Member # 121293
No, but I've thought a lot about building one that way.
I'm thinking of building high clearance "arched" style aluminum housed solid axles using UTV IFS components for extra clearance with coil-over/link suspensions at both ends and use an Outlander/Renegade 800 power plant and keep it as close to standard Rzr sized as possible. I have an 800 Outty and love the power, .
'85 4wd S10, ECLB with an '05 LLY Duramax/Allison, Locked 1 ton's, air-ride, 38's, & twin 241'.s |
Member # 148385
Well I still think in time the mfg'ers will put some sort of straight axle back in the utv market. Seems though (as capable as it is) the rzr is the only one out that will do west coast sand and rocks and east side mud and slick rock but not as good on rocks as it is in the dunes. Look at the competing rigs in rock competitions around the country.... very few are using ifs. Also look at Utv KOH race. all ifs but alot of major breakage too. people on my side of the country are asking for bigger and bigger tires with more and more power. hell the first thing people did with the xp 900 is start supercharging and turboing these things right out of the box. you can't even begin to compete in sand without one anymore. So I still think in time we will see a link suspension on solid axles from the factory. only time will tell. untill then what would you use, dana 20, 30-or 44. maybe a ford 8" or 9" cut down. maybe a late model jeep axles? sure would make gearing down for bigger tires alot less expensive and easier to do. wouldn't have to spend so much money on clutches and engine mods. I say run with it.
Member # 163263
A friend and I have talked about solid axles in his prowler and he mentioned samurai axles since he could get them easy enough and keep it narrow. An idea that I had although it would depend on the use as far as the gearing is to run a set of small 4wd tractor like kubota front axles on both ends, they have the diff centered like a sxs and would give you lots of ground clearance and plenty low gearing. I dont think the strength would be an issue although finding them could be.
2001 TJ 4.0 Nv 4500 Six Inch Longarm, 4:88's,4:1 Lowgear set, Rear Arb, Chromo Superior Shafts |
Member # 148385
I like this idea especially since Longfield builds a hell of a setup for Yota's. suck about 150-200 hp out of a new 900 or swap for a KMV4 V4 and you would definately have enough to eat up a set of 33's
#8 (permalink) | |
Member # 151571
No actually i would use suzuki samuria or geo tracker axles. they are light weight, about the right size, probably strong enough for the abuse it will see and they come stock with 5.13 gears and some of the rears come with a posi |
Member # 50866
ive seen a few, with samurai axles, one with rockwells/ scs drop box/ rice and canes, even one with a samurai motor/ trans/ tcase/ and axles.
I currently have no rig.
#12 (permalink) | |
Rope Dude
Member # 122622
I wish I could get him to get on here.
Todd Custom Splice- AmSteel Blue Winch Ropes We Stock - Safety Thimbles, Tube Thimbles and Excel Hooks Office- 785 856 1844 Cell-580 504 1405 Need WINCH Rope? pirate4x4 is the secret code in the store for free shipping. Have you seen APE EATER RACING's site |
#13 (permalink) |
Member # 159226
im in the process of building a sxs with solid yota axles, its goin to be fully custom with a yamaha 920cc v-twin, cantilever suspension, ranger xp t-case, ive narrowed the yota axles 6" total. im about to start building the links for the axles and then position the engine. im hoping to run 33's, chassis is 56" wide and 108" long.
87 sammi, 400/400/205, d60/14b, 5.38's, full spool, 42" rockers |
#15 (permalink) |
Member # 159226
no, what yall see is all i have done right now, waitin on parts to start the links. goin to do double triangulated front and rear. in the process of workin on how the steering is goin to work, thinking about using a powersteering setup out of a boat.
#16 (permalink) | |
Member # 53528
#17 (permalink) |
Member # 159226
cut the knuckles off, cut the front axle long tube 6" and the rear axle tube 2" on each side and welded the knuckles back on, its a little diffifult with the front axle cause it had a truss from the pumpkin almost all the way out to the knuckle on the long side, sent the new lengths off to get new chromoly axles made for it. the front axle housing is almost the same length on each side now but that worked out perfect for the drive shaft running between the seats and lining up right. ill post pics when i get home tonight
87 sammi, 400/400/205, d60/14b, 5.38's, full spool, 42" rockers Last edited by camarohrod; 07-06-2011 at 03:09 PM. |
