Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 05-14-2008, 06:56 PM   #1
yield2me
yield2me's Avatar
Member # 3196
My new buggy
After 10 months and too much $$$ finally finished it. Its a little dirty from riding this weekend. And broke (six shooter arm broke off where it goes into the trunion bearing.
Ultra4 Team 4406
"Usually last, but Usually there"
Thanks to our Sponsors!!
Performance Off-Road
Final Touch Powder Coating
Trail Tough
Heiseroil.com
Southeast Marine and Rescue, Inc.
yield2me is offline   Reply With Quote
Old 05-14-2008, 06:58 PM   #2
yield2me
yield2me's Avatar
Member # 3196
Ultra4 Team 4406
Trail Tough
Heiseroil.com
Old 05-14-2008, 07:01 PM   #3
4rnr
4rnr's Avatar
Member # 34860
Nice
How the hell did you shear that arm and leave the trunion in such good shape??
92 4rnr 3.4 auto duals 37" PBR's
88 4rnr 3.0 stick soft top 33's stock
4rnr is offline   Reply With Quote
Old 05-14-2008, 07:01 PM   #4
yield2me
yield2me's Avatar
Member # 3196
more
Ultra4 Team 4406
Trail Tough
Heiseroil.com
Old 05-14-2008, 07:04 PM   #5
Bigger Valves
Member # 3483
Looks good, Rob. It was good to meet ya'll this weekend. Hopefully the next time this event comes around I'll have my real rig ready. Either way, I still had a good time this go round. Get that arm fixed up and keep flogging the thing!
Benny
'87/350/350/205/60/60/linked/locked/lowered the Aerotoy
Bigger Valves is offline   Reply With Quote
Old 05-14-2008, 07:04 PM   #6
yield2me
yield2me's Avatar
Member # 3196
Last ones
Never mind that rats nest of wires on the driverside under the dash. Thats where my ARB is and I was troubleshooting why it wont build pressure.
Ultra4 Team 4406
Trail Tough
Heiseroil.com
Old 05-14-2008, 07:08 PM   #7
yield2me
yield2me's Avatar
Member # 3196
Originally Posted by 4rnr View Post
Nice
Good question....It pushed the knuckle over into my ball gusset, which jammed the Long up and would not let the wheel turn (i.e. roll; drive flanges). Thus........DNF.
Benny.....Sorry your luck was worse than ours!! About where u crashed, my P/S belt went out and I couldnt turn very good.
Rob
Ultra4 Team 4406
Trail Tough
Heiseroil.com
Old 05-14-2008, 07:09 PM   #8
apeters89
Moderator
apeters89's Avatar
Member # 7647
nice looking rig!
KF5EQF
Chasing the Pink
In the Pink Racing
Buy my car
apeters89 is offline   Reply With Quote
Old 05-14-2008, 07:13 PM   #9
yield2me
yield2me's Avatar
Member # 3196
BTW- Since I am such a Lemming, I made it look like a King of the Hammers rig!! (Mustard Dog is my Hero!!)
Light bar, rear facing amber, Lowrance GPS, Iroks, etc.
Of course, if I cant finish a 2.5 mile race, what makes me think I could finish a 50 mile race!
Thanks for all the comments guys.
Rob
Ultra4 Team 4406
Trail Tough
Heiseroil.com
Old 05-14-2008, 07:13 PM   #10
VXRICH
I AM THE FAT KID
VXRICH's Avatar
Member # 42064
Wow were the studs not tight? That broken Six shooter was not what I wanted to see I just put mine on.....
Richie
VXRICH is offline   Reply With Quote
Old 05-14-2008, 07:16 PM   #11
yield2me
yield2me's Avatar
Member # 3196
Studs were tight...PM sent
Ultra4 Team 4406
Trail Tough
Heiseroil.com
Old 05-14-2008, 09:22 PM   #12
F-550
Member # 90703
Bad ass rig dude. How bout some numbers on that thing? Width, Length, hieght, ride hieght, wheel base? Some more pics to..Thanks...
