Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Truck and 4Runner
Old 08-15-2008, 02:44 PM   #1
colonelangus
Member # 115243
proportioning valve question
i have a 87 4runner the rear lspv isnt working anymore.i have a manual proportioning valve id like to install.its a wilwood with 1 line in and 1 line out.
there is 2 lines running back to the lspv and only 1 out ..can i delete the line that is coming from the front side of the master to the lspv..or should i get a 2 into 1 fitting and connect it that way..
colonelangus is offline   Reply With Quote
Old 08-15-2008, 02:45 PM   #2
crash
Pirate4x4 Addict!
crash's Avatar
Member # 1588
Send a message via Yahoo to crash
yes.......
Why is it we all are for doing the same thing--but yet we can not work together to achieve it
Mike Crash Kash
The new live streaming video crashfab
crash is offline   Reply With Quote
Old 08-15-2008, 03:18 PM   #3
Hottrod81
Hottrod81's Avatar
Member # 36464
hmmmm......
Hottrod81 is offline   Reply With Quote
Old 08-15-2008, 04:08 PM   #4
OOP'S
Pirate4x4 Addict!
OOP'S's Avatar
Member # 30
Location: Roseville, CA,To many Yuppies, Not enough Hippies
That is the feed line for the rear brakes. You want to delete the line that hooks into the front brakes. It is located on the "T" that is located in the PS front wheel well. The feed line that goes to the rear is long enough it screw into the soft line that goes from the rear end to the bracket on/by the gas tank. Put a plug in the "T" up front when you take the return line off. If you did a search you would find all this information it even has pictures.
David & Theresa, Roseville, CA,
Excellent Parts Source
http://www.davezoffroadperformance.com/
http://www.marlincrawler.com/
http://www.12voltguy.com/web/
OOP'S is offline   Reply With Quote
Old 08-15-2008, 04:43 PM   #5
Hottrod81
Hottrod81's Avatar
Member # 36464
If that doesn't answer his question, nothing will. Good Pics OOPs.
Old 08-16-2008, 10:50 AM   #6
colonelangus
Member # 115243
thanks for the info..by the way my search /faq isnt working ive sent a pm to the site but no reply yet..doesnt matter what i type i get no match try again..
Old 11-17-2008, 05:05 PM   #7
cherokeechief79
Member # 7684
looking for info on this and was wondering if i could do the same thing here on a 94 runner that has abs brakes.would i have to totally remove or disable the abs box that the ps lines and brakelines go into?
mark
cherooo thingy
cherokeechief79 is offline   Reply With Quote
Old 11-17-2008, 09:56 PM   #8
TOYOTAPARTS
Dave'z Off Road Perf
TOYOTAPARTS's Avatar
Member # 61493
you can also run the right front steel braided line right to the hard line on top of the tee and by pass the tee all together..the hard line's loop is long enough to pull down to the braided line. http://www.davezoffroadperformance.c...c.php?f=3&t=52
link to our install and here is a pic of what we by pass the load leveler with.
For all your new and used TOYOTA and SUZUKI parts.HIGH PINION 3RDS ON SALE. Most Trail-Gear product is FREE shipping.Heavy duty twin stick shifter for sale! 530-622-2148
TOYOTAPARTS is offline   Reply With Quote
Old 11-18-2008, 07:38 AM   #9
cherokeechief79
Member # 7684
ok i think ive gathered enough info to do this.im gonna use a wilwood man prop valve.the only thing im still a bit confused on is that most of the writeups ive seen were without abs brakes.i have this but its doesnt really work since i replaced my 3rd member in the rear.im not at all concerned about keeping the abs at all im just wondering if i can still just plug the return line up front and plumb in the manual valve on the feed line in the rear.or will i have to remove the whole abs box itself?
mark
cherooo thingy
Old 11-19-2008, 06:05 AM   #10
orangething
Member # 81052
willwood parts give me a chubby
orangething is offline   Reply With Quote
Forum Jump
