As far as the laws in Tennessee Here what I am trying to comply with, inorder to be street legal.
"55-9-212. Mudguards on trucks — Penalty
a) No person shall operate upon a public highway or street any motor vehicle, including a separate truck tractor (normally used in a tractor-trailer combination), or combination of vehicles having a carrying capacity in excess of three thousand pounds (3,000 lbs.), if the motor vehicle or combination of vehicles is not equipped with rear fenders, mudflaps or mudguards of such size as to substantially prevent the projection of rocks, dirt, water or other substances to the rear. The fenders, flaps or guards shall be of a type approved by the commissioner of safety.
55-9-215. Operation of motor vehicle without adequate energy absorption system prohibited — Alteration of altitude from ground level of passenger car prohibited — Modification of front end by lift blocks prohibited — Modification of steering mechanism prohibited — Exceptions — Enforcement — Penalties. —
(a) No person shall operate a motor vehicle on any road, street or highway unless the vehicle is equipped with a bumper or other energy absorption system with an analogous function.
(2) No person shall operate a four-wheel drive recreational vehicle of a type required to be registered under the laws of this state upon a public highway or street modified by reason of alteration of its altitude from the ground if its bumpers, measured to any point on a load-bearing member on the horizontal bumper bar, are not within the range of fourteen to thirty-one inches (14-31) above the ground, except that no vehicle shall be modified to cause the vehicle body or chassis to come in contact with the ground or expose the fuel tank to damage from collision or cause the wheels to come in contact with the body under normal operation, and that no part of the original suspension system be disconnected to defeat the safe operation of the suspension system; provided, that nothing contained in this section shall prevent the installation of heavy duty equipment to include shock absorbers and overload springs; and provided further, that nothing contained in this section shall prevent a person from operating a motor vehicle on a public highway with normal wear of the suspension system if normal wear does not affect the control of the vehicle. In the case of a four-wheel drive vehicle where the thirty-one-inch limitation is exceeded, the vehicle will comply with this section if the vehicle is equipped with a drop bumper. The drop bumper must be bolted and welded to the frame of the vehicle and be made of a strength equal to a stock bumper.
(3) No person shall modify or cause to be modified by the use of lift blocks the front end suspension of a motor vehicle.
(4) (A) Maximum frame heights for motor vehicles shall be as follows
(ii) Trucks and recreational vehicles
(b) 4,501-7,500 lbs.26 inches
(B) Frame height measurements shall be taken from the bottom of the frame by measuring the vertical distance between the ground and the lowest point of the frame directly below the point in line with the center of the steering wheel.
(5) No person shall operate a motor vehicle having a distance greater than four inches (4) between the body floor and the top of the frame.
(6) No person shall modify or cause to be modified the original manufacturer installed steering mechanism, including welding, nor the front spindle where the brake pads mount, on a passenger vehicle or a truck or recreational vehicle with a weight up to ten thousand pounds (10,000 lbs.).
Other requirements: Rear view mirrors, lights windshield ect."
My plan is run mudflaps in the rear only, as it is not required in the front. The lowest point of my frame will remain less than 26" off the ground. I will maintain less than 4" between the frame and the floor. My front bumper should be less than 31 inches of the ground. I will have a makeshift rear bumper mounted under my spare tire carrier. I consider coilovers to be heavy duty shocks for the drivetrain I am running. I am going to run hydro assist.
