Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Approved Vendor's Marketplace > Axles/Tires/Wheels
Old 07-09-2009, 09:55 PM   #1
Gravel Maker
Quick with a laser!
Gravel Maker's Avatar
Member # 51387
Send a message via Yahoo to Gravel Maker
Thumbs up The Ruffstuff 9" Axle Housing!
This is it! The Ford 9" Axle Housing. This axle housing is a touch different than you are used to seeing from housing fabricators, this housing is not quite round! To put it simply, if it was round it would be weaker. The housing has 14 different facets to the basic diamond shape resulting from 36 individual bends! The end result is an axle housing that is the smallest shape possible and strongest shape too, AND there are no abrupt edges to hang up on passing rocks.
We make the Ford 9" Axle Housings to have 1/8" clearance of the ring gear because Ford made all ratio R&P's exactly 9" in diamerer. 3.08 ratios are 9" & 7.20's are still 9". Another beneficial thing to keep in mind when deciding on which axles you want to use is the NASCAR influence. NASCAR has been driving down the price of 9" axle parts for 50 years!
They are available in 1 length (68") and you can cut them if you need shorter. They will come in 1 tube diameter and thickness but you can try and convince me that 3 1/2" x 3/8" wall DOM isn't strong enough. The Body of the housing is 1/4" A50 plate and the faceplate is 3/8 for better stud retention. They are internally reinforced with 6 seperate reinforcements that all tie together to make it way strong. You will also have the option of front or rear and left or right drop. We stock these so you won't have to wait either!
And they aren't that heavy either!
Most of our welders don't dress this way but when Loren wanted to wear the leather apron how could I say no?
Actually, for a hot 19 year old model I think she really liked the housing
These are $480 picked up or $550 delivered in the lower 48. I think we can hold this price for a few months if steel dosen't do what it did last summer....We are just finishing up the truss options and I will add them later. The Toyota 8" is having a minor change done and then it will also be done! We will also make these for the Super 14 as Portal Tek makes them available.....
Dan Fredrickson
www.ruffstuffspecialties.com
Products that are better than "Good Enough"
Sales 916.509.2242 Tech/Sales 916.600.1945
Check out our NEW Axle Housings!
Gravel Maker is offline   Reply With Quote
Old 07-09-2009, 10:17 PM   #2
Gravel Maker
Quick with a laser!
Member # 51387
By the way....
We are making great progress on the FF hubs and spindles. They should be ready in 2-3 weeks. The Spindles are 4140 both HT & Cryo'ed and large enough for 40 spline axles, you can still run any spline count you want but why make them for less? The hubs and drive slugs are also nearly done and use the strongest bearing we could find but somehow it isn't really very expensive....This combo should take a big chunk off what the big guys are charging and I would run them head to head with theirs any day of the week!
Dan Fredrickson
Old 07-09-2009, 11:01 PM   #3
finder_87
Member # 4682
Subscribed. I might have to come take a look at these. The housings are ready to go?
Um...what?
finder_87 is offline   Reply With Quote
Old 07-10-2009, 12:39 AM   #4
maxyedor
maxyedor's Avatar
Member # 87150
That's what I like to hear! Can't wait for my play-money account to fill back up, it's a little low at the moment
maxyedor is offline   Reply With Quote
Old 07-10-2009, 01:11 AM   #5
toykilla5150
Smashurai!
toykilla5150's Avatar
Member # 65463
Send a message via AIM to toykilla5150
So you said Toyota 8"..... Im listening. Whats the deal on those bad boys? Do we need to supply the balls? Widths?
Thanks Andrew
Dave Halabuk RIP
Hope your gettin it up there in heaven!
Needs gears or lockers installed? Want to gear ur t-case or do a doubler? give me a call (916)417-7417
myspace
toykilla5150 is offline   Reply With Quote
Old 07-10-2009, 12:04 PM   #6
Gravel Maker
Quick with a laser!
Member # 51387
For the Toyota fronts.....
Thanks Andrew
If you want to stick with the birfields you would have to add the balls. We are looking for a company that can make them for a reasonable price.
Dan Fredrickson
Old 07-10-2009, 08:48 PM   #7
rockreeper
Member # 32958
Are you going to be selling them with d60 c's installed anytime in the near future?
rockreeper is offline   Reply With Quote
Old 07-10-2009, 11:04 PM   #8
Gravel Maker
Quick with a laser!
Member # 51387
We don't intend to in the immediate future.....
But we could deliver them to a couple of great local axle builders for free to complete them. I use Trevor or Beau at WFO Concepts or Sean at River City Differential....We are about 10 miles from either in the new location....
Dan Fredrickson
Old 07-10-2009, 11:12 PM   #9
finder_87
Member # 4682
Where is the new location? Is it cool to come by and check out the housings? Are you guys going to be at the rock race at praire tomorrow?
Um...what?
Old 07-10-2009, 11:16 PM   #10
Gravel Maker
Quick with a laser!
Member # 51387
We are now in Loomis!
Give me a call and I will give you directions...
