small u joints.... - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Side by Sides
Old 09-11-2010, 07:32 PM   #1 (permalink)
necronomikon's Avatar
Member # 26695
small u joints....
Top U joint blew, bent my steering column, polaris DENIED to warranty "damage not done from defect".Screw polaris and screw my dealer harder(but that's a longer story).
Is there a place to get just the u joints for the steering column without having to buy the entire assembly?
If I had to guess, the u-joint is about 2-3 inches or less across(haven't pulled and measured yet.
It's the joints for number 19 on the schematics.
Would like to be able to replace the joints, press the bar straight again and sheath it for strength...... what say you guys?
necronomikon is offline   Reply With Quote Quick reply to this message
Old 09-13-2010, 09:39 AM   #2 (permalink)
Member # 7753
I'm sure you can. Often the u-joints in steering are held in by a little peen on the ear, grind the peen off with a dremel and it will press apart like a driveline one.
I wouldn't bother sleeving, its the broken u-joint that is the problem it sounds like. You could buy some bigger ears to weld on and go with a bigger u-joint.
Slowzuki is offline   Reply With Quote Quick reply to this message
Old 09-13-2010, 11:19 AM   #3 (permalink)
KyleQ's Avatar
Member # 83837
Replace it with a D60 long side
Sucks that your dealer and the manu. told you to pound sand...
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60, Powr-Lok 70U - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 43" TSL SX on H1 Beadlocks
KyleQ is offline   Reply With Quote Quick reply to this message
Old 09-13-2010, 12:36 PM   #4 (permalink)
Member # 143821
Kartek has steering shafts and components, you might check their catalog and see if they have anything that works.
http://www.kartek.com/
Darryl89 is offline   Reply With Quote Quick reply to this message
Old 09-13-2010, 01:26 PM   #5 (permalink)
TrailTamer XJ's Avatar
Member # 140878
Farm supply store have small u-joints that can be had cheap. Might want look at them and see what it takes to swap them. I'd not be concerned about how perfect you weld the yokes on the shafts as they don't spin fast at all.
You can't say that you have wheeled hard till you have broken something or gotten stuck.
TrailTamer XJ is offline   Reply With Quote Quick reply to this message
Old 09-13-2010, 04:15 PM   #6 (permalink)
Member # 26695
Cool, ill check out those places. Lesson learned on warranties though. That 900$ coulda gone a long way elsewhere.
Old 09-27-2010, 02:27 PM   #7 (permalink)
95rokrunner's Avatar
Member # 97376
they tried that same shit with me, I had two broken front axle shafts
they said it was from abuse, I told them the first one wasnt but then I only had 3 wheel drive and still had to get home so the 2nd one might of been
they bitched and whined for 2-3 weeks and then finally covered it after multipule calls to me with multipule excuses.
I agree with ya polaris warrenty
what is crappy is I broke another front shaft and have to take it back in, we'll see how it goes this time around...
Team DuraLine rock crawling
2012 W.E.ROCK National Champions
2013 W.E.ROCK Western Series Champions
4522 Trail-Gear F-Toy
95rokrunner is offline   Reply With Quote Quick reply to this message
Old 11-04-2010, 08:06 PM   #8 (permalink)
Member # 162188
current Volvo semis and others use spicer part numbered universal joints. Call ur local spicer dealer, or Tom Woods??... and give them cap and cross dimensions. bet they make them. esp since they make the transmission and diffs in your RZR
adam.k is offline   Reply With Quote Quick reply to this message
Old 11-14-2010, 12:45 AM   #9 (permalink)
Member # 163388
Have you tried jumping on the RZR forums and checking if someone has one laying there in their garage?
I did it with long travel suspension, and scored a fairly good deal
Dosn't cost anything to ask!!
SomeGuyFromOlympia is offline   Reply With Quote Quick reply to this message
Old 11-28-2010, 04:40 PM   #10 (permalink)
Team 261 - VP
atvobsession's Avatar
Member # 31923
Just some advice. If you break a front shaft on either Polaris Sportsmans/XP or the RZR, after you secure the shaft, turn OFF the AWD so you are only in 2WD.
If you leave the switch on...anytime (and it could be for no really good reason at all) the rear wheels spins for 1/5 of 1 revolution (20%) the front locker will engage...putting my MAJOR strain on the other axle and possibly messing up your earlier broken axle that you may have tied up with zip strips or otherwise.
Regards,
Ken Hower - KOH #1962 Close Enough Racing/KOH #4899 Legends
Rubicon Trail Foundation - Director 2011-Present
Thanks to
for being the primary sponsor for the 2016 Cantina For The Con!
atvobsession is offline   Reply With Quote Quick reply to this message
Old 12-08-2010, 03:23 PM   #11 (permalink)
Member # 97376
agreed, like I said though, in this instance I still needed the remaining front wheel to get back out of were I was. once I got back out it was rear locked for the rest of the weekend
