What clutch to run on a 16v swap? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-29-2012, 03:48 PM   #1 (permalink)
Member # 72167
Any input on clutches people have used and like and dont like? Im putting a 16v in my sammy stock samurai tranny rebuilt, rebuilt engine. Is a oe replacment samurai clutch enough to hold that power? Or Stage 2, ceramic, ebay clutches, etc?
thanks ken
hotrodd64 is offline   Reply With Quote
Old 03-29-2012, 03:58 PM   #2 (permalink)
Member # 8284
Back before TT had there own line of clutches, I was recommended a stnd. Samurai clutch when doing my swap. Today, who knows...
DemoMike is offline   Reply With Quote
Old 03-29-2012, 08:11 PM   #3 (permalink)
Member # 16608
Do a little research...when I swapped in my 1.6L there were two options for clutches...
Seems like 2-door VS 4-door??
Anyhow, one is bigger in diameter...7 7/8" versus 8 1/2"
Use the big one.
I'm feeling generous tonight...I might search for a part# for you.
'88 Zuk
TatorZuk is offline   Reply With Quote
Old 03-29-2012, 08:13 PM   #4 (permalink)
mannysouza's Avatar
Member # 22726
centerforce
The more things you own, the more they own you!
mannysouza is offline   Reply With Quote
Old 03-29-2012, 09:31 PM   #5 (permalink)
Member # 72167
Ya a centerforce would be my first choice but 300 bucks is a little more than I have to spend now, and I'm not running the sidekick tranny so I'm stuck with the samurai flywheel and clutch options, I will probably go with a stage 2 off fleebay, see how it is. I just wondered about ceramic clutches because there's a butt load on eBay, and it seems ceramic would grip better, but then again that could be a bad thing
Old 03-29-2012, 09:48 PM   #6 (permalink)
Member # 93886
Center force dual friction.My wife drive mine some times and I get on her for slipping the clutch at timesany thing less would not be good.
88 Samurai D44,Spider 9",Detroits,33 TSL's
zuk1988 is offline   Reply With Quote
Old 03-29-2012, 11:33 PM   #7 (permalink)
Skandinavisk pirat
ShuDuck's Avatar
Member # 30288
petroworks clutch if you run the 1.3 flywheel. supersmooth and strong, I have used it on 1.6 16v, 1.3, and 1.9 TD
centerforce is
ShuDuck is offline   Reply With Quote
Old 03-30-2012, 06:51 AM   #8 (permalink)
Member # 121943
I just put in TT Vulcan clutch. It has a couple snow wheeling trips on it with good results. Headed to Moab next month for a real test.
64rcs is offline   Reply With Quote
Old 03-30-2012, 10:54 AM   #9 (permalink)
Gives Zero
red90runner's Avatar
Member # 35527
Send a message via AIM to red90runner
I have a petroworks clutch I'm looking to sell. Its in great shape, low miles, just upgrading to Toyota drivetrain. pm me if interested.
edit: SOLD
-Pat
Polygoats Offroad Club
red90runner is offline   Reply With Quote
Old 03-30-2012, 12:18 PM   #10 (permalink)
Member # 72294
PERTOWORKS no others compare have it in all 3 of my rigs. If your using the 1.3 trans.
86 S/T 6.4, 5:13 diffs,yota P/S Spooled & locked
86T/Top 6.5,5:13 Diffs,yota P/S, Spooled & locked
87S/T EXCO,6.5,5:13,Welded,Locked,yoda P/S BLAH,BLAH,BLAH,ETC,ETC.
MAD ZUKS-Modified & Aggressively Driven
SUZUKI SAMURAIS
1madzuk is offline   Reply With Quote
Old 03-31-2012, 04:34 PM   #11 (permalink)
Bobula's Avatar
Member # 138416
Send a message via AIM to Bobula
I have the same question. Thanks for the info
Bobula is offline   Reply With Quote
Old 03-31-2012, 04:47 PM   #12 (permalink)
mannysouza's Avatar
Member # 22726
I hope petroworks clutch is better than all of their other crap they sell
I love their engine mounts that look like a kid welded them up, cause drivetrain vibrations and their t case gears we have removed from three samurai's that would lock up when unless you leave out the center detent ball.
I wouldn't recommend them to anyone.
Old 03-31-2012, 07:59 PM   #13 (permalink)
Member # 16608
Sometimes a ceramic clutch can act like an "on-off" switch when they engage...
Find a cheap, stock Sachs on the "net" and run that...
'88 Zuk
