rzr carrier - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Side by Sides
Old 09-30-2009, 07:02 PM   #1 (permalink)
Member # 62453
rzr carrier
i just recently purchased a used rzr and have been reading that the front carriers are very proned to breaking has anybody noticed this or had this problem also if so what replacment carrier would you suggest thanks
txwheeler is offline   Reply With Quote
Old 09-30-2009, 08:19 PM   #2 (permalink)
Member # 2570
Send a message via AIM to On_The_Rocks
I have heard of some problems, but I have had 2 rzrs and over 1500 miles with out any problems. Those miles include the rubicon and fordyce, along with some sand dune riding too.
Ram 3500 4x4 5.9 quad cab, Banshee 4 mil 100hp, Rzr, LT sandrail
On_The_Rocks is offline   Reply With Quote
Old 09-30-2009, 09:19 PM   #3 (permalink)
Member # 137143
Keep fluid changed regularly and ride that baby til it breaks! Got over 1500 miles and counting.... THE AIR FILTER IS WHAT U NEED TO WORRY ABOUT!!! They leak dirt past the filter!
auto_B is offline   Reply With Quote
Old 09-30-2009, 09:28 PM   #4 (permalink)
Member # 33464
http://www.ocperformancemotorsports....ller-cage.html
66cummins is offline   Reply With Quote
Old 10-01-2009, 07:44 PM   #5 (permalink)
Member # 62453
thanks im getting ready for a halloween ride and have been hearing the storys just didnt want it to ruin the weekend but it sounds like i'll be ok
Old 10-01-2009, 07:47 PM   #6 (permalink)
Member # 62453
ya when i got it it had a blown motor do that but i went ahead and had a snorkel installed hopefully that will do the trick also as far as the diff fluid goes what are you using just regular gear lube?
Old 12-03-2009, 06:51 AM   #7 (permalink)
Member # 137143
In the front I run Polaris AGL stuff just cause I have only found it by other companies in a 1 to 2 gallon form (Tractor hydralic fluid of some sort???).
In the the rear synthetic 75w90 gear oil of ur choice. I have had good luck with the Lucas or Castrol...
Old 12-03-2009, 06:01 PM   #8 (permalink)
Member # 135736
All of my friends and I with RZR's have toasted our front ends. There is a plastic cage that breaks in the front end. Here is a new alum cage ALOT cheaper and I have talked to several people with it and it has taken care of there front diff carriers.http://www.superatv.com/POLARIS-RZR-...-P465C245.aspx Our front ends breaking has nothing to do with changing oil. If you land on the front end in AWD with any power going to the front end you will hear it chatter and pop. Enough times of that and you will bust that front plastic cage.
COPPERHEAD42 is offline   Reply With Quote
Old 12-06-2009, 04:32 PM   #9 (permalink)
Member # 123202
I've heard that sound a few times but it's still holding together, for now.
mudevil is offline   Reply With Quote
Old 12-06-2009, 05:47 PM   #10 (permalink)
Member # 135736
Ya its just a matter of time before it goes out. It has alot to do with how you drive it. Most of our climbs have lips at the top and we have to jump out of them
As long as you dont land on the throttle your fine but sometimes you have to stay into it. I got about a year out of my stock cage but I have had friends that broke theres in the first weekend they got them.
Old 12-06-2009, 06:12 PM   #11 (permalink)
Member # 123202
That's exactly what I'm doing with mine when it chatters and pops.
Old 12-07-2009, 06:23 PM   #12 (permalink)
Member # 132156
Many people whop ride the chit out of their RZR have done this including me. Here is a link to a better quality yet cheaper price aftermarket cage, you should also chang out the armature plate with it. It will ensure that your awd works the way it is supposed to.
http://jjandaracing.com/
Deez Nutz 08 is offline   Reply With Quote
Old 12-11-2009, 01:40 PM   #13 (permalink)
Run For the Hills
Mudinyeri's Avatar
Member # 44531
I agree with Copperhead. Keep your foot out of the throttle when you land jumps and you'll be fine for a long time.
Check out The Union Creek Journal, a fictional, diary-style chronicle of a Midwestern family's struggle to survive in the aftermath of a global economic collapse.
Mudinyeri is offline   Reply With Quote
