Pirate4x4.Com Bulletin Board
Old 08-08-2008, 08:03 PM   #1
patooyee
Pirate4x4 Addict!
patooyee's Avatar
Member # 4821
Links to GM LSx Engine Questions & Info
During all these recent Gen III & IV threads someone mentioned that we should have an LS bible thread and since I am currently going through a learning curve about my new LS2 engine, I figured it might be a good time to start the LSx Bible thread, or whatever you would like to call it. Kind of like TheRipper's rockwell thread. (Which was my bible when I was learning about my rocks.)
I'm not going to police this thread and keep it current every time some LS info comes up like TheRipper does the rockwell thread. I just dont' have the time or patience. But I'm sure that people here will do it for me as they seem to be doig for TheRipper in that thread.
I'd like to keep the trash out of here as much as possible. It seems like every time someone even mentions LS people start talking about what is better, worse, how you could spend equal amounts of money and get more power with other engines, etc. Everyone has their $0.02 and if we put it all in here we'll have about $1,983,004.06. That being said though, unfortunately, that BS clouds some good info threads, so I understand that it will rear its ugly head at least a little.
Also, I know there are great threads on other boards so feel free to link to them. I know ls1tech.com and others have to have some amazing info. I just haven't had the time or courage to dive headlong into those yet.
I'll start out with what I've found so far that has been informative:
Fuel pump and fitting info:
http://www.pirate4x4.com/forum/showt...t=ls+fuel+pump
Great drive-by-wire info:
http://www.pirate4x4.com/forum/showt...=gm+drive+wire
Some more DBW info and info on converting from DBW to cable throttle:
I haven't even begun intensive searching yet so expect more and feel free to add whatever you have found useful.
Finally, if something like this already exists, sorry to waste your life. I'l delete it if it exists here already.
J. J.
www.patooyee.com
Build thread
patooyee is offline   Reply With Quote
Old 08-08-2008, 08:28 PM   #2
mudbug660
mudbug660's Avatar
Member # 85902
Stroke: 4.8 = 3.27". 5.3, 5.7, 6.0 = 3.622"
Rod : 4.8 = 6.278". 5.3, 5.7, 6.0 = 6.098"
from performancetrucks.net
1950 cj3a 5.3,465,205,44,14,40"
[url]http://pirate4x4.com/forum/showthread.php?t=762319[/url]
mudbug660 is offline   Reply With Quote
Old 08-08-2008, 09:17 PM   #3
RaceMoab#42
Outlaw Rock Racing
RaceMoab#42's Avatar
Member # 90867
Wiring Pin diagrams that ls1toyota posted in a thread of mine a while back
Name:  ls pin diagram.jpg
Outlaw Rock Racing, XRRA cars #42 and #21..
XRRA 7th place western division
JIMMYS4X4.COM
MOAB4X4OUTPOST.COM
MAXXIS.COM
RaceMoab#42 is offline   Reply With Quote
Old 08-08-2008, 09:20 PM   #4
RaceMoab#42
Outlaw Rock Racing
Member # 90867
more
Name:  ls pin diagram2.jpg
Size:  57.3 KB Name:  ls pin diagram3.jpg
Name:  ls pin diagram4.jpg
JIMMYS4X4.COM
MOAB4X4OUTPOST.COM
MAXXIS.COM
Old 08-08-2008, 09:21 PM   #5
patooyee
Pirate4x4 Addict!
patooyee's Avatar
Member # 4821
Good info but is there a larger file or anything? I can't read that. Possibly a link to the thread?
J. J.
www.patooyee.com
Build thread
Old 08-08-2008, 09:35 PM   #6
RaceMoab#42
Outlaw Rock Racing
Member # 90867
Unfortantly the original thread has the same size pictures. Maybe ls1toyota has a larger file. I had to use my wives reading glasses to read it
JIMMYS4X4.COM
MOAB4X4OUTPOST.COM
MAXXIS.COM
Old 08-08-2008, 09:39 PM   #7
patooyee
Pirate4x4 Addict!
patooyee's Avatar
Member # 4821
Looks like he got them from alldatadiy.com. You have to have a subscription to get them, which may be worth it, but judging by the demo the paid versions are not much better.