But no races for us tommorrow Still winding up the move, the main shop is empty but now we have 6 rigs to move and all the bulk storage that was in the second building, its going to be a long weekend....
Dan Fredrickson
Old 07-10-2009, 11:38 PM   #11
troyman
troyman's Avatar
Member # 8277
Send a message via MSN to troyman Send a message via Yahoo to troyman
Definitely subscribed, I need a new housing and something to stick my 35 spline strange housing into! Will the full float option be available for 5 on 5.5?
Last night I lay in bed looking up at the stars in the sky and I thought to myself, where the hell is the ceiling.
troyman is offline   Reply With Quote
Old 07-11-2009, 07:51 AM   #12
matts88yj
YJ Junkie
matts88yj's Avatar
Member # 62615
Send a message via AIM to matts88yj
Dan, I hope I can get a hold of you for a few minutes today! If not I understand with still moving into the new shop and all. Both the housing and the model are I can't wait to see what options you have in store for the housings! Keep up the great work!
Matt
Anger Management Motorsports
#474 Spotter / Co-Driver
matts88yj is online now   Reply With Quote
Old 07-11-2009, 10:28 AM   #13
Gravel Maker
Quick with a laser!
Member # 51387
Here are some answers....
Yes, the 5 on 5.5", and the Toyota 6 & the 8 lug fullsize patterns.
I will be here answering the phone and directing the move as much as I can til late afternoon so call away!
Dan Fredrickson
Old 07-12-2009, 11:39 AM   #14
Gravel Maker
Quick with a laser!
Member # 51387
The shop has been pretty much destroyed....
By the move!
Now we have the rest of the day to pick up the pieces and put it all back together....
Dan Fredrickson
Old 07-12-2009, 12:06 PM   #15
AlxJ64
Member # 130031
The housing looks great Dan! I remember talking to you on the phone about this about 2 years ago. I'm gonna drop a link to this on our local board.
'97 TJ - HPD44 & HO72, 5.14s Locked F/R, 38" Creepy Crawlers, SM465/NP231D-HD
AlxJ64 is offline   Reply With Quote
Old 07-12-2009, 05:37 PM   #16
brewchief
brewchief's Avatar
Member # 71185
Will the full floater version have the snouts already on or will it be up to the builder? Will shipping be cheaper if I buy a front and rear at the same time? Approx cost on floater hubs?
The mind is like a parachute...it only works when it's open.
Hammers rally #318
Tellico rally #602
brewchief is offline   Reply With Quote
Old 07-12-2009, 06:34 PM   #17
Gravel Maker
Quick with a laser!
Member # 51387
Thanks, how does it look to you? Like I described 2 years ago?
Depending on the length you wanted we could add them for you for a reasonable fee (Not robbery). It would likely be much cheaper to ship without them.
We are shooting for $650-800 for the Hubs, Spindles, & Bearing combos and they are 47 spline capable! However, they won't be ready for a few weeks.
Dan Fredrickson
Old 07-12-2009, 06:37 PM   #18
VB CJ 5.7
Member # 111759
What housing?
79 CJ5... revived and promptly sold...
91 YJ with some shit bolted on...
VB CJ 5.7 is offline   Reply With Quote
Old 07-12-2009, 06:52 PM   #19
Gravel Maker
Quick with a laser!
Member # 51387
Uhhh....
Originally Posted by VB CJ 5.7 View Post
What housing?
the housing this add is all about?
Dan Fredrickson
Old 07-13-2009, 10:10 PM   #20
Gravel Maker
Quick with a laser!
Member # 51387
Got to see this one!
Because its the one you want!
Dan Fredrickson
Old 07-14-2009, 05:16 AM   #21
moveaside
moveaside's Avatar
Member # 11983
Now that is badass sir you caught me at a perfect time the 44 is whooped and I have a 9" third member I want to use. Any plans on a toy front axle housing maybe even a fj60???
I'll kick the shit out of you if I find you throwing trash out on the trail!
My crappy build
[url]http://www.pirate4x4.com/forum/showthread.php?t=587635[/url]
moveaside is offline   Reply With Quote
Old 07-14-2009, 09:56 AM   #22
Gravel Maker
Quick with a laser!
Member # 51387
Good question....
The FJ60 is the second in line....The Toyota 8" possibly as soon as this Friday!
Dan Fredrickson
Old 07-14-2009, 02:10 PM   #23
dmsFab
dmsFab's Avatar
Member # 101054
If only there were more chics like this in the world!
Nice housing by the way......no, not the model!
dmsFab is offline   Reply With Quote
Old 07-14-2009, 02:34 PM   #24
Mawnov
Member # 48072
Will a toy-elocker be a option when you finish the toy 8"?
85 4Runner with some stuff.
Mawnov is offline   Reply With Quote
Old 07-14-2009, 06:54 PM   #25
moveaside
moveaside's Avatar
Member # 11983
Those maybe too hard to find to make money selling axles for them but Dan can answer that better than me.
My crappy build
Forum Jump
