Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Suzuki
Thread Tools Display Modes
Old 12-30-2007, 07:47 PM   #1
dabomb5756
dabomb5756's Avatar
Member # 62837
Quick Stretch, a Samurai build on yota's and 36's.
Figured i should start a thread so i could show what i'm up to, and so i could ask questions in here instead of starting new threads each time...
I've been wheeling my samurai on 31's, yj's in rear, ruf, locked front and rear on stock axles with hi steer and kick power steering, 1.3 and 4.9's. I've been wanting more wheelbase and i've had yota axles laying around for about 2 years now.
I'm in college, away from home, so i'm trying to finish this project over winter break. I have until jan. 22nd.
I rent one side of a barn in the middle of nowhere and thats where most of the build takes place. Its only 5 min away from my house and has power, but only one small section of concrete and its not level. The rest is dirt, but i'm gona get some doors and sawhorses to make some nice workbenches.
Heres a link of the old stuff for sale: http://www.pirate4x4.com/forum/showthread.php?t=642740
Now, i am planning on a front frame stretch, 2x4 rectangle, 1/8 inch wall. I have 86 4x4 yota rear springs for the front, about 48 inches long with a 5 inch offset pin. I will mix in some of my ruf pack springs. I am keeping the shackle up front. Axle will be moved about 7-9 inches forward.
I will be going with a tube front clip. I am still stuck on steering, i am just going to build the suspension, then figure out if i have room for a yota ifs box, if not im going with a single ended hydro cylinder.
I'm also trying to get a mount set up for a future winch. I want it set in the frame rails like art (nczuk) did on his popsicle rebuild.
In the rear, i am going to keep my yj's, but i will be putting the shackle on the rear bumper and raising the front mount so its not a rock hanger anymore. I will need to build a trackbar also. Springs will be mixed leafs from front and rear yj's.
Right now i plan on chopping the rear of the body and floor at the seam behind the seats after the step up. I will tube it out, adding onto my existing rockrat cage and connecting to my rocksliders. I might do a comp cut though and keep some body. Depends on the rust situation. I dont really like doing body work, so i will most likely chop it.
Gas tank will just be raised up, axle will be moved about 5-6 inches back.
My neighbor can get me all the free pipe i want. I plan on using sched. 10 pipe for most stuff, but sched. 40 for the top bars of the rear cage. Dont get started on the pipe/tube debate, the passenger and driver are covered with a hrew cage build by rockrat and thats all that matters.
I usually go to the steel supply yard and pick through their dumpsters. If i take alot, they charge me scrap metal prices, something like 40 cents a pound. I get all my steel plate for mounts, guessets, or whatever basically for free.
I use a 110SP Plus lincoln and i am borrowing a hf bender. I plan on buying a hf 14inch cutoff saw and hopefully i get good at notching with it.
My budget it 0 dollars. I think i can do it if i sell my old stuff.
Well, my progress so far..
I've got both axles and driveshafts pulled, rear bumper off, skid plate off.
I've got all three yota axles apart. I have two rears with 4.10 and a front with 4.30. All are 4cyl 8 inch diffs and 55wms (not ifs rear). I am putting a 4.10 up front for now also, and will run 4.10 gears until i get a job over summer. Then come 5.29's and a front lockright.
Rear diff is getting welded tomorrow.
I have already cut the drain plugs out of both axles. I still need to get some 3x2 inch 3/16 plate to weld in. I didnt feel like doing a full shave, just got rid of the plug and ring.
I ordered a small trailgear diff guard, a large diff guard, and some axle gussets. I have set of rat adapters coming from a user on here. I will order some yota poly spring bushings tonight.
I am going on a road trip to get some 36's and 15x10 rims next week.
Thats about it for now, I'll try to get some pics up tomorrow night. Maybe show the shaved yotas, but otherwise nothing too exciting yet.
88 Samurai, 104WB, Locked Up Yotas, 6.5's, 36's.
Chop and stretch: http://www.pirate4x4.com/forum/showthread.php?t=643403
I blew through two D60's ring and pinions, and three sets of superior shafts. I run 42" tsl's, and finally stepped up to a Cryo'd D30..... I will never look back
dabomb5756 is offline   Reply With Quote
Old 12-30-2007, 10:06 PM   #2
OKIE ZUK
OKIE ZUK's Avatar
Member # 14812
Going to 36's you'll also need to add 6.5 gears in the t-case. Good luck on your build. Looks like you've done your homework.