J. J.
www.patooyee.com
Build thread
Old 08-08-2008, 09:51 PM   #8
RaceMoab#42
Outlaw Rock Racing
Member # 90867
LS engine dimensions
JIMMYS4X4.COM
MOAB4X4OUTPOST.COM
MAXXIS.COM
Old 08-08-2008, 10:02 PM   #9
patooyee
Pirate4x4 Addict!
patooyee's Avatar
Member # 4821
Some info ont he steam port:
http://www.pirate4x4.com/forum/showt...&highlight=ls1
J. J.
www.patooyee.com
Build thread
Old 08-08-2008, 10:03 PM   #10
Lil'John
Member # 278
Three bits of data from the fuel post above that I recently used/ordered.
Later vortecs(2004+) went to single line in.
In that case, using a late model corvette fuel filter helps and has built in fuel regulator. ACDelco P# GF822. Bad news is the outlet side uses one of the quick clip fittings So you either need to cannibalize a car to get that fitting or be lucky to have a flaring tool to do that style
To convert from the clip on fittings of the fuel rails to AN fittings, you can use Russel fittings:
P#640860 5/16" return line
P#640850 3/8" pressure side
I needed one of the 5/16" fittings for return line of fuel filter. I needed two of the 3/8" fittings: one for the pressure side of the fuel filter and one for the pressure side of the engine.
Pictures can be provided as I have them here boxed still.
Lil'John is offline   Reply With Quote
Old 08-08-2008, 10:12 PM   #11
patooyee
Pirate4x4 Addict!
patooyee's Avatar
Member # 4821
I don't understand ... you say that you have to cannibalize a car or have a flaring tool but then in the next sentence list a fitting. Please explain ...
J. J.
www.patooyee.com
Build thread
Old 08-08-2008, 10:19 PM   #12
mikey_d05
Unoriginal
mikey_d05's Avatar
Member # 46588
Send a message via MSN to mikey_d05
The fittings are $15 each if you don't have an OEM hose that will work. Quick connect means no flare tool is going to magically turn a steel line into something that will work.
5/16" q/c fitting, $15.39 at Summit:
Tech Articles: 4x4mecca.com
Kickass Parts at a Kickass Price: DIY4X.com
Buy My Beretta CX4
mikey_d05 is offline   Reply With Quote
Old 08-08-2008, 10:25 PM   #13
patooyee
Pirate4x4 Addict!
patooyee's Avatar
Member # 4821
Gotcha. So you're saying it'd be cheaper to flare a factory hose and make that work but the fitting is a good option given the lack of the factory hose ...
J. J.
www.patooyee.com
Build thread
Old 08-08-2008, 10:46 PM   #14
HardcorewannabeXJ
HardcorewannabeXJ's Avatar
Member # 84593
Send a message via AIM to HardcorewannabeXJ Send a message via MSN to HardcorewannabeXJ
Here is some LSX Tech j/k
Time for BAJA
HardcorewannabeXJ is offline   Reply With Quote
Old 08-08-2008, 11:00 PM   #15
silveradoreb
silveradoreb's Avatar
Member # 37431
LS Oil pan info with pictures and dimensions.
http://www.ls1tech.com/forums/showthread.php?t=817787
silveradoreb is offline   Reply With Quote
Old 08-08-2008, 11:27 PM   #16
Lil'John
Member # 278
More appropriately, a cheap flaring tool will not make something that works
Picture shows the resulting flare from a Mastercool flaring tool(P#71475) I flipped out today... think $200 and change for the tool
Old 08-09-2008, 01:46 AM   #17
BadLuck
Member # 94571
Wiring diagrams:
http://www.ls1tech.com/forums/showthread.php?p=9786890
BadLuck is offline   Reply With Quote
Old 08-09-2008, 06:46 AM   #18
ohfck
ohfck's Avatar
Member # 22653
Orilley's Auto parts have fittings that connect to the quick connect and provide a flared end for an easy hose connection. They are in the "Help" section.
Buy my Bronco!!
http://pirate4x4.com/forum/showthrea...392&highlight=
ohfck is offline   Reply With Quote
Old 08-09-2008, 07:04 AM   #19
THachiya
Member # 47888
The cheaper alternative is the Dorman 800-155 3/8" x 12" fitting (~$9) with a double bead on both ends. Cut it in half and a)use a compression fitting to attach it to your fuel line and b) it will slide into the Russell and/or GM connectors. (The 5/16" is 800-154)
Here is a link to the Dorman catalog with their fuel fittings: http://www.dormanproducts.com/docume...uyersGuide.pdf
Good Luck!
WTF-J - WTF gives you freedom. Freedom brings opportunity. Opportunity makes your future.