Hurray 4 2day Fuck 2morrow
Tow Rig--2004 F250 Lariat 4x4 Crew Cab 6" Donahoe Racing lift, 37" Pro Comp X-terrains, Airaid intake,4" MBRP Exhaust turbo back, Autometer gauges, Bully dog power pup.
F-550 is offline   Reply With Quote
Old 05-14-2008, 10:17 PM   #13
yield2me
yield2me's Avatar
Member # 3196
Specs from zuwharrie.com write up...
Main Vehicle Specs
Chassis- 2007 Usnick Motorsports "Draeger" Chassis #001
Motor
1.6 8v with GSXR carbs
K&N Filters
GM alternator
DT Header
2” exhaust system with performance cat
Hawk cam
MSD 6AL
MSD Blaster coil
MSD Super Conductor wires
Redtop Optima
Driveline
RRO 6:5 Transfer case with custom poly mounts
Twin Sticks
Centerforce Dual Friction Clutch
Toyota Minitruck axles 5.29 R&P
30 spline Longfields
6 shooter knuckles with arp studs
Trail-Gear drive flanges
Trail Gussets
Marlin Crawler ball gusset kit
Front and Rear ARB Lockers
Trail-Gear front 12" slip yoke and Rat Adapter
Rebuilt Toy CV shaft with Rat Adapter
Cutting Brakes
Steering
Trail Gear High Steer (Switching to full hydro now)
PSC Pump
Spidertrax ps pump bracket and pulley
Toy IFS gear box (Gone)
Suspension
Modified RRO front 3 link with Panhard bar
Modified RRO rear wishbone
2" x .250 lower links
15" Rancho Coilovers w/in cab control
Tires/Wheels
42" Irok Stickies
17x9 Trail Gear Creeper Locks
2 inch aluminum wheel spacers
Interior
Autometer tach, speedo, fuel, volt, temp, oil pressure
Lowrance Globalmap Baja 540c GPS
Sony am/fm/cd/mp3 with Marine speakers
Corbeau Seats
Recovered rear Zuk seat
4 pt harnesses for everyone
Master kill switch
12voltguy.com 10 switch panel
Exterior
Gloss Black powder coat by Final Touch Powder Coating
Zuk hood
Rock Lights
Light bar
Rear facing Amber
Recovery gear
Warn XD 9000i winch
Aluminum Fair lead
Winch rope
Fire extinguisher
First Aid kit
Miscellaneous
Rear suck down winch
Custom 6.5 gallon fuel cell
Height-74"
Belly-23"
Wheelbase-104"
Weight-#2720 (1660 F/1060R)
Width-75"
Ultra4 Team 4406
Trail Tough
Heiseroil.com
Old 05-14-2008, 11:24 PM   #14
madmonk
Member # 37684
looks like you got it running fri night, what was the problem? BTW good seeing you again, and nice rig.
scott
[url]www.muddevils4x4.com[/url]
madmonk is offline   Reply With Quote
Old 05-14-2008, 11:35 PM   #15
intheworks
Member # 80590
the rig looks really good! for some reason i like the light bar. if you ever wanted to or ever have problems, you could make your driveline a lot stronger for not much $$ at all. my suggestion would be run stock 4:10 R+P in the diffs and get a yota dual case set up, with 4:7's in the rear case. then you'll be just as low as you are now but have much stronger diffs and t-case's. ive seen a lot of toyota 5.29's give way with 37's and your running 42's........ so id say its a matter of time.
intheworks is offline   Reply With Quote
Old 05-15-2008, 05:24 AM   #16
yield2me
yield2me's Avatar
Member # 3196
scott
Dude, you wont fawking believe it. The coilwire was grounding out on the distributor cap retainer clips. I got it done at midnight.
