Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 11-11-2007, 03:48 PM   #1
ericrunner
Member # 46516
Joint 360 ( 1 link )
2 5/16 trailer ball, housing is 4'' x 2 1/4 comes with a plate to install ( bolt on or weld ) 4x6 x 1/2the joint bolts to the plate .42 degrees articulation. It can be use for 1 link, 3 link and heavy duty replacement bald joint
250$ canadien dollar for 1 kit joint 360.
SAVE 30$ when you buy a pair
The joint 360 is guarantee for life against breakage
[url]www.4x4laurentides.com[/url]
[B][SIZE="6"][COLOR="Red"]360 Joint[/COLOR][/SIZE][/B]
[URL="http://www.pirate4x4.com/forum/showthread.php?t=629586"]http://www.pirate4x4.com/forum/showthread.php?t=629586[/URL]
ericrunner is offline   Reply With Quote
Old 11-11-2007, 04:01 PM   #2
MC
www.Bulltear.com
MC's Avatar
Member # 21997
Send a message via Yahoo to MC
Interesting, looks familiar to something I had here a couple years back! Good luck with the new product...looks SHARP!!
How do you mount this?
Bulltear CNC plasma support forum click here
We offer
  • Rods ends!
  • Coil-overs!
  • Air shocks!
  • Billet items!
  • QA-1 coils and Rock Ends!
Own a full blown Plasma CNC for less, click here
MC is offline   Reply With Quote
Old 11-11-2007, 04:06 PM   #3
ericrunner
Member # 46516
this joint can go as far as 42 degrees so considering that you can use that for 3 or 4 link it will be undestructible .
Old 11-11-2007, 04:10 PM   #4
MC
www.Bulltear.com
MC's Avatar
Member # 21997
Very nice replacement for the Nth degree ball.
We offer
  • Rods ends!
  • Coil-overs!
  • Air shocks!
  • Billet items!
Old 11-11-2007, 04:17 PM   #5
yfzut
Member # 53425
anybody have a pic of one installed, do you think a single one on each end would be strong enough to handle a built 454 and 42,s.
yfzut is offline   Reply With Quote
Old 11-11-2007, 04:23 PM   #6
ericrunner
Member # 46516
garantee for life
Old 11-11-2007, 04:34 PM   #7
yfzut
Member # 53425
do they chatter or make alot of noise, i really like this and just woundering about the pros and cons. do you have site to look at these installed , kinda wondering how to mount it. im very interested in a couple to 1 link the front and rear.
Old 11-11-2007, 05:12 PM   #8
ericrunner
Member # 46516
no noise what so ever , no slack . I will post some pics later this week but you can mount those any way you want.
Old 11-11-2007, 05:18 PM   #9
ericrunner
Member # 46516
I have been running 1 links for the past 2 years and from experience and time that is what we came up with. We called it joint 360 degrees because if you mount it the way we do the only limitation of travel is your shocks
and its so simple to understand the geometry and install its also one of the only systeme to fully protect the drive line
Old 11-11-2007, 07:35 PM   #10
PsychoticDeadGuy
PsychoticDeadGuy's Avatar
Member # 54093
I am very interested in this thing! I would like to see some pics of it in use though...
Cut Now, Measure Later...
'05 LLY Duramax, waiting for EFI Live
'82 6.2l K5 Blazer, waiting for the 12 valve
Member of Underconstruction 4x4
Build It...Break It...Fix It...Repeat...
MKM Customs & Sinister Mfg. Company
PsychoticDeadGuy is offline   Reply With Quote
Old 11-11-2007, 07:42 PM   #11
ericrunner
Member # 46516
Old 11-11-2007, 08:18 PM   #12
yfzut
Member # 53425
i like it, very cool. is your 4 bars just welded to the axle housing.
Old 11-11-2007, 10:01 PM   #13
currupt4130
Member # 39371
Send a message via AIM to currupt4130
Something about the frame being in the way may hinder travel too...
Great product, looks pretty cool and very well done.
currupt4130 is offline   Reply With Quote
Old 11-11-2007, 10:25 PM   #14
Azzy2000
D1G1A0F9
Member # 11869
Very nice looking product
I may have to give it a try when I link my front.
Azzy2000 is offline   Reply With Quote
Old 11-11-2007, 10:36 PM   #15
frontier2k1
Texan stuck in NC.
Member # 43124
This looks very cool but I'd like to see some more close ups of how they are mounted...
