looking for idea's for daily driver - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-21-2012, 11:57 AM   #1 (permalink)
Member # 160386
Im getting ready to drop in a 2.0L And im looking for ideas for the drive train its a daily driver huntin rig. Im currently running 1.6 l 8v with 2 wheel drive trans 4.89 t-case stock rear with arb disc brakes front stock with arb i bought chromo axles for the front with 32 inch buckshots. Since im going 2.0l im thinking i need to upgrade the drivetrain and still keep it streetable at 70 mph and i may tow a 13 ft scamp camp trailer that weighs 1400 lbs open to ideas im thinking 44s on both ends with arbs
harf69 is offline   Reply With Quote Quick reply to this message
Old 02-22-2012, 09:10 AM   #2 (permalink)
Member # 101414
toy axles would be alot easier then d44's if u wanted to keep it simple.the older toy rear axles are closer to your width then the d44's
WOODZUK is offline   Reply With Quote Quick reply to this message
Old 02-24-2012, 12:32 PM   #3 (permalink)
Member # 48911
keep the motor and your axles, drop in some automatic lockers, and forget about towing. you'll be happier and richer if you do. I don't think it's a question of horsepower or gearing, the samurai just doesn't weigh enough to pull that weight safely. I did it in mine, and it wasn't entirely safe, the brakes just aren't up to it. you'd really need some trailer brakes, I mean, if you were going down a mountain on a steep pass, the sammy's brakes are just barely good enough for it alone. they overheat quick.
. I was coming down a steep hill once with 3 football players in my rig and my brakes became useless before I even got to the bottom, never want to do that again.
4.3v6,t18,dana18, ford/chevy driveshaft, chevy front in front, chevy front in rear
cajunsuzukispider is offline   Reply With Quote Quick reply to this message
Old 02-26-2012, 04:53 AM   #4 (permalink)
Member # 160386
The trailer has brakes my dad has been towing a scamp trailer from wa to idaho montana nevada with a 1.6 8 valve 2wd kick trans and 235/75/15 tires. can u run toyota axles and make it drive straight down the road. Can u get the offset right
Old 02-26-2012, 06:57 AM   #5 (permalink)
jstop's Avatar
Member # 11097
http://www.trail-gear.com/samurai-axle-housings
Jim Stopinski
http://www.kifourwheelers.com
jstop is offline   Reply With Quote Quick reply to this message
Old 02-26-2012, 08:05 AM   #6 (permalink)
talonxracer's Avatar
Member # 194195
Upgrading to 4dr sidekick front rotors and calipers is a fantastic upgrade for when keeping the stock axles, you can actually drive around in the mtns and not loose your brakes on every downhill trail.
I took an oath to defend the Constitution, not the Govt !!!
talonxracer is offline   Reply With Quote Quick reply to this message
