Member # 8294
Rhino Performance
Thinking about trying to get some more power out of the wife's Rhino. Already have a CDI box on it and that helped a bunch compared to the POS CDI it had. I have read that with the CDI boxes they can over rev so I want to do a tach first just to keep an eye on things.
Thinking exhaust first with upgrades to clutch and rejetting. Anyone got some advice? I know next to nothing about hopping these guys up and don't even know where to start. Looking for better acceleration, a bit more high speed, and just more all around response and power. Not looking to go too far, and don't want to sacrifice reliability too much. Thanks
If life gives you lemons, throw them at the stupid people. |
Member # 97035
I put a CDI in my 07 660 Rhino and it made it real clear that the next mod is probably a sheave/belt/exaust tip when I can afford it. I was thinking one of these- http://www.hunterworks.com/inc/sdetail/18364 The CDI has a cool feature that I put in the glove box called a "brother-in-Law switch. It really limits the motor and would be good for when the kids ride it.
[FONT="Times New Roman"][SIZE="3"]What you had matters not-you must do with what you've got.[/SIZE][/FONT] |
Member # 8294
Looks good. I like the idea of controlling the RPM properly. This should reduce the chance of over revving if adjusted right. I have seen spring kits for the clutches, but I know nothing about CVT transmissions other than the conceptual theory.
Member # 5809
Try the ALBA Exhaust if your going to get one. More money but its a very well put together kit. More Info
As for more speed. Get a machined clutch sheave from KMS. With the CDI you should be able to get it up to the 50mph range. Last edited by RoCkSkuLLz; 05-17-2008 at 08:47 AM. |
Member # 16371
Machined primary sheaves generally give you a slightly lower initial gear ratio and slightly higher final gear ratio, but everything in between is the same. If you get a clutch kit, lots can be changed depending on use of the rhino. Centrifugal clutch springs change engagement rpm, weighted rollers change shift rpm in conjunction with secondary springs to change backshifting and belt pressure. So, be specific in your driving needs when ordering a clutch kit. There is also a snowmobile clutch conversion kit that is supposed to be the new hot setup, but expensive.
Member # 113916
This is what I've done.
I replaced the intake tube, the one connecting the air box to the center console with a RAIS tube to give it more air to breathe. Go here for instructions http://www.yamaharhinos.net/Carb/yrnraispdf.pdf Installed a high flow K&N air filter I removed the end cap to the pipe and installed a high flow end cap. Rejetted the carb Installed Hunterworks Tri-Fire CDI Installed Hunterworks Clutch Sheave After all these mods I can do about 51 on the street before I run out of room. Gained just a tad on takeoff but not much to brag about. Was it all worth it? If I had to do it all over again, I would instead put the money toward a good pair of shocks. For what I do, there isnt much need for top end. Live and learn
www.dunechasers.com |
#11 (permalink) | |
Member # 8294
There just isn't enough hours in the day, but luckily there is enough hours in the day for a few beers.
