#1 |
Member # 12758
Picts: FJ40 with Cummins 6bt installed...
Belongs to 6btctd_40 over in the Land Cruiser section. Thought I'd post the picts for everyone to see...
Stats (not sure what the axles are... 60s?): Radiator is afco racing aluminum steering is now saginaw 15x10 wheels 42x15x15 swampers tf 727 trans np205 tcase square tube front driveline... Front axle....
Diesel Conversions Community - 91' Toyota Mini Truck, Mercedes diesel, low height coil SAS, Marlin doubler, running on vegetable oil. - '69 FJ55 on FZJ80 frame, Cummins 4BT, NV5600 CruiserOutfitters.com 4x4labs.com TreadWright.com MarlinCrawler.com UtahPowderCoatings.com PlantDrive.com |
#2 |
Member # 12758
Rear Fire wall: ![]() His Junk:
| Sponsored Links |
#3 |
Member # 2214
Where's the intercooler!???
Should be a fun ride. I know how it does in my 7000# Dodge pickemup. Rick (hope he has a good pyro. on it) |
#4 |
Member # 4406
Thats sick.
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride." |
#5 | |
Member # 137
Obviously the front is J/KThat rig kicks major ass! But more importantly, what are in the diffs, what gears? I'd like to see a shot of the steering linkage in the engine bay. I bet it was tight! How close is the oilpan to the front diff? More pics please........
'72 FJ55 [url]http://forum.ih8mud.com/showthread.php?t=76835[/url] '73 FJ40 [url]http://s132.photobucket.com/albums/q1/chuck_088/?sc=1&addtype=local[/url] '78 FJ40 '93 Ram W350 5 spd. CTD '99 Ram 3500 4X4 5 spd. CTD Welding is like sex, it's all about the penetration! |
#6 |
Member # 12758
I'll shoot him an email to get us some details...
Fresh out of picts on my end...
#7 |
Member # 13463
INSANE
Mike Hullfish TREC #C 94 |
#8 |
that is the ultimate of cool. the only thing i have concern over is the weight and vibration of the motor. for a TRAIL ONLY rig, i would rather have an 8cyl diesel for the smoothness. but in an expedition/daily driver/tow rig like what i plan to build in the far off future based off one of these-
i would rather have the 6cyl, and i will, with a TF727 and rover LT230 transfer case. |
#9 |
Member # 6971
HARK! What is that strange sound I hear off in the distance?
Oh, its his front springs screaming for mercy That is way cool, I love those motors. Definatly need more specs and pics.
I'm the "tack tack tack" welding nazi. http://www.pirate4x4.com/forum/showp...&postcount=218 ![]() "I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside |
#10 |
Member # 7412
thats a 89 to 91 non intercooled moter from a dodge. i have thought real serious about doing this and i have a 5.9 cummins at my disposal. but the noise turned me off for a trail rig. hell i have to shut my truck down to talk to anybody in a parking lot. the torque would be awsome, the fuel miliage would be great. but trying to listen to your spotter or talking to some one on the trail would suck. i bet with the pump bumped up that cruiser will haul ass. looks good, hell i would love to have it for a daily driver/ light trail rig. it would be a blast. mike
i would rather be spanking the monkey offroad |
#11 |
Member # 12338
thanks everyone! diffs are : dana 60 front narrowed 4.5 inches arb 4.56 gears dana 70 hd rear detroit 42x15x15 swampers this engine is a 90' with no intercooler. i do have an aftercooler but havent mounted it yet. it sits on the head/intake steering is now saginaw. i turned in the fuel screw quite a bit! lots o smoke lots o torque! its entered in ttc 2003 please gimme your vote! thanks feel free to email pat4x4@hotmail.com
#12 | |
I Like to Party!
