FugginZukin's RZR cage build - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Side by Sides
Old 06-20-2008, 08:01 AM   #1 (permalink)
FugginZukin's Avatar
Member # 75285
Hello All,
My inspiration to build this cage is the fact the stock one is a death trap. To start, the stock mounting pads for the stock roll cage are pathetic at best. I am beefing both front and rear up with some 3/16" steel plate. The rears will be held in place with four grade 8 bolts per corner. The fronts will be welded down.
FugginZukin is offline   Reply With Quote
Old 06-20-2008, 08:02 AM   #2 (permalink)
Member # 75285
Next step was to build the rear hoop. I wanted to maintain the stock lines except utilizing a hoop form.
Old 06-20-2008, 08:04 AM   #3 (permalink)
Member # 75285
Next step was working on the front mounting pads.
Old 06-20-2008, 08:05 AM   #4 (permalink)
Member # 75285
Forming up the pillars.
Old 06-20-2008, 08:07 AM   #5 (permalink)
Member # 75285
Working up some bracing, coping, and preliminary mock-up.
These tube clamps will be used in the front to be able to remove the front plastics.
That's all I have done for now. I will be working on it all weekend and hope to have it completed. More to follow. Let me know if you have any questions.
Old 06-22-2008, 01:55 PM   #6 (permalink)
Member # 75285
Built spreaders and some cross bracing this weekend. Cage will drop approx. 3/4" once I cope the bottoms of the cage to fit the mounting pads. Next will be work on the rear cross bracing as well as hooking up the 4 points.
Old 06-24-2008, 06:55 AM   #7 (permalink)
Member # 2787
Nice work!
UTVGuide.net
Crowdog is offline   Reply With Quote
Old 07-09-2008, 05:00 PM   #8 (permalink)
Jaggedx's Avatar
Member # 94515
Very nice!
www.jaggedx.com
623-780-5984
"Full line" dealer for all of your rock, desert, and sidexside needs.
Visit our online store: https://jaggedx.com/catalog/
Jaggedx is offline   Reply With Quote
Old 07-15-2008, 03:42 PM   #9 (permalink)
JW
Member # 222
Any progression on this? Nice work!
"See that double? Do that double!
If you start thinking about it, you'll never do it. People who think too
much end up living longer, making more money, vacationing in Tavarua,
marrying wisely and investing well-but they don't clear as many doubles."
budbuilt.com & highangledriveline.com
JW is offline   Reply With Quote
Old 07-16-2008, 07:32 AM   #10 (permalink)
Member # 75285
Originally Posted by Crowdog View Post
Nice work!
Originally Posted by Jaggedx View Post
Very nice!
Thanks guys. I appreciate it!
Had a rough past couple of weeks and wasn't able to do anything on the RZR. I will be putting in some work on it this week/weekend in which I will update the thread. Thanks for the interest.
Old 07-16-2008, 10:08 AM   #11 (permalink)
Member # 107373
Nice cage work.
I like your cylinder mount on your bender.
800, 302, c4, D20, jack stands
1wook is offline   Reply With Quote
Old 07-17-2008, 05:13 AM   #12 (permalink)
Member # 75285
Originally Posted by 1wook View Post
Nice cage work.
Thanks. The cylinder mount is just a 3" piece of pipe cut in half with two pieces of plate with holes for bolts welded to each end of the pipe to form a clamp. Then there is a smaller piece of tube (sleeve) that slides over the outside bolt of the bender that is attached to the 3" clamp. On the arm end there is a piece of tube (sleeve) that goes over the outside bolt of the arm that has an old steel socket that fit over the end of the ram rod welded to it. Wallah, done. I got the idea from OffRoadFabNet.
Old 09-21-2008, 01:54 PM   #13 (permalink)
Member # 75285
Finally was able to get some work done on this thing. I apologize for the delay. I have been extremely busy.
Old 09-26-2008, 02:19 PM   #14 (permalink)
Member # 75285
Got some more work done. Should be finished by Sunday. I'll be putting some paint on it tomorrow.
Old 09-26-2008, 08:18 PM   #15 (permalink)
Member # 2787
Damn. That came out really nice.
Do you do this sort of stuff for a living?
UTVGuide.net
Old 09-28-2008, 09:00 AM   #16 (permalink)
Member # 75285
Thanks man. I really appreciate it.
I wish I did this stuff for a living. Nah, I am just a hobbyist who tinkers in the garage once in a while.
Old 09-28-2008, 07:14 PM   #17 (permalink)
Member # 37089
Pretty freakin' sweet! Those are some nice fat welds on those joints. What thickness of tube are you using?
M&M Fabrications
stallion85 is offline   Reply With Quote
Old 09-29-2008, 06:29 PM   #18 (permalink)
Member # 7938
VERY nice indeed! Be sure to post up pics when it is painted and installed. How do you like the RZR?
KS Toy is offline   Reply With Quote
Old 09-30-2008, 03:06 PM   #19 (permalink)
Member # 75285
Thanks! The tube is 1 3/4" .095" wall DOM.
Thank you. I will have some painted and assembled pictures up hopefully by the end of the week.
I like the RZR so far better than other UTVs that I have driven in terms of performance. The power and the ride are great. The one negative I don't like is the build quality. I wasn't too impressed with the stoutness of the frame and overall quality of assembly. Overall I am happy with it however.
Old 10-01-2008, 07:38 PM   #20 (permalink)
Member # 2787
Well for just a garage guy, you do great work. Please keep the pictures coming.
UTVGuide.net
Old 10-02-2008, 11:44 AM   #21 (permalink)
Member # 46216
Send a message via AIM to shortsub
that thing looks awesome . really nice job!!
396 forged and rollerd' [U]small block[/U], propane, 60 /14 with chromos ,th400, ord doubler , HAD 1410s f/r , full hydro, lockd 42 sxs .... all wrapped up in a glittery package
07 d max LBZ with a fatgirl on the back
shortsub is offline   Reply With Quote
Old 10-02-2008, 01:36 PM   #22 (permalink)
leeman1790's Avatar
Member # 113084
Thats some excellent work, looks better then the stocker and of course hell of alot stronger. I'd imagine the frame would fail before the cage haha.
leeman1790 is offline   Reply With Quote
Old 10-03-2008, 06:29 AM   #23 (permalink)
Member # 75285
Thanks! Some new pics on the way.
Thank you.
Thanks. I agree, the frame would definitely fail before the cage. I have considered making a sub-frame to attach to the cage for the seats to bolt to. I kina feel uneasy having the lap belts attaching to the toothpick frame and the shoulder harnesses mounted to the cage. Maybe I will do that mod down the road.
Old 10-03-2008, 06:35 AM   #24 (permalink)
Member # 75285
Needed a way to attach the side/net bars to the cage, so I cut off the old mounts from the stock cage and welded to the new.
Got some paint on it over the past few days and have gotten the cage bolted to the RZR. I used Rustoleum black "hammered". It turned out pretty well. It is more of a dark gray than a black however. Matched the seats and plastic pretty good. Overall I am happy.
Next I will be making the harness mounts and a spare tire carrier that I had been planning to make. I will post those in this thread as well. I won't be active for the next week or so due to moving back to Arizona. Take it easy!
Old 10-07-2008, 06:10 PM   #25 (permalink)
Member # 7938
Looks GREAT! Can't wait to see it with the 6" lift and 32" tires!