THachiya is offline   Reply With Quote
Old 08-09-2008, 07:08 AM   #20
mudbug660
mudbug660's Avatar
Member # 85902
http://lt1swap.com/2000harness.htm
Here's some pictures and discriptions of the fuse block wiring for around a 2000 model 5.3. It also has pinouts for 99-2006 chevy trucks in a link on his page. It tells you what each wire goes to, it's function, and whether you need to keep it or not when doing a swap.
Old 08-09-2008, 08:01 AM   #21
patooyee
Pirate4x4 Addict!
patooyee's Avatar
Member # 4821
Originally Posted by HardcorewannabeXJ View Post
Here is some LSX Tech Blown LSx Block with a couple bottles just in case, in a new corvette :smoking:
Thanks for the useful info.
J. J.
www.patooyee.com
Build thread
Old 08-09-2008, 09:47 AM   #22
Fl-Krawler
Fl-Krawler's Avatar
Member # 47337
LS alternator relocation bracket to move it to the passenger side cylinder head.. http://www.speedinc.com/cont.cfm?cid=C0000801
Fl-Krawler is offline   Reply With Quote
Old 08-09-2008, 03:43 PM   #23
spaggyroe
Member # 17950
Trouble codes for 98 + LS1/LS6
http://www.hotrodlane.cc/ONLINETECH/lserrorcodes.htm
P0101 MAF System Performance
P0102 MAF Sensor Circuit Low Frequency
P0103 MAF Sensor Circuit High Frequency
P0106 MAF Performance
P0107 MAF Sensor Circuit Low Voltage
P0108 MAF Sensor Circuit High Voltage
P0111 IAT Sensor Performance
P0112 IAT Sensor Circuit Low Voltage
P0113 IAT Sensor Circuit High Voltage
P0117 ECT Sensor Low Voltage (w/message)
P0118 ECT Sensor High Voltage (w/message)
P0121 Throttle Position Sensor Performance
P0122 Throttle Position Sensor Low
P0123 Throttle Position Sensor High
P0125 ECT Excessive Time To Closed Loop fuel control
P0131 H02S Circuit Low Voltage Bank 1 Sensor 1
P0132 H02S Circuit High Voltage Bank 1 Sensor 1
P0133 H02S Slow Response Bank 1 Sensor 1
P0134 H02S Circuit Insufficient Activity Bank 1 Sensor 1
P0135 H02S Heater Circuit Bank 1 Sensor 1
P0137 H02S Circuit Low Voltage Bank 1 Sensor 2
P0138 H02S Circuit High Voltage Bank 1 Sensor 2
P0140 H02S Circuit Insufficient Activity Bank 1 Sensor 2
P0141 H02S Heater Circuit Bank 1 Sensor 2
P0147 H02S Improper Voltage B1
P0151 H02S Circuit Low Voltage Bank 2 Sensor 1
P0152 H02S Circuit High Voltage Bank 2 Sensor 1
P0153 H02S Slow Response Bank 2 Sensor 1
P0154 H02S Circuit Insufficient Activity Bank 2 Sensor 1
P0155 H02S Heater Circuit Bank 2 Sensor 1
P0157 H02S Circuit Low Votaae Bank 2 Sensor 2
P0158 H02S Circuit High Voltage Bank 2 Sensor 2
P0160 H02S Circuit Insufficient Activity Bank 2 Sensor 2
P0161 H02S Heater Circuit Bank 2 Sensor 2
P0167 Fuel Temp Sensor High
P0170 Fuel TrimBank 1
P0171 Fuel Trim System Lean Bank 1
P0172 Fuel Trim System Rich Bank 1
P0173 Fuel Trim Bank 2
P0174 Fuel Trim System Lean Bank 2
P0175 Fuel Trim System Rich Bank 2
P0200 Injector Control Circuit
P0218 Transmission Fluid OverTemp
P0230 Fuel Pump Control Circuit
P0300 Engine Misfire Detected
P0325 Knock Sensor (KS) System
P0327 Knock Sensor (KS] Signal Circuit Front
P0332 Knock Sensor (KS) Signal Circuit Rear
P0335 CKP Sensor Circuit
P0336 CKP Sensor Circuit Performance
P0341 CMP Sensor Circuit Performance
P0342 CMP Sensor Circuit Low Voltage
P0343 CMP Sensor Circuit High Voltage
P0351 Ignition Control 81 Circuit
P0352 Ignition Control 82 Circuit
P0353 Ignition Control 83 Circuit
P0354 Ignition Control 84 Circuit
P0355 Ignition Control 85 Circuit
P0356 Ignition Control 86 Circuit
