custom built SxS
ok, i have decided that since the deal fell through on the yota i was getting, i'm going to build a small buggy. i think this fits in this section best because it will be 80" wb, less than 65" wide and be set up like a SxS.
will have a geo 3 cylinder w/ auto transaxle rear mounted with the trans toward the front, driveshafts will come right off the trans to a pair of flipped 8.8 IRS diffs with 4.10's, i will be using thunderbird spindles/halfshafts on the back, but will have to figure out what halfshafts/spindles to use up front. seats will be mounted over the transmission. i will make this my build thread when the parts start pileing up. |
Not sure if you've seen it, but I remember this one from a while back and it seems semi-like what you're doing. Might be able to pull some ideas, or what not to do.
Kid's buggy
Originally Posted by Co Pilot yeah.... your wifey poo cant wear all the pretty pantys she wants.. but if she aint giving it up... whats the point? quote: He could have used a bigger hammer though, and then things break faster so you can move on to the next step of cussing quicker. |
i have read that thread start-finish 2 or three times. running a honda engine like he did would make it where i could run the diffs unflipped because they run backwards from a regular engine, but i really like the compact size of the g10 suzuki engine/trans setup
