Member # 203733
I dont know what to...zinc
Can someone please clear up exactly what the deal is with zinc additives and flat tapped cams. I know that it is important to use additives when the engine is being broken in, But now with nearly 5k miles on my rebuilt 1.3, Do i still have to put in a zinc additive now that zinc phosphate is no longer in conventional motoroils or is this all hubbub
Member # 80727
Either run "offroad" Valvoline race oil that still has zinc in it or put zinc additive in with every change.
Every motor with a flat tappet cam needs zinc in the oil ALL THE TIME. Break in is just the most crucial point. Although you may get away with it for a long time, not having zinc in your oil will cause your cam and lifters to wear out prematurely.
1994 Isuzu Trooper: OM617/W56/toybox 4.56 Dana 44 w/ lockright/6 lug Ford 8.8 4.56 Ox locker |
Member # 141230
What a second here, dose this mean I should also be putting some sort of zink additive in when I change oil also. I have never heard of this and have been in the automotive industry for years now. I also have a few flat tappet engines, never added anything to the oil and haven't had any issues.
Member # 141230
Check this link out. It has some usefull info I think.
http://www.valvoline.com/faqs/motor-oil/racing-oil/ |
Member # 22726
I use the racing valvoline also and some say that the zinc will help keep a motor running if the engine starves for oil. I guess it bonds with the metal to make a coating. I'm not an engine builder and this is heard second hand to take it for what it is worth.
However, the racing valvoline doesn't have as much cleaning additives so frequent oil changes are needed.
The more things you own, the more they own you! |
#6 (permalink) | |
Member # 106179
DO NOT DO BUSINESS WITH SHAFFERS OFFFROAD. BUYER BEWARE |
Member # 17632
I run diesel oil in my flat tappet stuff. Though it doesn't have as much as it used to, it has way more than the current pass car oil.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s 91.5 Dodge 6BT 5 spd tow rig |
Member # 1602
Mark E. San Jose, Ca *SOLD* 75 Ramcharger 440, blah, blah *SOLD* 66 Welder Bill't Bronco Rockbuggy 06 CTD 87 Buick Grand National X2 65 Vista Cruiser GN Turbo V6 powered |
