____ 78? ____ 70? __ +8" Wheel base _____ 107 ____ 105 __ -2" outside width __ 78? ____ 68? __ +10" (The '86 has a 1" bodylift, the '97 will not.) I'll be shooting for about 4" lift, no body lift, 23" frame height, front axle moved 2" forward, rear axle moved ~4" back, ~113" wheelbase. The goal is for it to be similar to my '86, but a couple inches lower and longer and with a slightly better rear departure angle. This will be a fairly slow build, so don't go cluttering up this thread asking for updates every couple of weeks. My plan is to keep the '86 wheelable as long as possible while I do bumpers/sliders/fuel tank/OBA/alternator and anything else I can on the '97, and then start cutting it up and getting the axles and t-case under it and have it done late winter/early spring, in time for the Hammers. ![]() [edit]Scratch that- both rigs are now both all torn apart! Also, here is a link to some stuff Sean and I were discussing about our future 3rd gen builds: http://www.pirate4x4.com/forum/showthread.php?t=587375 Last edited by ErikB; 12-13-2008 at 08:57 PM. |
#2 |
Grocery Getter
Member # 59
Here are a couple of pics of how it sits now, with a couple hundred pounds of flares, running boards, bumpers, skid plates and tow hitch removed.
| Sponsored Links |
#3 |
Pirate4x4 Addict!
I really like the 3rd gen's but there is just too much shet metal on them for up here in the PNW.....
Why is it we all are for doing the same thing--but yet we can not work together to achieve it Mike Crash Kash The new live streaming video crashfab |
#4 |
Grocery Getter
Member # 59
Oh yeah, and Webilt's runner is kind of an inspiration for mine, only it won't be nearly as tall and I have no plans for an exo.
Last I heard, he was swapping a 3.4L/auto into it too. http://www.pirate4x4.com/forum/showthread.php?t=220153 Last edited by ErikB; 08-29-2007 at 04:29 PM. |
#5 |
Member # 19373
Wow very sweet looking build! Your 86 has been a huge insperation for me, Ive Built alot of my rig from watching and reading about yours. Good luck with the new toy and build.
![]() My rig
[CENTER]When the power of love overcomes the love of power, the world will know peace. -Jimi Hendrix[/CENTER] [QUOTE=steveh;7244017]Keep it on track guys. DRM and I will be watching. We need our TG paychecks ...... [/QUOTE] |
#6 |
WabFab.org
I hope to do a 3rd gen someday...just have to find the right donor.
Looks like a fun project.
#7 |
Pirate4x4 Addict!
Member # 227
Looks like a Blast Erik!
The next one I build will be a 4 Door 3rd Gen. KC KC
JOIN THE ACCESS ARMY! Its time to Soldier Up to PROTECT ACCESS! http://www.delalbright.com/Access/army.html Special Thanks to PRP Suspension Seats, Trail Gear, CTM, Davez Offroad & Pirate4x4.com www.davezoffroadperformance.com |
#8 |
Media Elite
Member # 2242
Glad to see the project getting started Erik. You should look in to the Off Road Solutions coilover kit for the front.
Harry Situations Harry Wagner Freelance 4WD Writing & Photography Vehicle Features, Tech, & Trail Reports |
#9 |
Pirate4x4 Addict!
Member # 30
Location: Roseville, CA,To many Yuppies, Not enough Hippies
Looks good Beebs. Hope I am on the trail with you when you put the first dent in it!!!!!!!
David & Theresa, Roseville, CA, Excellent Parts Source http://www.davezoffroadperformance.com/ http://www.marlincrawler.com/ http://www.12voltguy.com/web/ Last edited by OOP'S; 08-29-2007 at 08:28 PM. |
#10 |
wheeledoutdawomb
Member # 37854
Do you plan on running it on the street? if yes there is a couple things to be aware of, i only say this cause i just finished a build on a 97 4 runner and ran into some major issues that if i didnt have a work around for the problem it wouldnt be on the street, possibly would have gone a different route if i knew then what i know now.
here is a couple pics
70 Gmcjimmy203/205 PARTING OUT 86 zukcrawler36's,longfields,dualcases,ARB5.29,foxsho cks 87 farfugzukn/dd,on 31's,diesel1.6NA,yj springs,6.1tcaseFOR SALE 88 zuk dd 1.616v stocksuspentionFOR SALE 97supercharged4runnerSAcd44/d60 06DodgeMegaCab6spddually4xcummins Johnson Valley Post # 941 Last edited by allbentup; 08-29-2007 at 09:19 PM. |
#11 | ||
Grocery Getter
Member # 59
![]() Definitely. My rig has never seen a trailer, except for the one that gets pulled behind it. Any input/experience you can add would be appreciated. Got more pics of the front suspension, panhard, etc.? |
#12 |
Member # 20195
Cool, I'm sitting with a 1996 DD 4runner I'm going to build up, not too much info out there though...