99 Frontier in pieces, 406 mogs, doubler, atlas 4 speed, 40s with other random parts. Build thread------->http://www.pirate4x4.com/forum/showthread.php?t=733603
www.noas4x4club.com
frontier2k1 is offline   Reply With Quote
Old 11-12-2007, 05:55 AM   #16
ericrunner
Member # 46516
sorry for the poor quality of the pics above, its a custemer rig Dodge ram charger 1979 . 2x4 1/4 was used welded to the frame i will post some pics of my moon buggy under construction this week i used 2'' 3/8 DOM + 3/8 flat bar
Old 11-12-2007, 05:58 AM   #17
ericrunner
Member # 46516
on pic num 1 the Joint is bolted to a plate adapter that is welded to the frame . This is not the plate we made mine is rectangle
Old 11-12-2007, 09:38 AM   #18
pdm
Member # 97355
No bushing or liner? What steel are you using, because it looks to me it will just get loose with a little wear just like any other rod end?
pdm is offline   Reply With Quote
Old 11-12-2007, 10:04 AM   #19
Red Chevy
Red Chevy's Avatar
Member # 64526
I like the joint, I also have a question for u 1 link guys. Are there any issues in the rear with the axle trying to walk under the truck when the front is against an object. I am considering this setup in the rear of a friends truck.
2006 quadcab cummins H.O. 4x4, Airaid intake system, Diablo Predator/Power puck stack
35x12.5x20 mud grapplers, 3" kore chase susp.
CJ-7, rocks, 43x16x20 R-4 treads, build on hold
Red Chevy is offline   Reply With Quote
Old 11-12-2007, 10:15 AM   #20
Ramrock
Member # 20276
So is that just a standerd trailer ball or you making that to. I know most trailer balls shanks are the breaking point. Not the hitch. So is the 200,000 lbs rated at the mount or ball. Just asking. The strongest ball ive seen was a 2"shank ball rated for 25,000. Just seems like you could pull the thread off under hard braking.
Very nice look joint and mount.
01 RAM 2500 Q/B 2WD 24V CUMMINS
85 YOTA 2.5-ROCK's TBI-4.3/tb-350/doubler/42"s/H1's/4LINK/1 LINK
Ramrock is offline   Reply With Quote
Old 11-12-2007, 11:31 AM   #21
ericrunner
Member # 46516
any type of link the diff will walk under if its to short, i like to have the 1 link the same lenght as the drive shaft that way it protects the drive train and the drive shaft dosent move that mutch at the splines.
Yes its a regular 2 5/16 trailler ball
Before you can get any slack im shure the rig will be dead by then , its greasable
A regular ball is tested as side load , this when installed the way it was dessing for 200 000 lbs makes more sence .
Old 11-12-2007, 09:35 PM   #22
mrtwstr
76 Green Heads
mrtwstr's Avatar
Member # 12370
I know this is going to make me sound like a total dick, but......
First -
Spell check man. I know I wouldn't buy shit from someone who reads like a grade school drop out.
Second -
Be careful what you say, making incorrect statements and/or saying stupid shit will lose you a lot of respect around here.
Third -
Do a giveaway you cheap fuker!
My mom thinks I'm special!
XXX Traction.com
Triple-X Traction.com
Lavender Brothers.com
mrtwstr is offline   Reply With Quote
Old 11-12-2007, 09:52 PM   #23
Hammered Scout
Member # 62561
French Canadian?
69 Scout 800, 60F,14bolt,6.0 LQ9/T400/Atlas4.3,39.5 Swampers, 2001 Dodge CTD 6Spd H.O, 4x4, 1965 Unimog
[SIZE="4"]"If your buddie was shot in the ass with diamonds, coils and 4 link would be the way to go IMO." [/SIZE]
Hammered Scout is offline   Reply With Quote
Old 11-12-2007, 10:34 PM   #24
Y-TOUGH
Newbie
Y-TOUGH's Avatar
Member # 84170
Yes, I am also a Canadian French.
I am sorry if I made of the lack of ortographe or if I am having difficulty understanding me.
It makes me very nervous to write in English.
But I will try using language translator.
Eric is a good person and he has good will.
I do not yet know his product but it interests me a lot.
This year I change my boggey to put rockwell and bogger 54.
I love this sport, and finds this distressing language barrier.
If you love not to write my words do not read me please.
Now swap to bogger 54" and rockwell
www.lagangdemalade.com
Some of our 4x4 video competition
Y-TOUGH is offline   Reply With Quote
Old 11-13-2007, 05:32 AM   #25
ericrunner
Member # 46516
im not to good with the computer is there a function to correct or translate ?
You think a give away will help lunch my product in the US
Forum Jump
