#1 |
Member # 55361
Axle Wrap and Anti-Wrap setups? Rear
Its way past the time that I build a rear anti-wrap bar... you can see in the pic below that I often try to turn my rear axle into a toploader!
![]() Description is in my sig... 64s in the rear, I know I need to get a better rear shackle angle. I was thinking about building something similar to Kert @ DIYs "Wraptor", but got to thinking about it and I dont know if I need to get that complicated. What I want to know from you FULLSIZE guys is who is running what and what kind of difference have you noticed in axle wrap and traction. Does it bounce less? Also if you have a flex pic I would love to see it Gabe PS: I have searched and read and read again, I just want some current opinions from guys running big tires with heavy rigs... thanks
[COLOR="Red"]SAVE TELLICO POST #195[/COLOR] ex-President- [url]www.offcamber4wd.org[/url] 87k5 eaton rear, chromo 60front, 203/205 ect ect ect sittin on 42Iroks:smokin: [URL="http://pirate4x4.com/forum/showthread.php?t=678695"]Build thread [/URL] |
#2 |
King of Booty Fab
Member # 55444
Check mine.
No wrap, and I've been doing burnouts, on the 49's, and when I do the truck jacks up. No hopping.
TTC 2010 Hopeful
Anyone want to donate some stuff so I can finish in time? ![]() But seriously............. |
| Sponsored Links |
#3 |
unconcerned onlooker
mine doesnt limit flex. its a single sided bar built like a ladder bar but with a shackle on the forward end. angle and placement of the ladder bar will determine load placement on the tire. it turns it into a ladder bar, in that the end of the frame where the shackle attaches becomes the lifted part.the shackle simply allows it to articulate.
MySpace sympathy, empathy and apathy... i dont know which one is which.... But i know you can find sympathy between shit and syphilis in the dictionary. |
#4 |
If everything goes right, I will have some pictures for ya when I get back stateside the end of the week.
I am running 44 boggers and 310:1 gearing, so it sees plenty of torque load.
Big Ed '78 Chevy Big-30 ![]() Check out our online store. AMSOIL Your last stop for all your Automotive Synthetic Lubricant needs. Please PM me for quotes or questions. Link to places to wheel in Texas Texas A&M Off-Road: "Collegiate (and ol' Ag) off-roading in its finest state" |
#5 |
Member # 92313
We have a couple rigs running this set up in our group, its simple, shackle at the frame side. My truck weighs 6700 lbs and the only thing I broke was a bolt due to a rock hitting the bracket.
#6 |
Member # 55361
Im assuming that you are using the frame side heim with misalignment spacers? If so does this allow for enough rotation of the axle durring hard flex?
gabe
#7 |
I use bushings on all three sides of my link, which is much like those built by M1028. There wont be any bind from the link, if you only use one. You dont need more than one per axle, so it does make packaging easier. When you put two per axle on the rig it might limit flex.
#8 |
Member # 96496
Location: Flowery Branch, GA (yes.. like a branch with f**kin pretty pink flowers on it...)
fawk, just 4 link it.
#9 |
Member # 32786
This is the best pic of rear flex I have at work. If you search at CK5 under my username 79chevyk10 you'll find better. Had to measure front limit strap length due to blowing out 1350 cv's from overflex at got 43" from ground to bottom of rear tire and had more in it, but not the front driveline... anyway.
My traction bar is mounded on the pass side tube with Johnnie joints at all three points with a 7" shackle at crossmember. The bar is same length as rear driveline and doesn't limit flex at all. I have ran it for 4 years now and have conquered ledges that none of my friends can do. I get anit-squat (rear lifts up under accel) as a result. You really need to do one before you spin a tube or snap a yoke.
79' K10 350 F.I./ TH350/ NP203/NP205/D60/14FF & 42's 02' GMC crew cab D-Max 79chevyk10 everywhere else. Save The Hammers Rally Post #314 Tellico Rally Post #20 |
#10 |
Member # 55361
Ill be building one before the K5 sees dirt again. I have broken a DS yoke, but if I spin a tube on the eaton I would be really Focked
![]() Thats pretty much the design I have been thinking. Has anyone made one like the one below? ![]() using a pivot bearing like this one from rocklogic4x4.com ![]() I was thinking it would allow for unlimited movement as far as flexing goes while keeping the pinion angle consistant. what are your thoughts, opinions, bacon recipies...
#11 |
Member # 32786
Bushings would be fine IMO if they were as close to center as possible. If you have to be off center, I perfer to have joints to eliminate having the bushings wearing out after 10 trips or so.
Your design will work tits...I think. Attatched is a pic of the traction bar I made and a poser flex pic described above in my pervious post.
#12 |
Member # 115091
would the shackle work on the top??
85 k10 454th350203/205 rocks 4linkedf/r 49"iroks 86 k10 454 44"tsl 05 Dmax ccsb http://www.killerblazer.8m.com |
#13 |
Member # 44136
If you are asking if the shackle should be in tension, or compression, I usually see them set up in tension if you do a shackle flip, but I don't know why.
Hammers Thread post #1388 Tellico Rallypost # 285 |
#14 | |
Member # 55361
With the shackle in tension at an optimal angle it will not allow the pinion to rotate unless the shackle rips off the crossmember.
#15 |
Member # 15404
Gabe is right, however I have seen it work in compression.... if you have to do it just make the shackle long so it is less likely to invert on you.
Life begins whare the pavement ends! |
#16 |
Member # 15404
Here is mine. It's been working good for a couple of years.
#17 | |
Member # 2922
Take pics of what you make! Burt
Rockin in a Fullsize *****72 K5/Blazer***** |
#18 |
Member # 115091
thanks for the info!!how much seperation do you use,would 1.5".120 dom with 3/4x3/4 rod ends be strong enough for 454 doubler 4.56 39.5 and a heavy foot
#19 |
Member # 55361
I just ordered the bearing pivot from rocklogic, I will update this thread when I get ready to build it.
gabe
#20 | |
Member # 15404
I assume you are talking to me.... As I recall I think I used 8" of seperation. I would go with as much as you can without making it hang to low or get in the way of anything up high. I used 1.75" x .120 DOM with a half of 1/4" thick good pipe welded on the bottom. I used 3/4x5/8 rod ends (40k lbs rated). I think yours would be strong enough. I wanted mine to be able to contact rocks and not dent/bend so I over built it. I have had many 3-4 foot rear full throttle bounces while climbing and it has held up fine. Here is a great thread about the subject. On the third page Gordon shows how to determine your IC and antisquat... http://www.pirate4x4.com/forum/showt...=351224&page=3
#21 |
Member # 15404
So what do you think is the advantage of this style over using a rod end? My 30$ 3/4 x 5/8 rod ends are rated for 40k lbs.... it seams that would be overly complicated and expensive.
#22 |
Pirate4x4 Addict!
Member # 6704
What's the general "been there, done that" consensus on the crossmember? I have a bunch of 1.5 x 1.5 x .120 square tube left over from various other projects. Is the .120 wall sq. tube up to the task? I can always go pick up some heavier wall tube if need be.
It's IHeavy aka TORC KC0UIC -.- -.-. ----- ..- .. -.-. Nothing is foolproof to a sufficiently talented fool. |
#23 | |
Member # 55361
#24 |
Member # 115091
started building a cross member after work today.figured out the frame is different from one side to the other.put a slight delay in my progress
#25 |
Member # 48084
REAR
![]() ![]() ![]() FRONT ![]() ![]()
SFA ZR2 wheeler |
| Thread Tools | |
| Display Modes | |