Currently it's got the 2.7 with the w59 I'm going to be swapping my duals out of my 83 and I have a r150 with the 4 cyl adapter, just need the marlin 2.7 to r 150 bellhousing... Not sure what I want to do with the suspension (budget wise was thinking of the marlin sfa kit...looking forward to updates on the build
83 toy, 5.29's 36" IRoks, Detroit rear, Auburn limited slip front...now with dual tcases & TDD spacers front and rear [QUOTE=Dr.Van Falk]Seriously, once you start dying your hair you're only a boob job away from being able to do porn in Brazil.[/QUOTE] |
#13 |
Accurate to 1/10th
Member # 30965
Dang Erik - you pack your 4Runner like me.. to the roof! Looks like it's a good thing your new rig has some cargo space.
I'm definitely looking forward to the build. Best of luck going forward. |
#14 |
Member # 45196
nice this will be a good build to see. I parted out my 86 in november to build my 96 tacoma that I now drive around a hundred miles a day. You'll love the power and comfort of the newer rig
96 taco, lockd, linkd, caged, beat, daily driven 24" frame on 4dz ready to jump |
#15 |
Member # 18993
did it come with the 5-speed? or is that something you are going to be swappin in? i've been getting ready to build one aswell once i can find a good canidate, so im looking forward to seeing this
R.I.P. RYAN [QUOTE=Grumpy_old_fart;7711636]yeah, sure build it. drive it. can i get an insurance policy with your name on it, so i can be beneficiary when you die?[/QUOTE] |
#16 | |
RIP Bo
Subscribed.
I've got similar plans for my '97 3.4L 5-speed whenever my rig gets too beat up to drive on the street anymore; but I'm still a few years away. ![]() I'm interested in seeing how yours turns out though. Here's mine.
Terry Quote:
#17 | |
Grocery Getter
Member # 59
Yep. I had to look around for a while to find the 5-speed/V6 combo, and in the price range I was looking at. -> I updated and cleaned up the original post a bit.
#18 |
Member # 69745
how much heavier is the 3rd gen than the '86?
#19 |
Pirate4x4 Addict!
here's to hoping your build goes much faster than mine
This Space for rent! |
#20 |
Member # 6892
This is going to be an awesome build.
Are you running cromo's in your taco rear?
Yarr! I've been to the Hammers... There in the tool section at Home Depot. Rally for The Hammers post #141 Rally for Tellico post #100 |
#21 |
Grocery Getter
Member # 59
Dunno. I'm curious about that myself. I should weigh the '86 before I tear it apart, and the '97 before and after I build it for some comparisons.
![]() Me too! ![]() Unlike you I'm only a part-time family guy, so I *should* have plenty of time to get things done... Yep, Poly Performance shafts. Never had a problem w/ the stockers, but was worried about not having any spares. Now I've got chromos AND spares, so I should be more than set. Oh yeah, I'm also going to pick up a ScanGuage2 for its digital guage/engine monitoring/scan tool features. ![]() http://www.scangauge.com/
#22 |
Member # 3140
Erik you will like the scangauge2, I dont know how i worked on odbII vehicles before i bought it.
Toy truck with some poop pipe.Some Marlin, PolyPerformance and Sky junk glued on here and there. |
#23 |
That is a sweet tool for $170.
#24 |
chicken fucker
Member # 2931
subscribed. if you build yours slow enough i can be the guinea pig for the link setups(my 2nd generation is under the knife as of next weekend). im keeping the gas tank in the stock location and running a copy of trail gears rear link setup and the same up front. build it yourself, you dont need a kit, we all know your a fart smeller, i mean smart feller...
what do you think about using a body lift to provide space for that rock anchor gas tank hanging way below the frame rail?
http://www.diamondaxle.com http://www.F-O-A.com http://www.12voltguy.com http://www.addictedoffroad.com wanted: (2) 12''x3''x250# coilover springs 2002 diamond axled coilover/linked tacoma v6 4door rock taxi with dual cases and beadlocked 37s |
#25 |
Member # 53724
This one we built here allpro dana 60 hybrid front axle with there tacoma
coil over kit with leafs in the rear
[URL=http://yotamasters.com]Yota Masters[/URL] 1991 Landcrusher 1982 Toyota crawler, Froggy. 2000 Tacoma on "nappy headed" Hoe's. [QUOTE=Myanarchy] [COLOR="Orange"]I think I'm gonna stick it between max volume and his boyfriend's pelvis. The force of their love could crush a bowling ball.[/COLOR][/QUOTE] |
| Thread Tools | |
| Display Modes | |
