Rhino 660 clutching? - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Side by Sides
Old 09-02-2009, 10:04 AM   #1 (permalink)
Member # 11213
I have a Rhino 660 running on 28" MTS's. It runs pretty well in the mud and snow but I would like more low end out of it. I am also concerned that she is going to be a dog when plowing snow.
Is there a clutching solution that is less expense that purchasing a full kit? Can I mix/match OEM parts possibly? I have seen mention of using a white spring with Kodiak weights. Any recommendations for this specific application?
~Carnage
TrailCarnage is offline   Reply With Quote
Old 09-02-2009, 05:20 PM   #2 (permalink)
Mo
Everyday is Tuesday.
Mo's Avatar
Member # 47
I know nothing about their drive train, but what about swapping out sprockets?
Mo is offline   Reply With Quote
Old 09-02-2009, 05:55 PM   #3 (permalink)
Quit looking
Belooky's Avatar
Member # 138061
Rhino has no sprockets. The white secondary spring works great to keep the belt from slipping. The 4 kodiak weights, cant recall the measurement of them off the top of my head, will give your power back by keeping the belt on the primary pulley for the most power. I would get a machine washer and shim the primary to help "start off in a lower gear". By shimming the primary you will let the belt start off deeper in teh primary which will essentially give it a lower gear
Altman's Racing
1996 f250 D60, 10.25, 557bbf, bottle fed by giggle gas
Belooky is offline   Reply With Quote
Old 09-22-2009, 09:57 AM   #4 (permalink)
Member # 130882
clutch
you can buy an epi clutch kit for 200 bucks but you going to lose top end if that doesnt matter to you which it doesnt to me im running 28 outlaws with it and my top speed is 45 but the power is like having a 900 rhino lol
TOE123456 is offline   Reply With Quote
