Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 09-24-2008, 06:22 PM   #1
extremetoy
Member # 21887
Send a message via AIM to extremetoy
Boatsides on my Blazer in Progress
Just though I would share the progress that I have done on the boatsides for my Blazer. Consists of 2x8 3/16th, 2x2 3/16th and 3/16th plates.
2x8 welded in. I know I only have 4wheel studs on the front tire, it just for rolling around purposes
2x2 crossmembers tacked in.
Plate tacked on.
Plate partially welded in and painted
Still one more grinding, welding, painting, and another side to do. Just though I would share..
extremetoy is offline   Reply With Quote
Old 09-24-2008, 06:23 PM   #2
operose
Member # 69243
Gonna cap the ends?
Looks pretty stout either way
operose is offline   Reply With Quote
Old 09-24-2008, 06:43 PM   #3
ashmanjeepXJ
Cherokee Moderator
ashmanjeepXJ's Avatar
Member # 10249
47s only need 4 lug nuts
ashmanjeepXJ is offline   Reply With Quote
Old 09-24-2008, 07:03 PM   #4
Spike5421
Member # 10411
Send a message via AIM to Spike5421
what do the bottom of the doors look like? Did you cut right below the bottom hinge?
82 Cj7 (SOLD)
'04 4wd Taco, S/C, Allpro 3.5", 4.88 gears, ARB bumper, Warn, rocker guards.
Spike5421 is offline   Reply With Quote
Old 09-24-2008, 10:24 PM   #5
extremetoy
Member # 21887
yes I am going to cap the ends and then use 16 guage to block off the fat holes on the sides to stop mudd from getting in.
Yes I know I only have 4 studs on the front right. I ran out and had to roll it around alittle before I bought more and have not put them in yet but it isn't driving yet anyways.
I wanted it stought since I plan on having full exo and this thing is gonna be heavy.
Old 09-25-2008, 01:45 AM   #6
turbosniper1
The MaKK Daddy
turbosniper1's Avatar
Member # 66537
Send a message via Yahoo to turbosniper1
I think your boatsides are just right! Not too high to make them look like $hit and take up too much of the truck, and not too low so they are pointless... they are just right! Good job! And I say that the 3/16" is also a good balance of strength and weight, especially if you are going to put the exo-cage on it! Keep the pics coming as the build progresses please! I would like to see how it turns out with the cage!
Thanks!
Matt
The BEST H-1 Beadlocks with custom recenters:
http://www.pirate4x4.com/forum/showthread.php?t=746158
NP 241DHD T-Case for '01 Ram 2500 Diesel
http://www.pirate4x4.com/forum/showt...0#post10167380
turbosniper1 is offline   Reply With Quote
Old 09-25-2008, 09:42 AM   #7
Rock Ape
Member # 23843
Boatsides???I thought those were sliders!!!!
Looks good and keeping the doors might be nice....for awhile!!!
THANKS TO MY SPONSORS....TFAB,TRAIL-GEAR,YUKON,TORCHMATE AND RUFFSTUFF!!!
Rock Ape is online now   Reply With Quote
Old 09-25-2008, 11:37 AM   #8
6.2Blazer
Member # 21408
Interested in how he did the lower door hinges also. I'm going to guess he either had to cut them out and/or move them because the new tube looks higher.
Also, is there still room inside the door to roll the window all the way down?
6.2Blazer is offline   Reply With Quote
Old 09-25-2008, 01:21 PM   #9
extremetoy
Member # 21887
The hinges on the doors are in the stock location but I had to cut the bottom hinge in half. Originally I wanted to go higher but with the doors so heavy, I just went as high as I could and it turned out perfect. The windows are currently welded shut to keep the weather from the interior while I build it. Unfortunately GM decided to design the doors with the power window motor in the bottom of the door. I plan on getting some doors with manual windows and modify them to work with them cut. Or I will just cut the welds and pull out the windows
Old 09-25-2008, 01:45 PM   #10
87GMCsierra
Member # 49663
Send a message via AIM to 87GMCsierra
Are all of the 2x2 braces the same length? my buddy has a 91 blazer and he is boatsiding it but it doesn't look like we can get the plate to sit flush with the frame if we run the braces straight to the frame cause the frame has a slight bend in it at the front.
