Member # 80991
toughest tire for sxs
Ive had atv's for years but never used many aftermarket tires. Looking to buy a rhino in the next few months and was wondering what are some good tires for it once the stock ones get worn. I live in east TN and will be riding mainly trails with rocks and roots. I only go through what mud i have to so don't care for any serious mud tires, just mainly looking for good traction and more so puncture resistance in sidewalls. I've heard that bighorns are pretty good but was wondering what else is available. Will probably go with stock size or maybe one inch taller, just don't want something that will kill the power.
Member # 94515
No question, Maxxis Bighorns by far the best aftermarket tire!
www.jaggedx.com 623-780-5984 "Full line" dealer for all of your rock, desert, and sidexside needs. Visit our online store: https://jaggedx.com/catalog/ |
Run For the Hills
Member # 44531
I run the Bighorns and like them a lot. Don't have enough experience across brands to say they're the absolute best .... Don't forget to change your air pressure to match the terrain and your driving style. UTV's are big enough that it makes a difference. I run beadlocks and relatively low pressure when rock crawling.
Check out The Union Creek Journal, a fictional, diary-style chronicle of a Midwestern family's struggle to survive in the aftermath of a global economic collapse. |
Newbie
Member # 80107
I've tried a few different tires. Right now I'm running 25" Goodyear MTR's, and so far I'm very happy! No punctures YET. the ITP XTR mud lites are HEAVY and pick up nails and small branches like there magnets, also are not that good in sand(river beds). A buddy of mine is running the Bighorns, we tore a side wall on a rock in the desert. Rode 12 miles back to the truck at +/- 20 mph with bead locks, stiched up the tire with safety wire, put on a patch and finished the day. My votes for the MTR's or Bighorns.
Edit: Bighorns measure about an inch over what they claim. 25"=26" 26"=27" Last edited by caffiend; 06-21-2009 at 01:20 PM. Reason: forgot something. |
#12 (permalink) |
Registered user.
Member # 108773
I had the same issue when mine were new. But after a good ride and you loosen up the rubber they work great. I have also put hole in the ITP 589's when they were new. But the Bighorns are the best tire I have ever used for rock crawling and snow. I've run then as low as 1.5 lbs and never had a problem.
Scott McCullough atvobbsession.com KI6MLH Last edited by Atv'er; 06-21-2009 at 06:55 PM. |
#13 (permalink) |
Member # 11961
I have had the bighorns on mine for about two years, they have more plugs in them than they have lugs. I think that a fox tail can puncture them. They are not tough, but work well.
#14 (permalink) |
Quit looking
Member # 138061
The ITP terracross's do well. The 589's that I have, have close to 1,000 miles on them and no plugs or leaks
Altman's Racing 1996 f250 D60, 10.25, 557bbf, bottle fed by giggle gas |
#15 (permalink) |
Quit looking
Member # 138061
From all my racing on bikes and quads I consider 2400 miles with 25% tread left great
#16 (permalink) |
In the desert, where high speed and rock strikes can be serious problems, some side x side racers are running General Grabber AT2 car tires. 26x14.
Check it out:
Baja Bomber, Mega Titan, Teal Brute You can do anything you dare to dream. |
#17 (permalink) |
Member # 54086
The new ITP BajaCross looks like a great tire. 8 ply and they say it's there longest wearing tire yet. I put a set on a full size Ranger and have been pretty impressed, I'll probably put them on the RZR when the Bighorns need replacing
#18 (permalink) |
Nothing against the Maxxis tires, it's just after one trip out in the desert, the stock wheels on my Rhino were junk. If you really drive a side by side hard, you will blow through the Bighorn's sidewalls fast and the wheel becomes the weak link. Car tires like the Grabber AT2s, or now discontinued BFG A/T are designed to hold up a much heavier vehicle, I think around 1,200-lbs per tire, so Rhinos simply can’t kill them.
The downfall is weight.
#19 (permalink) |
Member # 94515
From Our experience sidewall damage on UTV's generally comes from cutting or impaling by sticks or sharp rocks. The light truck tires by BFG, general or? still have verry thin sidewalls, and cut just as easily. Wheel damage usually comes from running too low a pressure at too high a speed. If you are going to be running high speeds in the desert I reccomend running anywhere from 15-20 psi, this will make your tires and wheels hold up much better, however it may tend to be harder on things like control arms and shock mounts. The best advice is to drive better. and try not to hit big rocks at high speeds. Esier said than done of course. as far as traction goes, any of the UTV tires like bighorns or baja Crosses or whatever will provide much better traction in rocks or loose dirt & gravel than the Light Truck tires. however if you are looking for wear the LT tires last way longer, if you don't tear them before they are worn out. More advice would be to cary a plug kit and portable compressor or another option would be Tireballs but they are quite pricey.
Check out any of these products at www.jaggedx.com we sell a full line of Viair compressors,tires, wheels, beadlocks, and also have spare tire carriers for any UTV.
#20 (permalink) |
Member # 11213
I have Highlifter MTS's and absolutely love them. I plow snow in the winter. The rest of the year I run rocks, roots, sand and mud. They are a pretty hard compound so they wear well. Heck, I made a 1 mile run up the shore of Lake Superior. We were running in about 20" of water on shale and jagged rock. I hardly slipped a tire and didn't blemish them.
~Carnage |
#21 (permalink) |
Quit looking
Member # 138061
Just an option if you guys didnt know about them is there is now a 15" atv rim made. I know they have the 4/110mm pattern which fits the rhinos. The rangers need the 4/156mm pattern which I dont think they make in the 15" rim. As far as I know the only 15" rim made though is the Buckshot. I dont particularly like the looks of it but I ran it on my last bog bike with 30x9.5 swampers and they held up great and hold the bead surprisingly well with low pressure even on rocks