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc.
OKIE ZUK is offline   Reply With Quote
Old 12-30-2007, 10:16 PM   #3
dabomb5756
dabomb5756's Avatar
Member # 62837
Do you think even with 4.9's and 5.29 axle gears i will still need the 6.5's?
I am very happy with my 31's, 3.73's, and 4.9 gears. I actually wouldn't want to be much lower. I am at 66:1 now, and with 4.10's i'll be at 72:1. With 5.29's i will be at 94:1.
If i do a proportion of crawl ratio to tire size i get:
(66:1 / 31) = (x / 36) with x being a equal crawl ratio on 36's,
I get 76.6:1
So, i think 94:1 will be alright with the added weight of 36's?
Or is this method completely wrong?
Thanks.
Old 12-30-2007, 10:46 PM   #4
OKIE ZUK
OKIE ZUK's Avatar
Member # 14812
Do what you what. I may not know what I'm talking about.
Old 12-30-2007, 11:05 PM   #5
dabomb5756
dabomb5756's Avatar
Member # 62837
Well, looking at your sig, you are running 36's, 5.29s and a 6:1. EFI, i am guessing you have a 1.6, so you have a little more power.
How do you like your setup?
Old 12-30-2007, 11:09 PM   #6
OKIE ZUK
OKIE ZUK's Avatar
Member # 14812
No a stock '94 model 1.3. Ask anyone I wheel with if I don't have enough motor.
Old 12-30-2007, 11:17 PM   #7
Itsmejoe231
Itsmejoe231's Avatar
Member # 34828
Okie got plenty of motor. lol
Sorry we didnt get to wheel together at Clayton this weekend....
www.ZukiKrawlers.com
Itsmejoe231 is offline   Reply With Quote
Old 12-31-2007, 12:11 AM   #8
OKIE ZUK
OKIE ZUK's Avatar
Member # 14812
Joe, when did you leave Clayton?
Old 12-31-2007, 12:17 AM   #9
supazuk94
ZUK MODERATOR
supazuk94's Avatar
Member # 28426
Originally Posted by OKIE ZUK View Post
Going to 36's you'll also need to add 6.5 gears in the t-case. Good luck on your build. Looks like you've your homework.
I run 36's under mine w/ 5.14 tcase gears and 4.30 toys and mine goes just fine.....
but then again i have a 1.6 and a kicker 3
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
www.longfieldsuperaxles.com
www.kore4x4customs.com
www.DEEPWOODSEXTREME.com
supazuk94 is offline   Reply With Quote
Old 12-31-2007, 12:30 AM   #10
supazuk94
ZUK MODERATOR
supazuk94's Avatar
Member # 28426
for what its worth my 1.3 was quite strong too (94 efi also) I put the 1.6 to simplify the kicker install
-UZI 9mm
Old 12-31-2007, 08:12 AM   #11
HRDCRWLRZ
Member # 87618
5.29's, 6.5 t-case, 1.6l 16v, 36's, YJ springs. I extended the wb 12in at the rear.
HRDCRWLRZ is offline   Reply With Quote
Old 12-31-2007, 09:53 AM   #12
Valley Auto
CVB4X4
Valley Auto's Avatar
Member # 78079
Okie's right my stock 1.3 needs every bit of my 6.5's and my 5;89's to turn my 36"s even though the sidewall says 38.5
If i catch you littering in hollister hills SVRA I will find you and duct tape you and you trash in your tent...Why? Becuase samurai's are sneaky....
Valley Auto is offline   Reply With Quote
Old 12-31-2007, 12:38 PM   #13
Itsmejoe231
Member # 34828
We left about 11:30 AM Sunday.
Old 12-31-2007, 12:49 PM   #14
OKIE ZUK
OKIE ZUK's Avatar
Member # 14812
Old 12-31-2007, 05:03 PM   #15
dabomb5756
dabomb5756's Avatar
Member # 62837
Well crap....
Owell. We'll see what happens...
On with the build.
Got the zuk axles torn apart, both diffs packaged for shipping and got the rear bumper packaged. I already sold that stuff.
I made a couple trips to the barn and back to get all my tools there, and now i am waiting for stuff i bought to show up.
Tomorrow i will prolly burn out the spring bushings out of the yota springs, and get some steel plate and rectangle tube if the supplier is open.
I might also finish prepping the yotas. I have cut everything off them, i just need to grind some of the nicks down and get them prepped for paint.