87 GMC 350 TPI Blown(up).d60 x-over locked zero rates & 6" skys.14bltff detroit,discs DIY4X shackle flip & 4"tough country's.465/205 twin sticked.H.A.D. front shaft.39.5 tsls on beadlocks. narrowed 2ft front & rear
01 dodge ram 2500 CTD 6spd. DD/Tow rig leveled on 35" Interco's
87GMCsierra is online now   Reply With Quote
Old 09-25-2008, 03:21 PM   #11
SKOP
Member # 109734
Thumbs up
looks good.
i also love the look of your rig
SKOP is offline   Reply With Quote
Old 09-25-2008, 03:57 PM   #12
J-Ohlin
Member # 80208
Also love the rig. Can you post pics of the rear fenders inside and out. also did you bob the rear or just push the axle back?
76 fj-40, 400sb, 465, 35's.
89 blazer, tbi 350, nv 4500, 241, 60, eaton, 5.13's, 38.5 SX's.
J-Ohlin is offline   Reply With Quote
Old 09-25-2008, 03:59 PM   #13
78stepsideUAK10
78stepsideUAK10's Avatar
Member # 92930
Badass
78stepsideUAK10 is offline   Reply With Quote
Old 09-25-2008, 06:17 PM   #14
extremetoy
Member # 21887
The back is narrowed 9" on each side. I started the narrowing slightly past the cab to save some room for the passengers. Also the rear axle is pushed back about 3". I will take picture when I have a chance..
All of the 2x2 braces are a slightly different length and angle from each other. The frame is slightly different throughout the entire thing. The bottom plate looks like a wave on the bottom to match the shape of the frame. When i have a chance will take a picture of it. 3/16th is not that thick and it can be bent to conform to the frame either buy pushing it with your foot and tacking it in or using a jack to push it against the frame.
Old 09-25-2008, 06:29 PM   #15
Odin K30
...self chosen
Odin K30's Avatar
Member # 86878
Dood....you can weld glass
Just being a dick.
Nice work keep the pics coming looks good.
I dig the skulls.
79 GMC shortbed/ D60/ TH400/ NP205/ locked H072/ coils at all four corners/ 3 Link frt / 4 link rear/TPI 355...for now
Buy my TH400/205 combo http://www.pirate4x4.com/forum/showthread.php?t=861417
Odin K30 is offline   Reply With Quote
Old 09-25-2008, 06:45 PM   #16
87GMCsierra
Member # 49663
thanks man. ill try to convince him to do it that way. it seems alot easier. he wanted to run 2x2 off the frame about 6" to 8" then angle cut them and run the braces from those to the slider.
Old 09-25-2008, 07:00 PM   #17
extremetoy
Member # 21887
On average, mine are 12" long from frame to 2x8
Old 09-26-2008, 12:19 AM   #18
87GMCsierra
Member # 49663
yea the way he wanted to do it doesn't seem as strong as just running them straight to the frame.
Old 09-26-2008, 05:52 AM   #19
77fixer
Member # 9679
How about some pics of the wheel spacers.
77fixer is online now   Reply With Quote
Old 09-26-2008, 09:59 AM   #20
welndmn
Well Done Man!
welndmn's Avatar
Member # 398
Send a message via ICQ to welndmn Send a message via AIM to welndmn Send a message via Yahoo to welndmn
Looks nice.
Wow, you live in P-town and I have never seen that rig.... Does it run
Mark
71 Bronco. 42's and bolt on goats.
welndmn is offline   Reply With Quote
Old 09-26-2008, 03:48 PM   #21
extremetoy
Member # 21887
Originally Posted by welndmn View Post
Looks nice.
It does not see too much street use with tire wear being so expensive
Yes it does run but I have yet to drive it with the rockwells and 47s. currently it is a slightly built L98 355 with TPI.
Old 09-26-2008, 06:41 PM   #22
motofast28
motofast28's Avatar
Member # 108470
can you take some pics of the inside where you cut at
motofast28 is offline   Reply With Quote
Old 09-27-2008, 04:03 PM   #23
extremetoy
Member # 21887
I will take pictures tomorrow when I weld in the drivers side plate.
Old 09-27-2008, 05:14 PM   #24
Ramrock
Member # 20276
Man after seeing this i think i mite reuse my 2x4x.250slider when i boat side my yota truggy. And just move them up and use 2x2.250 wall for the angle peices to the frame. Sence my exo/cage is set-up to mount to it. Plus 2x2x.250 is just setting on my shop floor.
01 RAM 2500 Q/B 2WD 24V CUMMINS
85 YOTA 2.5-ROCK's TBI-4.3/tb-350/doubler/42"s/H1's/4LINK/1 LINK
Ramrock is offline   Reply With Quote
Old 09-27-2008, 08:55 PM   #25
78stepsideUAK10
Member # 92930
How far up are the power windows in the doors, or are they mounted on the bottom.
I want to keep my power windows
Forum Jump
