#1 |
700R4 to LS1
easy question, what year 700r4 and what vehicle (that the trans came out of incase you didnt understand the question) should i be looking for in order to bolt this trans to a LS1
2009 Twisted Customs buggy -----2008 BMW 335i coupe -----2004 Duramax 2500 CC |
#2 |
Member # 33482
Lets assume a 700R4 will bolt up to a LS, pick a year, there all the same bolt pattern.
In case you didn't understand the answer. All 700R4 have the same bolt pattern.
blah blah blah...... |
| Sponsored Links |
#3 |
Member # 3775
Wrong, there are 2 common 700r4 bolt patterns, 60deg v6 and 4.3/v8.
You need one that came behind a 4.3 or V8, that's any number of chevy trucks, s10s, blazers, suburbans, camaros, and full size cars. The 4x4 v8 ones have stronger cases and internals.
1995 S10 SAS and stuff 1999 Yamaha R6 |
#4 |
Member # 15461
I'll sell you one that will work perfect for you, it just needs a rebuild.
#5 |
sucks tryin to be a smart ass back and being told your wrong haha
#6 |
From '85 to '87 there was a large input shaft version, which has the same spline as a 350 trans.
http://www.technicalevolution.com/700r4.htm
:shaking: |
#7 |
HEAD BAKER, AND COOK
Member # 113951
the LS1 or GEN III motors run a 4L60E or a 4L65E behind them. electronic transmission. we put a 700R4 behind a LS1 and it was a pain to get the tv cable hooked up. (kick down/throttle pressure) we couldnt get the right pull out of the cable. we put a fullmanul valvebody in it and have never had a problem .................
#8 |
AKA "BONDO"
Member # 9252
IIRC its not the bolt pattern that is the issue it the flex plate and a spacer for the Torque Converter. at least this was what we needed for the 6.0 L to TH350 in the buggy so I guess as long as you have the 90* V8/4.3 V6 pattern your golden. also didn't the 700R4 have a lock up converter so that would need to be addressed as well. I am sure the have non lock up as well.
Hope this helps
ANY SEVEN OFFROAD San Leandro Ca Winchline, Parts and Service DP4x4 RIP RYAN (Wicked Fabrication) "Safety is our # 2 concern" Rage 4th Bay Cities Metal Fabrication & Design website comming soon AnySevenOffroad.com comming soon Last edited by RockChump; 05-15-2008 at 04:45 PM. |
#9 |
Member # 113951
thats right we get a spacer from advance adapters #716155a crank bushing. art carr builds an extension on the crank pilot of the converter. you also have to watch the torque converter holes. if you use a 700R4 or 4L60E, thm350 the holes will fit the camaro flexplate, you have to drill for a thm400 converter, not a great idea, tci has a dual drilled flex plate 399753 comes with spacer also ..................
#10 |
what trans would you run then behind a ls1 in a buggy?
#11 |
Member # 22653
TH400 or Built TH350
Uh.... |
#12 |
Member # 62561
For you guys running the LS V8's and T350-T400. Are you running the VSS and how are they running?
69 Scout 800, 60F,14bolt,6.0 LQ9/T400/Atlas4.3,39.5 Swampers, 2001 Dodge CTD 6Spd H.O, 4x4, 1965 Unimog [SIZE="4"]"If your buddie was shot in the ass with diamonds, coils and 4 link would be the way to go IMO." [/SIZE] |
#13 | |
Member # 33482
But hey thanks for your insightful knowledge that wont mean dick if he doesn't figure out how to control it. ![]() Now I am poking a little fun at you. ![]() To the original poster, if your after the 700R4 because of the 4th gear (overdrive), then a better option is a 4L60E or 4L80E. The 4L60E is the electronically controlled version of the 700R4 and if you get one after '98 or so it will have the removeable bellhousing. Regardless of donor vehicle, the internalls can be beefed up to handle the power/torque of your engine and tires, up to about 450ft pounds of torque. Plus with the electronics it will be easoer to control and make the torque converter lock up function while on the interstate. Without lock up you will fry the tranny on the interstate. Would mister smark alec like to explain the difference in bolt pattern between the LS1 and a standard 350 V8 blcok? Would he also like to explain the reason you need a different flex plate or spacer? There is more to it then bolt pattern. Sorry, poking a little more fun. :biggrin
blah blah blah...... Last edited by Hanr3; 05-16-2008 at 07:26 AM. |
#14 | |
Member # 22653
I also haven't used a spacer or a different flex plate (just used the one from the 5.3), but hey I'm not smart.
Uh.... |
#15 |
Member # 33482
Shhh,
seeing if he knows that.
#16 |
Member # 33482
Hint:
www.summitracing.com LS1 - 700R4 Crank Adapter $34.95 Part#: HP3795 LS1 - 700R4 Flexplate $129.95 Part#: HP4004 Manual valve body in the tranny and Summit also sells kits to lock up the torque converter. I am not aware of a kit to make the TV cable work. Not saying it doesn't exist, just that I am not aware of it. Hence the manual valve body. The 700R4 will bolt up to the LS1, except for one bolt, leave it out.
#17 |
Member # 15461
prostock, I have one of the later versions of the 700r4 which has the most upgraded internals, it was in a suburban. alumcj is putting one behind an LS1 also, when he gets it running you should see what bugs he ran into.
#18 |
Member # 13688
Its going to work flawless i hope. Its bone stock, and im going to run it that way at first. See how i like the shifting and such before i dump money at it.
Its only an afternoon to swap a trans out - no big deal.
LCQ / KOH 10 here I come. |
#19 |
ok how about this, since i already have a 4l60e 2wd trans, could i swap like a tailshaft or something to set it up for 4wd? or stick with fuckin around w/ 700r4?
#20 | |
Member # 6208
yeah the shafts are interchangable. If you run the 4l60e... What type of transfer case are you going to run? You're going to need a VSS for that trans to shift. (or run a Compushift) |
#21 |
Ill be running an atlas, whats a vss..im going to use the factory computer and such for it..would i still need the vss or compushift?
#22 | |
Member # 3775
1995 S10 SAS and stuff 1999 Yamaha R6 Last edited by Jeffh555; 05-16-2008 at 11:50 AM. |
#23 |
lets get back to what i asked
#24 | |
Member # 6208
#25 |
Member # 8459
Is it just me or is this guy a huge douche? I know you keep sayin' that you're just pokin' fun but seems like you're just tryin' to boost you're own ego. Folks come on here to looking for answers, thanks for the good tech you shared, ease up on the assitude.
SAVE JOHNSON VALLEY POST #1430 '78 FJ40 Project:"My 1st love"-in progress. Almost Done!! |
| Thread Tools | |
| Display Modes | |