P0357 Ignition Control 87 Circuit
P0358 Ignition Control 88 Circuit
P0400 EGR Flow Malfunction
P0401 EGR Performance
P0402 EGR Excess Flow Detected
P0404 EGR Pintle Position Error
P0405 EGR Pos Sensor Low Volt
P0410 AIR System
P0412 AIR Solenoid Relay Control Circuit
P0418 AIR Pump Relay Control Circuit
P0420 TWC System Low Efficiency Bank 1
P0430 TWC System Low Efficiency Bank 2
P0440 EVAP System
P0441 EVAP incorrect flow
P0442 EVAP Control System Small Leak Detected
P0443 EVAP Purge Solenoid Valve Control Circuit
P0446 EVAP-Canister Vent Blocked
P0449 EVAP Canister Vent Solenoid Valve Control Circuit
P0452 Fuel Tank Pressure Sensor Circuit Low Voltage
P0453 Fuel Tank Pressure Sensor Circuit High Voltage
P0461 Fuel Level Sensor 1 Circuit Performance
P0462 Fuel Level Sensor 1 Circuit Low Voltage
P0463 Fuel Level Sensor 1 Circuit High Voltage I
P0480 FC Relay 1 Control Circuit
P0481 FC Relay 2 And 3 Control Circuit
P0500 Vehicle Speed Sensor Circuit (M/T)
P0502 VSS Circuit Low Input
P0503 VSS Dropped too Fast
P0506 ldleSpeedLow
P0507 Idle Speed High
P0522 Engine 0il Pressure Sensor Circuit Low Voltage
P0523 Engine Oil Pressure Sensor Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit
P0531 A/C Refrigerant Pressure Sensor Performance
P0560 System Voltage
P0562 System Voltage Low (w/ message)
P0563 System Voltage High (w/ message)
P0567 Cruise Resume Circuit
P0568 Cruise Set Circuit
P0571 Cruise Brake Switch Circuit (M/T)
P0601 PCM/VCM Memory
P0602 PCM/VCM Not Programmed
P0604 PCM/VCM RAM Performance
P0605 PCM ROM
P0606 PCM Internal Communication Interrupted
P0608 VSS Output Circuit
P0615 Starter Relay Control Circuit
P0645 A/C Clutch Relay Control Circuit
P0650 Malfunction Indicator Lamp (MIL) Control Circuit
P0654 Engine Speed Output Circuit
P0704 Clutch Switch Circuit (M/T)
P0705 Trans. Ranqe Switch Circuit (A/T)
P0706 Trans. Range Switch Performance (A/T)
P0711 Trans Fluid Temp Sensor Circuit Performance
P0712 TFT Sensor Circuit-Low Input (M/T Europe only)
P0713 TFT Sensor Circuit-High Input (M/T Europe only)
P0716 4L80E Input SS Performance
P0717 4L80E lnput SS Low
P0719 Brake Switch Circuit Low
P0724 Brake Switch Circuit High
P0730 4L80E Unknown Gear Ratio
P0740 TCC enable Solenoid Cicuit
P0741 TCC Excess Slip
P0742 TCC System Stuck On
P0748 Pressure Control Solenoid Circuit
P0751 1-2 Shift Solenoid Performance
P0753 1-2 Shift Solenoid Electrical
P0756 2-3 Shift Solenoid Performance
P0758 2-3 Shift Solenoid Electrical
P0785 3-2 Shift Solenoid Electrical
P0801 Reverse Inhibit Solenoid Control Circuit (M/T)
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit (M/T)
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit (M/T)
P1106 MAP Intermittent High
P1107 MAP Intermittent Low
P1111 IAT Sensor Circuit Intermittent High Voltage
P1112 IAT Sensor Circuit Intermittent Low Voltage
P1114 ECT Sensor Circuit Intermittent Low Voltage
P1115 ECT Sensor Circuit Intermittent High Voltage
P1120 TP Sensor 1 Circuit
P1121 TPS Voltage Intermittant High
P1122 TPS Voltage I ntermittant Low
P1125 APP System
P1133 H02S Insufficient Switching Bank 1 Sensor 1
P1134 H02S Transition Time Ratio Bank 1 Sensor 1
P1135 Lean Mean Bank 1 Sensor 1
P1136 Rich Mean Bank 1 Sensor 1
P1153 H02S Insufficient Switching Bank 2 Sensor 1
P1154 H02S Transition Time Ratio Bank 2 Sensor 1
P1155 Lean Mean Bank 2 Sensor 1
P1156 Rich Mean Bank 2 Sensor 1