Old 12-31-2007, 05:16 PM   #16
Blind Driver
Blind Driver's Avatar
Member # 29177
Either you have a bank of batteries or a really long extension cord
Originally Posted by Roxywheels View Post
If Chuckie is pm'ing, that means he signed up under another name and even if Camo might possibly have reconsidered his decision, he won't now because he totally fucked himself. You may want to pass that on to him.
I don't give him coming back any thought at all.
Blind Driver is online now   Reply With Quote
Old 12-31-2007, 06:25 PM   #17
OKIE ZUK
OKIE ZUK's Avatar
Member # 14812
Old 12-31-2007, 06:32 PM   #18
dabomb5756
dabomb5756's Avatar
Member # 62837
I know my stuff isnt that exciting yet,
but....
get all your stuff out of my thread!
haha
Old 12-31-2007, 06:38 PM   #19
OKIE ZUK
OKIE ZUK's Avatar
Member # 14812
Fine, I'll leave.
Old 01-01-2008, 04:51 PM   #20
purevil71
purevil71's Avatar
Member # 9275
Send a message via Yahoo to purevil71
I'm running a GRS II T-case with 5.29's on 36" tires with a weak a$$ed 1.3, and it does pretty good.
BUT, for the price, you can't beat the deal on the 6:1's!!!
"Just when I think you've gone and said the stupidest thing ever, you keep on talking!"
___________________________________
'88.5 Sami based buggy
'73 Suzuki LJ project
'92 Sidekick (project: Family Wheeler)
purevil71 is offline   Reply With Quote
Old 01-02-2008, 09:51 AM   #21
LostZuk
Member # 88667
Send a message via MSN to LostZuk
I ran 36's with the 6.4 and 5.29's for a little while and then upped them to 38's and I am happy, but I alos run a 1.6L
I do not have a problem with insanity, I am quite comfortable with mine!
LostZuk is offline   Reply With Quote
Old 01-04-2008, 05:17 PM   #22
dabomb5756
dabomb5756's Avatar
Member # 62837
Well heres and update of the past week or two.
Got tires and rims from chicago area:
Heres the samurai as it sits in the barn:
And the mobile workshop in my backyard haha. It has axle and stuff on it because i cant keep this stuff in the garage for more than a day:
I picked up 8 beadlock discs for 50 bucks. I dunno if they will work right, but the price was right:
Drain plugs cut and replaced:
Pretty Smooth:
Otherwise, i got the rear carrier out and got the ring gear off. I am going to a buddies house to weld it up with his arc welder.
I picked through the garbage at a steel yard and got a ton of free plate for spring mounts, gussets, tabs, whatever. Sizes ranging from 1/8-3/8 thick stuff. I also got some nice 2x2 square for a crossmember for the traction bar. I still need to order my 2x4 tubing for the frame stretch and rear bumper/shackle mount.
I also still havent gotten the darn spring bushings out of the yota springs, hopefully i will do it tomorrow. The poly bushings did come today.
Otherwise, i am still waiting on stuff to get shipped in. Hopefully alot of it comes tomorrow. Then i can get the axle gussets welded on, axles painted, and totally back together by monday.
One question though...
When taking the yota ring gear off, there is a metal peice between each set of two ring gear bolts. It has tabs on it bent up to keep the bolts from loosening. Do you guys reuse these things? I was just going to use locktite.
Also, does anyone know the torque specs on ring gear bolts and bearing cap bolts?
THanks guys!
Old 01-05-2008, 08:27 PM   #23
97tj500ft
Rowdy Jeepers
97tj500ft's Avatar
Member # 92984
All this work and $$ and your shit still won't be as bad ass as a JEEP! Even a Compass! Next time we go to the Badlands I will bring my son. That way he can play around with your shit and you can ride with me.
97tj500ft is offline   Reply With Quote
Old 01-05-2008, 09:32 PM   #24
dabomb5756
dabomb5756's Avatar
Member # 62837
Hahah ft, i knew you would have something productive to say!
At least i build my shit sucka
Old 01-06-2008, 05:38 AM   #25
97tj500ft
Rowdy Jeepers
97tj500ft's Avatar
Member # 92984
Yes you do. Sounds like you have done plenty of research and an awsome game plan. Can't wait to see your beast finished. Let's get real, what are your plans when finished? After what that thing could do on 31's your just going to get in trouble with 35's. Too bad your not closer, I would come and help. It would be nice being the helping hand recieving direction for a change. Good luck.
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
