#1 |
Member # 106812
Crawl ratio for rock racing?
Did some searching but guess I am not typing it in right.Wondering what the average crawl ratio people are using in Rock Race events?I am thinking around 35 to 1 give or take a few would be good but figured I would ask.
#2 |
Pirate4x4 Addict!
Member # 4821
Is it still called a "crawl" ratio if you're racing???
I know I blow your mind ... ![]() J. J. Last edited by patooyee; 10-19-2009 at 06:54 PM. |
| Sponsored Links |
#3 | |
Member # 106812
#4 |
Moderating Midget
Short course or endurance?
Nolen Grogan CottonLand Cruisers www.rockmidgetphotography.com blacksheep4x4.com USAF Veteran 1988-1998 GOD Bless America |
#5 |
Member # 80873
ttt
id be interested to hear what ratios/drivetrains the endurance/koh guys are using
#6 |
Pirate4x4 Addict!
Member # 4821
My build now is 50:1 not including converter. My old rig was 34:1 with 42's. To be honest back then it was too high for what i did but probably good for rock racing with the power that I had. (Mild SBC350.) I'm not a racer though so I'm probably not a good source of knowledge there. Sorry to waste your time.
Draggbody is who I compare my specs with since we wheel together. He has a mild BBC454 with an SM465 and when he's trying to go fast never even puts the t-case in low range. That puts him around 16:1 in first gear I believe. (he doesn't use granny in that case and spends most of his time in 2nd gear anyway.) He recently won SETTC and dominated the speed courses so that may be informative for you. I wouldn't say that he was exactly in a field of fellow racers though. He runs 40's. J. J. Last edited by patooyee; 10-19-2009 at 07:19 PM. |
#7 |
5.13's/2.5 first/3.0 atlas 2500 stall. whatever numbers it works out to be. never did it. goes pretty good.
Doug Bigelow IronClad Energy, Mopar Super Center, Appalachian Offroad, Maxxis, Bulldog Winch, Raceline, PSC, Custom Aluminum Radiators, FOA, Yukon Axle, Tom Woods, PRP, Baja Designs, Stage 8, Everlast Welders, Powertank, Air Dominion LLC, Rock Racing Batteries Code:
http://www.accessarmy.com |
#8 |
Member # 74897
38.475:1 not counting the convertor
#9 |
Stuff Strutter
Member # 26443
tires play into it. You need more gearing to feel the same with 42's then with 37's. That said mid to upper 30's with 40" tires. This is speaking to xrra type stuff/rock bouncing. I think Randy at jimmy's says around 42:1. I'm goint to be about 38:1 in mid like doug
Triple Nickel Racing Team #555 Kelly Kaiser Vertical Limits Inc 913.731.3040 paypal: verticallimitsinc@excite.com Your ORI struts dealer! |
#10 |
Member # 106812
Thx for all the info..I am looking at 727/dana 300/ 5.13 gears.Was hoping the mid 30's would be good.Also going with a 37 or a 39 not sure yet.
#11 |
Pirate4x4 Addict!
Member # 2160
I like doug's #'s- Jess
http://highangledriveline.com Bringing Innovation to the market ! http://highangledriveline.com/HAD1.gif 530-877-2875 -------------------------------------------------------------------------------- When we fear our Government its called tyranny ,And when our Government fears us its called Freedom. |
#12 |
Member # 30887
I'm currently 31:1, and it feels great for racing. I do notice when slow crawling that it's pretty high. I used to be 43:1 and I think the rig is faster now with the higher gearing. Before, the 1st gear rapped so quick, i lost time between the 1-2 shift. Now, 1st can hold longer and pulls harder. Tranny is a 4l60E (3.06 1st i believe) and the t-case is a np205 with 5.13 r&p.
If i were building a multi-purpose rig, i think a 3 or 4spd case would be the ticket, that way you have more control in the slow rocks but have the mid range for the speedy stuff. I guess it depends on what you will be doing with your rig. If only racing, mid 30's would be great. But if you wanna crawl some, like rec wheeling, deeper would def be better. I got plenty of motor to overcome, but it's real jumpy in the rocks.
Xrra Team #720 Mayhem Motorsports Sponsors- Heiseroil.com, InnerAirLock.com, Drivetrain Specialists, Adventure Productions 13th place, XRRA Western Division 2008 2008 Homebuilt tube chassis-2004 LQ9, 4l60e NP205, Dana 70's, 40" Toyo's. |
| Thread Tools | |
| Display Modes | |