Rob
Ultra4 Team 4406
Trail Tough
Heiseroil.com
Old 05-15-2008, 06:21 AM   #17
TachedOutOffRoad
wanna be FToy buildr
TachedOutOffRoad's Avatar
Member # 75648
NICE!!! 42" Stickies on a light rig like that should be just awesome!
More pics!!
TACOMA BED, CAGE, AND 3RDS FOR SALE
FToy#40, the F-Limo
Ultimate East Coast Places to Go
TachedOutOffRoad.com
TachedOutOffRoad is offline   Reply With Quote
Old 05-15-2008, 11:21 AM   #18
Longfield
Longfield's Avatar
Member # 15061
Nice rig. 42 inch stickies thats what i run on my Dana 60s. I think to big of tires for toyota running gear. When we don't recommend anything over 39.5.
MADE IN THE USA!
WWW.LONGFIELDSUPERAXLES.COM
ORDER LINE TERRA 360-893-0235
24 HOUR TECH LINE 253-847-8254
FREE SHIPPING!
World's Best Customer Service & 24 Hour Tech Line!
Longfield is offline   Reply With Quote
Old 05-15-2008, 11:54 AM   #19
yield2me
yield2me's Avatar
Member # 3196
I hear ya Bobby, but with ARB's I can unlock the diff if its looking bleak. There are guys running rear steer Toy's (some with v-8s) with 42's around here and they are surviving. Its not your shafts I am worried about anyway!
Rob
Ultra4 Team 4406
Trail Tough
Heiseroil.com
Old 05-15-2008, 03:46 PM   #20
74_Chevota
Member # 12991
Send a message via AIM to 74_Chevota
This rig is bad. Saw it at Uwharrie Cross after they broke and wish i could have seen it in action. I did offer up generiously to trade my non-sticky iroks for the stickies to take some strain off that front end.
07' FJ buggy: D60,14bolt-40" Maxxis-5.3L-Stak-chromo'ed
Psalms 34:1-3 <><
74_Chevota is offline   Reply With Quote
Old 05-15-2008, 04:50 PM   #21
purevil71
Member # 9275
Send a message via Yahoo to purevil71
Sweet rig. You should bring it up to ZukiMelt at the Badlands in July. Would love to see it in person.
"Just when I think you've gone and said the stupidest thing ever, you keep on talking!"
___________________________________
'88.5 Sami based buggy
'73 Suzuki LJ project
'92 Sidekick (project: Family Wheeler)
purevil71 is offline   Reply With Quote
Old 05-19-2008, 08:37 PM   #22
yield2me
yield2me's Avatar
Member # 3196
So is Zukimelt the 10-12 or 24-26 of July? Since I am an East coaster, I try to do the Zu, but if its the 10-12, that is a weekend we can probably do it.....
Rob
Ultra4 Team 4406
Trail Tough
Heiseroil.com
Old 05-20-2008, 06:46 PM   #23
dabomb5756
Member # 62837
10-12, and yea it would be awesome to see your rig in action.
88 Samurai, 104WB, Locked Up Yotas, 6.5's, 36's.
Chop and stretch: http://www.pirate4x4.com/forum/showthread.php?t=643403
I blew through two D60's ring and pinions, and three sets of superior shafts. I run 42" tsl's, and finally stepped up to a Cryo'd D30..... I will never look back
dabomb5756 is offline   Reply With Quote
Old 05-26-2008, 05:36 AM   #24
53guy
RokHmpr
53guy's Avatar
Member # 77930
Saw your rig at the race, super clean looking, sorry to hear you DNF, we barely did with no brakes after some jumping action.
53guy is offline   Reply With Quote
Old 06-02-2008, 10:16 AM   #25
WVJeepBuilder
WVJeepBuilder's Avatar
Member # 56276
Send a message via AIM to WVJeepBuilder
I hear that you and this rig are coming to WV July 4th weekend? if so I look forward to meeting you and checking this beast out!
www.Myspace.com/RLoftis2
WVJeepBuilder is offline   Reply With Quote
Forum Jump