it'll be a shame to see so much work get wasted running places like elbe
BITD #4401 KOH Finisher 2010 Partners: Bilstein Shock Absorbers, Trail-Gear, Trent Fabrication, GT General Tire, S&N Fab, Superior Axle & Gear, Raceline Wheels, PSC, Vision X Lighting, Tom Wood's DriveshaftI Wanna Go Fast! |
#13 |
Member # 7412
have you changed your fuel pin location to get max fueling and played with your smoke screw? and bump the timing up about 3/32 above the factory line. and get a 16cm. housing on it and it will get a boost a bit quicker. and i dont think egt's will be a problem with the weight you will be running. mike
#14 |
Member # 12338
yes i have turned in the fuel screw and adjusted the smoke screw. exhaust housing is 18 cm and i havent messed with timing yet when the pump was stock this thing moved like a lightning bolt on 42's with 4.56 gears and the trans in 3rd!!!!! torque has to be upwards of 650 lbs now!!
#15 |
Member # 137
Just looking at the drivetrain, did you scavenge it from a W350?
You know you're gonna start another trend here What's your wheelbase? How bout some more engine bay shots?
#16 |
Member # 12338
no i didnt use the dodge gear the rear end is a dana 70 hd out of a ford dump truck i put 1 ton front 60 rotors on it. detroit locker front is military dana 60 4.56 and arb 35 spline all the way out
#17 |
thread killa...
Member # 10903
Did you use front 60 calipers and brackets on the D70HD also?
Pics?!
John 06 Dodge 2500 06 Unlimited Rubicon 91 K5 |
#18 | |
There are several of them running around Sacramento, and one of the buggy manufacturers offered a 4BT as an option. I am just curious about front axle/driveshaft clearence. Both of the rigs I have seen in town here had issues due to the large oil pan and the top to bottom dimensions of the block. I woould not worry too much about innercoolers, aftercoolers, CACs, pyrometers, blah, blah, blah...... This engine will never create full power in a light weight rig. If it ever does, watch your frame twist into a pretzel. A lot of early Cummins Dodges came back to the dealership with a front tire in the air because the frame was so heavily twisted.
Ask me anything about a Cummins, I stayed at a Holiday Inn last night. |
#19 |
Wears a tinfoil hat
That rig is very cool!!
http://facebook.com/tenbucks76 |
#20 |
Member # 9017
not as cool as his but
heres mine w/ a nissan turbo diesel (sd33t)
![]() and the jeep
AKA "NEO" Team Branik Motorsports/Badlands #518 Spotter/Co-Driver for Brandon "Dino" Haynes in XRRA, KOH, TREC Series Thanks to our sponsors: Branik Motorsports,Badlands Offroad Park, Bulldog Winch, Greatlake Offroad, Fort Wayne Clutch, Metal Supermarkets, Superior Axle, and BFGoodrich |
#21 |
Member # 8717
I see said the blind man |
#22 |
how do you like the nissan diesel? they are cheap and i am assuming would work well in a light rig like mine.
#23 |
Member # 9017
it does fine, i have no complaints.
i took off the air cleaner and put an k&N filter in place of it. that helped out alot with the response and i can hear the turbo alot better now.....sounds sweet!! this spring i'm going to put 3" exhaust on it and see if that will help it out anymore.
#24 | |
Member # 7430
Oh, wait, you drive a Rover ![]() 5-6 grand for a new one, 3-4 to totally rebuild if you have a core. the SD33T stock, is about 100 hp. Inadiquate for a 5000 lbs Scout. How light is your rig? Anyone interested in SD33/T hopups visit here: http://atlas.binderbulletin.org/foru...p?s=&forumid=5 Yeah, its a Scout site, so what. They've got the market cornered on Nissan hop-up parts. Matt
Wifey: Get rid of the porn??? WHY??? We'd have to get rid of the knives, guns and booze too!!! Later that week: I'm JEALOUS!!! Why did YOU get the lap dance, and I DIDN'T!?!??? |
#25 |
i have seen used motors sell for as little as $500 in running condition, im not too worried about price in that regard.
i would want to tweak it up to about 150hp, my truck is at about 100 right now and its too slow. my rover is about 3300lbs. |
| Thread Tools | |
| Display Modes | |
