#1 |
Cage Fighter
Member # 2634
Throwin a 60 under my D-MAX
OK, so maybe this could go in chit chat, tow rigs, or other, but I think it fits here OK.. mmmkayyy
You and I know that after the first real dent / flop, you'll see this beast camped at buck lol.. trying to avoid any real CARNAGE, but WTF... if you wheel it, it will comeDiagnosis - after two years of "light" wheeling, mild trails, snow and fire roads my IFS finally took a major DUMP.... I tagged a rock while doing some whooops at moonrocks, then got high centered on a rock, and then it just went down hill from there, shredded the lift kit, snapped a tie rod end, destroyed the rear Dline and tranny mount ![]() blah blah vlah IFS BLOWSSolution - Do what chevy should have done in the first place - steel rear drive shaft - HP kingpin (79 ford ) 60 ![]() - King RESY coilovers ![]() - hysteer - 4 link front - 4.10 gearing - ARB front - beadlocked 37's I just order my PLATES "NOMOIFS" LOLHere are a few initial PICS until the parts start rolling in... No real fab pics as I haven't broken out the hypertherm yet
#2 |
Cage Fighter
Member # 2634
| Sponsored Links |
#3 | |
Addicted to Gear Oil
Member # 56050
This should be good
1965 Scout 80 7.3PSD/ZF/203/205 Quote:
David H. Petraeus for President 2012 |
#4 |
Cage Fighter
Member # 2634
#5 |
Member # 129493
don't you need the axle level relative to the truck, not the ground?
#6 | |
Cage Fighter
Member # 2634
level was on ther for another reason !!!that pic was just show and tell
<>< Last edited by Chopperman; 06-16-2009 at 11:12 PM. |
#7 |
Member # 37026
looks like you bailed out on the double cab taco idea/plan?
ECV 7-11 RIP troy & daniel, KYOTA Forever. |
#8 |
Cage Fighter
Member # 2634
Needone of those too !!! . .actually I came to realize, that i would absolutley destroy a rig like that...
I need a 4 seater 1 ton buggy BAD.. my D-MAX is a light trail/ snow / DD / camping / tow rig
#9 | |
Member # 37026
#10 |
Member # 6892
Should be a sweet project. Any particular reason you are thinking 4 link instead of 3 link plus a panhard? Just seems as a daily driver having the panhard would be better because of the reduction of bumpsteer.
Yarr! I've been to the Hammers... There in the tool section at Home Depot. Rally for The Hammers post #141 Rally for Tellico post #100 Last edited by Blue-Beard; 06-17-2009 at 12:44 AM. |
#11 | |
stock sucks
Member # 78847
id have to agree either way your gonna need a pan hard on that beast the three link should give you more room for drive shaft and exhaust clearance even if you radius arm the one side as this thing is not gonna need to be a flex monster but handling will be a priority id assume ... you have proven you have skills can't wait to see what you come up with
#12 | |
Cage Fighter
Member # 2634
I'm still up in the air on this kit vs fabbing my own stuff.... I just don't have the time .. REALLY... Been working 12-14 hour days 6-7 days a week now, so time is a HUGE priority for me right now... If I buy this kit I'm looking at one weekend worth of work to get back on the road... I don't know.... Either way, I'm buying parts tomorrow, I need to get this thing rolling...
<>< Last edited by Chopperman; 06-17-2009 at 01:22 AM. |
#13 |
stock sucks
Member # 78847
we both know once you get that shit in your hands all your gonna see is it's limitations and what you should do
![]() i hear the time crunch part thou ... http://www.polyperformance.com/shop/...t-p-16803.html that kit minus the upper frame brackets, the upper shock mounts are just 2 hoops w tabs, lowers are tab's on the axle so you have to make the upper frame mounts and tie the hoops together and you know that shit will take a pounding. just trying to play devils advocate for ya .. good luck looking forward to see what you come up with |
#14 | |
Cage Fighter
Member # 2634
![]() I just need to get the axle under their and start looking around.... no time though...
<>< Last edited by Chopperman; 06-17-2009 at 01:53 AM. |
#15 |
stock sucks
Member # 78847
lol of course you did
![]() ![]() tell dave he needs to prototype this swap so he can sell lots of them and you will be kind enough to let him use your truck for it ... ![]() im out the am is coming to fast have good one man |
#16 | |
Cage Fighter
Member # 2634
Out
<>< Last edited by Chopperman; 06-17-2009 at 02:04 AM. |
#17 |
Semi-Broken
Member # 13467
Dumb question, will the stock T-case work with that drivers drop axle?
#18 |
Member # 4140
The stock 261/263 is drivers drop if that's what you mean. It does have a slip yoke front output which is less than ideal for a lifted solid axle rig.
Tim There is no accounting for taste 1936, 1937, 1943, 1950, 1952, 1954, 1955, 1997, 1998, 2002, 2008. |
#20 |
Member # 42023
Be carefull with ordering that steering from ORU....a few weeks ago, my swap that would only took two days took three weeks due to the steering arms being on back order and no one telling me about it when i placed my order. Ended up playing phone tag and finally got things lined out.
good look....youll love it, just wish i had went DMAX
2007.5 2500HD "Six O" Pain in my ass. 1994 K2500 "From the ground up" |
#21 |
D1G1A0F9
Member # 11869
That Ford blue 60 looks good under the chebby
![]() I would just buy the material and fab your own mounts/links. We all know you can do it and do it right, judging from your other builds. Looking forward to a non bolt-on update
#22 |
Pirate4x4 Addict!
We are all born Arminians. It is grace that turns us into Calvinists -George Whitefield FOR SALE - DAVE COLE specials - interco truxxus stickies |
#23 |
Wears a tinfoil hat
Looks like this is gonna be a cool rig when its all done. Will you be retaining the front ABS or getting rid of it completely?
Scott |
#24 | |
Member # 6892
Yarr! I've been to the Hammers... There in the tool section at Home Depot. Rally for The Hammers post #141 Rally for Tellico post #100 |
#25 | |
Member # 56050
What "kit" are you looking at? You know you can build something better, cheaper, and stronger...you got the skilz
I understand the time issue though. If you got an extra $7,200 laying around The short arm kit is still $3,000 yikes![]() Rock Krawler is very proud to release its first solid-axle swap kit for the '00-'06 Chevy 2500/3500 trucks. The system provides around 9 inches of lift with the help of coilover racing shocks. The system is designed to work with an '03-and-up Dodge Ram axle, but brackets are available to make any driver-side pumpkin axle work with the kit. Heavy-duty steering kits are also available to complement this kit while giving minimal bumpsteer. Rear coilover kits are available as well, or you can stick with a conventional rear leaf setup. Information: Rock Krawler, 518.270.9822, www.rockkrawler.com
David H. Petraeus for President 2012Last edited by guidolyons; 06-17-2009 at 11:03 AM. |
| Thread Tools | |
| Display Modes | |
