#1 |
Bomber Fab
Member # 3069
Randy Built, Bomber Chassis for KOH
This thread is the build up of my buggy. It will be used for general hammers wheeling as well as racing in the King of the Hammers 2009.
Here is a short list of specs. LS1 4L60E Atlas 4spd Spider 9 with HI 9 in the front Spider 9 with Strange 35spline rear 42" Irocs on Walkers wheels The rear suspension will have 20" of vertical travel. 12 1/2" of that is up from ride with 4" of air bump travel. The front cycles 16 1/2". 8" of up with 4" bump All that with a 18-19" belly.
Thanks for the support Howe Performance CTM Racing High Angle Driveline Bulldog Winch Spider Trax Superior Axle and Gear BFG Tires Walker Evans Racing Bomber Fabrication is now open for business. Last edited by Randy; 02-02-2009 at 01:01 PM. |
#2 |
Bomber Fab
Member # 3069
Here are some pics of the design Dustin and I drew up.
Thanks for the support Howe Performance CTM Racing High Angle Driveline Bulldog Winch Spider Trax Superior Axle and Gear BFG Tires Walker Evans Racing Bomber Fabrication is now open for business. |
| Sponsored Links |
#3 |
Bomber Fab
Member # 3069
Here are pics of the rear suspension and rear end
Thanks for the support Howe Performance CTM Racing High Angle Driveline Bulldog Winch Spider Trax Superior Axle and Gear BFG Tires Walker Evans Racing Bomber Fabrication is now open for business. Last edited by Randy; 08-06-2008 at 08:37 PM. |
#4 |
Bomber Fab
Member # 3069
More progress pics
#5 |
Bomber Fab
Member # 3069
More
#6 |
Moderating Midget
![]() Watch out boys.....my money is on this one.
Nolen Grogan CottonLand Cruisers www.rockmidgetphotography.com blacksheep4x4.com USAF Veteran 1988-1998 GOD Bless America |
#7 |
Bomber Fab
Member # 3069
Here is a little header tech. I make the collector die from four chunks of 1 3/4 solid bar. I welded them together and turned them down to a cone in my lathe. Then I used my press to form 3" tubing over the die.
#8 |
Bomber Fab
Member # 3069
Here is the first header mocked up on the motor, and a pic of how I seal the four tubes inside the collector.
Thanks for the support Howe Performance CTM Racing High Angle Driveline Bulldog Winch Spider Trax Superior Axle and Gear BFG Tires Walker Evans Racing Bomber Fabrication is now open for business. Last edited by Randy; 09-18-2008 at 12:13 AM. |
#9 |
Member # 14059
shit hot
#10 |
Bomber Fab
Member # 3069
with the collector on and all welded up.
#11 |
Member # 47428
money's on this on for sure.
Dont worry, It's just a sammy! 87 Tintop cut to shit Low Rider, 4.3 TBI, 700R, 203/205 Doubler, Dana 44 HD Front, Dana 60 FF Rear, DOM Cage, Front & Rear 3 Link on Coils, 37 Xterrains eccentric r/c - Everything R/C for less - Free Shipping
eccentricrc.com |
#12 |
Member # 72877
Nice work!!! looks SICK!!!
321 EOR Chassis buggy, 302/c6/stak, rockwells 47 LTB's!!!! |
#13 |
Bomber Fab
Member # 3069
Here are some pics of the boxed cromo plate high steer arms I made.
#14 |
Banned
Member # 2032
Nice work Randy, you make it look easy.
#15 |
K^2
Slinky Blue Ballz http://www.pirate4x4.com/forum/showthread.php?t=551947 SLINKY BLUE BALLZ FOR SALE: http://pirate4x4.com/forum/showthread.php?t=859440 |
#16 |
more please
Mike Yager Current Build - Jeep TJ - http://www.pirate4x4.com/forum/showt...php?p=10862387 |
#17 |
Bomber Fab
Member # 3069
heres a shot with both headers on. then we go to the steering. With such a bling steering ram you know the mounts have to be bad
Thanks for the support Howe Performance CTM Racing High Angle Driveline Bulldog Winch Spider Trax Superior Axle and Gear BFG Tires Walker Evans Racing Bomber Fabrication is now open for business. Last edited by Randy; 08-06-2008 at 10:34 PM. |
#18 | |
BUILT XJ AND YJ THERE IS ALWAYS A CHEAPER YET STILL EFECTIVE WAY TO DO ANYTHING |
#19 |
my only question is how durable do you think the fabed arms will be
i know this style of arms and such are popular in desert racing looks rediculously awsome
#20 |
Bomber Fab
Member # 3069
here is a shot of the front upper shock mount, more steering pics and front lower link mount at the axle.
#21 | |
Bomber Fab
Member # 3069
I think they will be fine. They are double sheer. I think the main reason we only see 1" thick arms is because they are single sheer and they cost less to make.
#22 |
Family Man
Member # 21320
One day I want to be able to weld like you
![]() Looking forward to your progress |
#23 |
Hardline Crawler
Member # 36746
Damn you have skills man, look fwd to seeing this one finished up
Matt O. 2009 KOH Racer Essentially Offroad, BFGoodrich, PSC, Bilstein, Grote Lighting, PRP Seats and Winchline.com |
#24 |
I think they will be fine as well, the only thing I would have done differently is to taper the tube sleeves through them and use tapered nuts. I don't know how accurate the cost less to make comment is though. They cost less based on what?
Building shit.....sometimes even for myself! |
#25 |
______________
You should clearcoat all these parts.
______________________ Americans for America
| Thread Tools | |
| Display Modes | |
