Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Truck and 4Runner
Old 07-28-2009, 06:07 PM   #1
Diesel_Dirk
Just do it!
Diesel_Dirk's Avatar
Member # 106806
spring perch crushing rear axle
Has anyone had the rear spring perches crush the axle tubes?
I noticed my pinion angle decreasing over time, past being inline with hte driveshaft, to where the agle was a few degrees negative.
I run 3" TG springs and they are bent (I guess a traction bar is in order) somewhat, and I assumed this was the sole cause of the axle rotation.
But when I set out to grind out the welds on my perches i noticed thatthe tube had been crushed by the perches.
thats a 1/4" gap under the straight edge.
the points of the perches left even deeper indents
Aside from the crushing the axle "seems" straight.
I plan to cut a chunk out of another axle tube, split it lenghtwise and use each half to reinforce under a perch.
Has anyone seen similar damage? Fixable or replace the housing?
my build: http://ovo.ca/forums/showthread.php?t=867
Diesel_Dirk is offline   Reply With Quote
Old 07-28-2009, 06:09 PM   #2
TOYOTAPARTS
Dave'z Off Road Perf
TOYOTAPARTS's Avatar
Member # 61493
I see this every day,mostly over torquing u bolts. Wont happen with a Tg rock assault housing.
http://www.davezoffroadperformance.com/
For all your new and used TOYOTA and SUZUKI parts.HIGH PINION 3RDS ON SALE. Most Trail-Gear product is FREE shipping.Heavy duty twin stick shifter for sale! 530-622-2148
TOYOTAPARTS is offline   Reply With Quote
Old 07-28-2009, 06:11 PM   #3
Mr Stubs
Mr Stubs's Avatar
Member # 102813
How long have you had the rig.... it could be from major overloading abuse.
My friends call me "The butcher"
I feel like I stole this bing from Billy....http://www.pirate4x4.com/forum/showthread.php?t=847699
Mr Stubs is offline   Reply With Quote
Old 07-28-2009, 06:13 PM   #4
Mr Stubs
Mr Stubs's Avatar
Member # 102813
Originally Posted by TOYOTAPARTS View Post
I see this every day,mostly over torquing u bolts. .
That would be some major over torque. Must be done by monkeys with big air tools.
Old 07-28-2009, 06:55 PM   #5
Diesel_Dirk
Just do it!
Member # 106806
Rig is exactly a year old now. I beat on it fairly hard. 38's, doubler, with 4.7 in the rear case and 5.29's.
As far as over torquing...I tightened them with a 1/2" ratchet....
just checking out your build Stubs...may have to plagarize that track bar.
Old 07-28-2009, 07:16 PM   #6
crash
Pirate4x4 Addict!
crash's Avatar
Member # 1588
Send a message via Yahoo to crash
Its a tin can--what do you expect..
Why is it we all are for doing the same thing--but yet we can not work together to achieve it
Mike Crash Kash
The new live streaming video crashfab
crash is offline   Reply With Quote
Old 07-28-2009, 07:33 PM   #7
yotakid707
yotakid707's Avatar
Member # 55608
Send a message via AIM to yotakid707
hopping.overloading,over tourqing,or what crash said its just a tin can all can be the problem....a buddy of mine did the same thing hopping his truck pretty hard trying to get up a trail
Never argue with an idiot cuz they bring you down to there level and then beat you with experience!
yotakid707 is offline   Reply With Quote
Old 07-28-2009, 07:37 PM   #8
Pat
Me, Myself, and I
Pat's Avatar
Member # 120
I can use a 1/2" rachet and torque something to well over 200lbs..
What does a half inch rachet have to do with anything?
I have seen this alot on rigs with blocks too.. A cool quick tip is to take some 3/8"(About the same witdth as your perch) flat bar and bend it to the shape of the underside of the axle under the perches going up the the bottom of the perch top and weld them in place.. kinda like the shape of a V or U.. just helps a stock sheetmetal housing survive big tires, lots of torque, and over torquing the ubolts
Try out a AppleSeed... http://www.appleseedinfo.org/
Pat is offline   Reply With Quote
Old 07-28-2009, 07:43 PM   #9
86Yota4.70
Linkoligist
86Yota4.70's Avatar
Member # 44474
Send a message via AIM to 86Yota4.70
He is talking about me.. I was bouncing on the rear pretty hard and broke a rear axle shaft.. went to replace it and found this..
HereticFab.com..
-Heat Treating- 4130 links!
-Cryogenics
-Custom Fabrication
www.Mixchallenge.info
86Yota4.70 is offline   Reply With Quote
Old 07-28-2009, 07:49 PM   #10
Diesel_Dirk
Just do it!
Member # 106806
That tube looks nasty...
Yeah hoping, etc... thats what i figure did this in.
Thanks for the tips guys. I'll strengthen the perch area and start looking for another axle.
Old 07-28-2009, 07:53 PM   #11
yotakid707
yotakid707's Avatar
Member # 55608
Taylor you need to come up to bobs man...uppers is calling for you lol jeff and alex have been giving it a pretty good run lately but gettin denied.....shane gave it a good run and his buddy almost walked it in his rockwelled runner but broke a rear shaft too
Old 07-28-2009, 07:58 PM   #12
Diesel_Dirk
Just do it!
Member # 106806
I meant that I didn't use air or some monsterbar to tighten them.
Old 07-28-2009, 08:21 PM   #13
ErikB
Grocery Getter
ErikB's Avatar
Member # 59
I've seen it before. U-bolts dent the housing a little sometimes but wrap is what caves it in on the front side.
Here's what I've done to spread the load around the tube better.
ErikB is online now   Reply With Quote
Old 07-28-2009, 08:26 PM   #14
Diesel_Dirk
Just do it!
Member # 106806
thanks for the pics Erik
Forum Jump
