Instrument cluster dead. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-01-2012, 01:44 PM   #1 (permalink)
Wheelin Junkie
Sami17649's Avatar
Member # 173883
I'm going to scream! First the starter will not work... Checked again and missed the little wire on the bottom, and the starter now works. Still not starting up tho. But now the instrument panel doesn't light up. (like the ALT and other lights just below the gauges) I can deal with spark issues, but this is confusing me to no end.
Its an 88.5 Sammy. All the fuses are good. All connectors plugged in, no cut wires. Radio still turns on and off with the key (aftermarket). Checked the service manual and, 'yes' I have been using the magic search button. Still no bueno... Is there a relay for the gauge cluster or a fuse somewhere that I don't know about?
Rusty stock '88.5'. Stage 1. Work in progress.
Sami17649 is offline   Reply With Quote
Old 07-01-2012, 06:59 PM   #2 (permalink)
Member # 162431
Check your grounds and make sure they're good, maybe even make a few of your own. Remember you need:
*motor to frame ground(s).
*motor to body ground(s).
*frame to body ground(s).
more the merrier!
1995 2dr. 4X4 16V Geo Tracker
SOON TO BE: BADASS BUGGY!
ColtonW is offline   Reply With Quote
Old 07-01-2012, 10:09 PM   #3 (permalink)
Member # 146619
you are talking about the lights inside the cluster ? if so its probly the dimmer, give it some slap and it works for me probly is your probleme if its not a ground prob
zougail is offline   Reply With Quote
Old 07-01-2012, 11:08 PM   #4 (permalink)
Member # 221019
ya if its just the lights then check your dimmer and then there 3 wires under the dash (kinda where the steering tube mounts ) male/female type i wanna say there red,white,blue ceck to see if there unplugged or just pull the cluster and follow them
209wheeler is offline   Reply With Quote
Old 07-03-2012, 04:40 PM   #5 (permalink)
Wheelin Junkie
Sami17649's Avatar
Member # 173883
I checked the grounds and added some more. Still nothing. The lights in the gauge cluster light up. And the dimmer works fine. Its the display just below that that has all the warning lights on it that no longer works. Also I just realized that the solenoid on the carb no longer makes any clicking noise when i turn the key... that quit working at the same time too.
Old 07-04-2012, 09:06 AM   #6 (permalink)
Wheelin Junkie
Sami17649's Avatar
Member # 173883
Fixed! Almost dont believe it. A fuse that dosent look blown whatsoever was the problem. It wasnt charred, damaged, dirty, cracked, nothing. It looks just fine. It just didnt work. I have never seen that happen before.