P1191 Intake Air Duct Leak
P1220 TP Sensor 2 Circuit (w/ message)
P1221 TP Sensors 1, 2 Performance (w/ message)
P1222 Injector Control Circuit Intermittent
P1257 Supercharger system Overboost
P1258 Engine Coolant Over Temperature-Fuel Disabled
P1274 Injectors wired incorrectly
P1276 APR Sensor 1 Circuit Performance
P1280 APP Sensor 2 Circuit
P1281 APP Sensor 2 Circuit Performance
P1285 APP Sensor 3 Circuit
P1286 APP Sensor 3 Circuit Performance
P1336 Crank Position sensor Error
P1380 EBTCM DTC Detected o Rough Road Data Unusable
P1381 Misfire Detected - No EBTCM/PCM Serial Data
P1404 EGR Pintle Closed Position Performance
P1406 EGR Pintle Position Error
P1409 EGR Vacuum Leak
P1410 Fuel Tank Pressure System
P1415 AIR System Bank 1
P1416 AIR System Bank 2
P1431 Fuel Level Sensor 2 Circuit Performance
P1432 Fuel Level Sensor 2 Circuit Low Voltaqe
P1433 Fuel Level Sensor 2 Circuit High Voltage
P1441 EVAP System Flow During Non-Purge
P1442 EVAP Vacuum Switch High Voltage
P1504 EBCM RPM signal error
P1508 Idle Low, IAC not responding
P1509 Idle High, IAC not responding
P1515 Commanded vs Actual TP Performance (PCM)
P1516 Commanded vs Actual TP Performance (TAC)
P1517 TAC Module Processor Fault (w/message)
P1518 PCM to TAC Module Serial Data Circuit
P1520 Transmission Range Switch Circuit
P1523 Throttle Closed Position Performance
P1539 A/C Clutch Status circuit high voltage
P1545 A/C Clutch Relay Circuit
P1546 A/C Clutch Status Circuit Low Voltage
P1571 ASR Desired Torque (w/ message)
P1572 ASR Active circuit Low too long
P1574 Stop Lamp Switch Circuit
P1575 Extended Travel Brake Sw. Circuit High Voltage
P1585 Cruise Control Output Inhibit circuit
P1626 Theft Deterrent System Fuel Enable Circuit
P1630 VATs Learn Mode Active
P1631 Theft Deterrent System-Password Incorrect
P1635 5 Volt Reference 1 Circuit
P1637 Generator-L-Terminal Circuit (w/message)
P1638 Generator F Terminal Circuit Failure (w/message)
P1639 5 Volt Reference 2 Circuit
P1652 PCM Chassis Pitch Output Circuit (w/message)
P1654 Cruise Control I/O circuit
F1659 EVAP Solenoid Circuit
P1660 Cooling Fan control Circuit
P1661 MIL Control Circuit
P1663 Oil Level Lamp Control Circuit
P1665 Driver 3 line 5
P1666 Driver 3 Iine6
P1689 Traction Control Delivered Torque Control Circuit
P1810 TFP Valve Position Switch
P1811 Max Adapt and Long Shift
P1860 TCC PWM solenoid Electrical
P1870 Transmission Component Slipping
P1875 4WD Low Circuit error
03' TJ
08' pile of DOM, 6.0 vortec, TH400, stak 3 spd, two steering rocks, 44" TSL's, and a really sweet keychain.
spaggyroe is offline   Reply With Quote
Old 08-09-2008, 09:55 PM   #24
patooyee
Pirate4x4 Addict!
patooyee's Avatar
Member # 4821
LS2 to TH400 info (and possibly will help with TH350 and 700R4, too):
http://www.pirate4x4.com/forum/showthread.php?t=705980
J. J.
www.patooyee.com
Build thread
Old 08-09-2008, 09:57 PM   #25
BillaVista
Web wheeler/welder
BillaVista's Avatar
Member # 3547
Here's a little teaser:
http://www.pirate4x4.com/tech/billavista/misc/GM/
BillaVista
See my tech articles:
Pirate4x4.com Tech
Back up...a little bit...and come with it. Would ya just take the skirt off...and drive!
- Charlie M
Originally Posted by BootsntheJeep View Post
Oh for God's sake man, don't burden these obviously talented and skilled people with ENGINEERS.
BillaVista is offline   Reply With Quote
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
