Cheapest simplest way to mount a winch to a samurai? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-11-2011, 08:41 PM   #1 (permalink)
Member # 201895
I am about to buy a winch for my samurai and was wondering what is the best way to mount the winch to the old sammy. I am on a pretty tight budget so I am trying not to by like $600 bumper
Boardboy is offline   Reply With Quote Quick reply to this message
Old 12-11-2011, 08:48 PM   #2 (permalink)
Member # 43395
Weld a piece of plate to the front frame horns. Brace with angle.
gi_zuk is offline   Reply With Quote Quick reply to this message
Old 12-11-2011, 10:49 PM   #3 (permalink)
Member # 156317
yup you can do it that way. Im moding an old tow bar that came with mine with some 1/4 inch plate steel to make a bumper just a little wider then my frame rails to hold a winch.
1988 TinTop
facebook.com/NORCALZUKS
Beans is offline   Reply With Quote Quick reply to this message
Old 12-12-2011, 09:28 AM   #4 (permalink)
Member # 693689
I capped the ends of the frame rails using some 1/8" plate. Then used a piece of pipe bent into U. Then used some brackets I made at work and welded them between the factory frame tube and the U piece I made. I've got about nothing invested in the mounting, and it is tucked up nice and close for a good approach angle.
DannyK is offline   Reply With Quote Quick reply to this message
Old 12-12-2011, 11:10 AM   #5 (permalink)
catzuk's Avatar
Member # 44135
Ratchet straps.
87 Zuk, dana 44's w/5:38 detroits,coils/3 link frt, 3 link rear 37" Krawlers
87 Zuk, SPOA, Lockrights f/r, 31" Cooper Stt Pro's. shaved and trussed stock axle housings,1.6 8V, fuel injected, 4.89 t-case
catzuk is offline   Reply With Quote Quick reply to this message
Old 12-12-2011, 11:11 AM   #6 (permalink)
058hamer's Avatar
Member # 24417
Velcro.
058hamer is offline   Reply With Quote Quick reply to this message
Old 12-12-2011, 11:15 AM   #7 (permalink)
Sledgehammer83's Avatar
Member # 185165
I was going to say self tappers but I like DRKelly's idea better.
47' CJ2A V6, SM420, D20
1979 F250, Dana 60's, C6/NP205 15k original miles (awaiting diesel swap)
Sledgehammer83 is offline   Reply With Quote Quick reply to this message
Old 12-12-2011, 01:00 PM   #8 (permalink)
Member # 42266
pop rivets?
88 Samurai: 39.5 Iroks, 5:29's 6.5:1, 16v 4spd
txzuk1988 is offline   Reply With Quote Quick reply to this message
Old 12-12-2011, 01:05 PM   #9 (permalink)
Member # 125093
The plastic push in things that you use for door panels?
zukyack is offline   Reply With Quote Quick reply to this message
Old 12-12-2011, 04:12 PM   #10 (permalink)
jknight76's Avatar
Member # 174252
gum
88' sammi SPOA, Winch, 31"MTZ's,-That's It, all I've Got!
jknight76 is offline   Reply With Quote Quick reply to this message
Old 12-12-2011, 04:25 PM   #11 (permalink)
jr4x's Avatar
Member # 94747
Plumbers tape is cheap
jr4x is offline   Reply With Quote Quick reply to this message
Old 12-13-2011, 09:13 AM   #12 (permalink)
Member # 162145
http://www.ebay.com/itm/KFI-Products...item25694730eb
$61 free shiping E BAY.....Boxcar...
God Bless
boxcar is offline   Reply With Quote Quick reply to this message
Old 12-13-2011, 10:57 AM   #13 (permalink)
Member # 42266
Sheetrock screws (drywall screws.. eh!!)
Old 12-13-2011, 08:53 PM   #14 (permalink)
Member # 72294
Tack welds / Boxcar has an idea you could cut weld and end up with a pretty kool and strong mount.
86 S/T 6.4, 5:13 diffs,yota P/S Spooled & locked
86T/Top 6.5,5:13 Diffs,yota P/S, Spooled & locked
87S/T EXCO,6.5,5:13,Welded,Locked,yoda P/S :flipoff2::flipoff2: BLAH,BLAH,BLAH,ETC,ETC.
MAD ZUKS-Modified & Aggressively Driven
SUZUKI SAMURAIS
1madzuk is offline   Reply With Quote Quick reply to this message
Old 12-13-2011, 09:45 PM   #15 (permalink)
Member # 17632
If you can't weld or do your own fab, there is no cheap way. The easy way is to pay someone to do it. That mount that boxcar posted up is for ATV winches, too small for what you want.
Travis..
'15 Ram 2500 4x4 Big C and a 6 speed
2000 TJ on 35's
crashnzuk is offline   Reply With Quote Quick reply to this message
Old 12-14-2011, 06:29 AM   #16 (permalink)
Member # 114559
Check local u pull it places for universal winch plates. If you do find one it will still need some Fab/welding done to it to make it work. Or you could get a zor bumper that bolts right up.
http://www.zuksoffroad.net/images/Fr.../prefab_01.jpg
if it isnt broken, fix it till it is
Wildfinger is offline   Reply With Quote Quick reply to this message
