Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 07-22-2003, 04:32 PM   #1
Tass
Member # 1516
$20 Dana 300 flip kit
A couple of people have been asking me for info on how I flipped my Dana 300 so here goes. First of all most of the credit has to go toward Xtremetoy here on the board because he gave me the idea on how to do it.
First of all I made a new piece to house the shift rails between the case and the original cover out of 1.5" by 3/4" rectangular tubing. I drilled it to accept the cover and the new rails. For the shift rails I used 5/8" ID pipe which is the size of the rails. I took the original front shift rod housing and cut it in half and flipped it over (so I could reuse the detents and shifters etc.) and attached it to the new shift rail housing.
Next I pulled the case apart and flipped the shift forks over to come out of the (new) top. The reverse fork has to be ground just a little to clear the forward fork. Next I drilled two new holes in the shift rods to locate the set screws, I just played with the detents and the forks until I figured out exactly where I wanted the holes, I then marked them and pulled the case apart to drill the rods. This was the hardest part of the whole thing because if the holes are off it won't go into gear all the way when you shift (obviously).
I made a new plate to cover the original shifter holes in the bottom of the case which also holds the bottom of the front output shaft bearing housing.
Since I was just going by trial and error I didn't get a lot of pics but I'll post what I have. I know the expanation kinda sucks but I'm going from memory here. Basically it took me about 14 hours total to make everything, pull the case apart and put it back together. It's really simple and works great so far. Oh, yeah, for shifters I used a couple of my old Toyota pieces. It doesn't look pretty but it gets the job done.
I'll try to answer any questions that anyone has as best as possible.
The first pic shows the top of the case and where I cut the shift housing.
Tass
Nothing to see here, move along.............
Tass is offline   Reply With Quote
Old 07-22-2003, 04:33 PM   #2
Tass
Member # 1516
The next pic is basically the same thing. It's hard to see but it shows how close the two shift forks are.
Tass
Old 07-22-2003, 04:35 PM   #3
Tass
Member # 1516
The next pic is the test fitting in the truck. It's behind a Toyota t-case using an OTT adapter (which is a work of art BTW)
Tass
Old 07-22-2003, 04:41 PM   #4
Tass
Member # 1516
Next is with the top plate on and the shifters installed. Sorry the pic is blurry.
Tass
Old 07-22-2003, 04:50 PM   #5
rokcrln
Member # 5821
Clean set up! So I assume the dana 300 is only a pass side drop?
Seams real easy (time excluded) to do and is a better set up than the stock dana 20s for EB's and more options for up grades.
Buildem--Rollem--Tearem Apart--Get Rid of the Wife--And Start All Over!
BRONCO BUGGY; dana44,35spln 9", 37's, 351W efi, C5full manual w/comp brk, atlass 5:1, fox 16" air's master craft rubicon's, full hydro, and a girl friend that loves to help.
rokcrln is offline   Reply With Quote
Old 07-22-2003, 05:00 PM   #6
66CJdean
Pirate4x4 Addict!
Member # 940
Looks cool. The shifters for the 300 look like toy shifters???
WWW.PCRYO.COM
Deep Cryogenic Tempering Service
Find all my products at
www.KICKASSOFFROAD.COM
916-434-6978
Custom Axles built to order. 4340, TorMax, or 300M
Custom Hummer wheels and centers
Axle Resplining
66CJdean is offline   Reply With Quote
Old 07-22-2003, 05:01 PM   #7
Tass
Member # 1516
Yes, stock is pass. side drop. A lot of the time was figuring stuff out like where to drill, how to attach the shifter housing etc. I'm sure I could do another one less time.
Tass
Old 07-22-2003, 05:02 PM   #8
Tass
Member # 1516
They are Toy shifters. I also used the Toy shifter housings, I just cut them out of the top of some old cases I had laying around
Tass
Old 07-22-2003, 05:13 PM   #9
66CJdean
Pirate4x4 Addict!
Member # 940
They make a nice pivot point and clean.
What did you do for a fill/overfill port so as to get the right amount of fluid in it?
WWW.PCRYO.COM
916-434-6978
Axle Resplining
Old 07-22-2003, 06:28 PM   #10
BJ On Roids
Member # 6588
using a similar theory could you flip a toy t-case upside down? do you think??? im sorta confused on the issue, at first i thought it would spin the wrong way, now i wonder what i was smoking before!
does the Dana 20 have front wheel disconnect? will it hold up to the punishment? (I read bv's article but im not convinced its as good as an atlas)
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR]
[COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR]
BJ On Roids is offline   Reply With Quote
Old 07-22-2003, 07:59 PM   #11
Damo
Member # 9123
It's a dana 300 and yes they do have front axle disconnect. hi/lo on one stick, 2wd/4wd on the other.
