#1 (permalink) | |
Whatever Works
Member # 128472
What should idle be?
88.5 1.3 Samurai. Stock engine.
I turned it up a bit before the run the other day. I use to idle around 300 rpm. Now its up to 1200ish. Is that high, or did I just get accustomed to a stupid low idle?
Samurai Build on a Low Buck Budget: The Tin Can Quote:
Member # 67110
Search?
I believe spec is 800 RPM, I like mine closer to 1k. Set it where ever you like it
[URL="http://www.pirate4x4.com/forum/showthread.php?t=829327"]one more Samurai build[/URL] |
#3 (permalink) | |
Member # 147031
Unless your engine runs extremely well on low revs i'd set it around 900-1000. Kinda depends on your driving style i guess
#4 (permalink) | ||
Whatever Works
Member # 128472
http://www.pirate4x4.com/forum/searc...rchid=11682136
Every topic there, unless I skipped over it dealt with rough idle or idle issues. I was just curious what it supposed to be "stock". Quote:
I did turn it up. Its about 1100ish now. I guess I'm just not used to it that "high". ![]() Thanks.