Metal to burn, sparks to fly...
Damo is offline   Reply With Quote
Old 07-22-2003, 08:06 PM   #12
madmarx
Member # 5115
Damo, this is DEFINITELY incorrect. The left stick is for the front axle, and the right stick is for the rear axle. With the 300 in the stock position, the sticks all the way forward is low, middle is nuetral, and rear is high.
madmarx is offline   Reply With Quote
Old 07-22-2003, 08:08 PM   #13
Tass
Member # 1516
[quote]Originally posted by 66CJdean
[/QUOTE
I filled it up before I put the top on. You could use the plug on the top cover to fill it as long as you measure how much is going in.
Tass
Old 07-22-2003, 08:13 PM   #14
Damo
Member # 9123
My bad. But I got the 300 thing right and u can nuetral the front output independant of the rear...
Ever run it with one end in hi and the other in lo?
Old 07-22-2003, 10:12 PM   #15
madmarx
Member # 5115
Nope, I never took mine apart so I could take out the interlock pill.. I imagine it would blow up pretty dang fast
Old 07-23-2003, 06:18 AM   #16
TN William
Member # 10283
Can you make me one for $20?
TN William is offline   Reply With Quote
Old 07-23-2003, 06:28 AM   #17
RUFF
RUFF's Avatar
Member # 8565
And he was asking a Question about a Dana 20 not a 300
www.werockaustralia.com
SAVE THE HAMMERS Post #749
Do illiterate people get the full effect of Alphabet Soup?
If electricity comes from electrons, does morality come from morons?
RUFF is offline   Reply With Quote
Old 07-23-2003, 08:56 AM   #18
wilburburns
Web Designer-Host
wilburburns's Avatar
Member # 18120
Are there any lubrication issues or problems with flipping a D300?
Cliff
wilburburns is online now   Reply With Quote
Old 07-23-2003, 11:20 AM   #19
Jeepmangled87
ROCK & ROLL OFFROAD
Jeepmangled87's Avatar
Member # 3906
Send a message via AIM to Jeepmangled87
not a bad setup.
ROCK AND ROLL OFFROAD
877-765-8774
Dallas/Ft Worth OFFROAD MEGA STORE.
www.shoprockandrolloffroad.com
www.rockandrolloffroad.com
www.forumrockandrolloffroad.com
RED YJ-42's 60-14-fox
TEAM 7238 BITD BORN TO KILL
Jeepmangled87 is offline   Reply With Quote
Old 07-23-2003, 11:41 AM   #20
GoodeJ
GoodeJ's Avatar
Member # 13056
300 Flip
Sweet!!! I'll have to remember this option when I go full size!!!
Blue Ribbon, UFWDA, CORVA LIFETIME Member
RTP, Friends of "Everything I can" KG6WSR
GoodeJ is offline   Reply With Quote
Old 07-23-2003, 12:25 PM   #21
BrettM
Member # 11998
Send a message via AIM to BrettM
you should seriously consider making that into some sort of "kit", or having people send you their D300 and having you modify it. The DOE kit is like $800, though I think it includes the clocking ring and stuff also...
awshifting.com
awshifting@gmail.com
BrettM is offline   Reply With Quote
Old 07-23-2003, 03:15 PM   #22
Tass
Member # 1516
I can barely find time to work on my rig, let alone building things for other people
Tass
Old 07-23-2003, 08:13 PM   #23
saprobe
Member # 6596
doesnt matter. the 20 is the same way,so same answer applies
nice job on the home-brewed flip
scotty
85 grand wagoneer(whats left of it)
77 scout II truggy
84 "home made crew cab"
Mindless
Entertainment
saprobe is offline   Reply With Quote
Old 08-11-2003, 12:00 PM   #24
GoatASS
Member # 21338
have you taken this on the trail yet? how is it holding up?
GoatASS is offline   Reply With Quote
Old 08-11-2003, 12:27 PM   #25
ashmanjeepXJ
Cherokee Moderator
ashmanjeepXJ's Avatar
Member # 10249
COOL
ashmanjeepXJ is offline   Reply With Quote
Forum Jump
