Top speed with a carbed 8 valve? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-19-2003, 04:37 PM   #1 (permalink)
Member # 2816
So I've heard that to run freeway speeds I need the 16 valve but a guy I know has a carbed 8 valve and he says he can go 80 down the freeway with 38's on so what gives? What are your impressions of the 8valve motor and is it worth the hassle of dumping a EFI 16 valve motor in. Also anyone have problems with their carb? I know some carbs are a little more finiky than others. What is it like for rockcrawling? Thanks
erik
Big Girls Don't Climb...
TheNerple is offline   Reply With Quote
Old 02-19-2003, 05:40 PM   #2 (permalink)
Member # 10934
I know i`m a FAWKEN` NEWBIE, but the only way a sammy goes 80mph with 38`s is OFF A FAWKEN CLIFF WITH A TAILWIND!!! LOL!!!!!
I might be a newbie but I`ve read this board for a looonnnggg time!(I just have`nt had a smart ass comment yet)
okezuki is offline   Reply With Quote
Old 02-19-2003, 08:20 PM   #3 (permalink)
Pappa Smurf's Avatar
Member # 12401
Send a message via AIM to Pappa Smurf
i all depends on what gears he has and what he's done with the motor
my dad has gone 95.4 mph acording to the gps the speedo said 90 and this with 33's and 6 to1 's with his 8 vavle 1.6
it was pushing 5 grand in 5th we could have gone faster
Toyota axle parts www.pirate4x4.com/forum/showthread.php?p=8789642#post8789642
Pappa Smurf is offline   Reply With Quote
Old 02-19-2003, 08:39 PM   #4 (permalink)
Member # 16115
Send a message via AIM to skurbs18
My top speed is about 55mph. I am sittin on 31's with stock gears and an 8v 1.3. It won't even pull 5th and it dosen't like 4th on a small incline. I plan to get a t case gear kit soon so that should help it a bit. Fortunately mine only sees road use in between mud holes. I don't think I would feel comfortable doin 80 in my zuke
skurbs18 is offline   Reply With Quote
Old 02-19-2003, 09:45 PM   #5 (permalink)
Vermin's Avatar
Member # 6524
GRS1 tcase + 5.38's + 33's = serious rpm for freeway action. And no, it's not photoshopped.. but the speedo is off about 8mph at that speed. GPS said 81mph.
Vermin is offline   Reply With Quote
Old 02-20-2003, 01:09 AM   #6 (permalink)
Member # 9386
Send a message via Yahoo to zukikid
i love 1.6 8 valves...i've blown up 2 of them i am going to run a swift gt engine.
zukikid
p.s. i could run allday with 33's and 5.12s at 65 miles an hour...no down shifting. i had a 1.6, weber,header,cam
"life is not convenient"
[QUOTE][i]Originally posted by littlejackass [/i]
[B]aaaahh come awn care bears rock! :D [/B][/QUOTE]
zukikid is offline   Reply With Quote
Old 02-20-2003, 03:33 AM   #7 (permalink)
Member # 12382
top speed
i runing 31 10.50s 4.625 gears with a 2 inch exaust and a webber on my 8 valve and the highest rpm ive seen on the flat and level is like 5200 rpm....thats cruzin
steamy pile on 33,s
rabidray is offline   Reply With Quote
Old 02-20-2003, 05:42 AM   #8 (permalink)
Member # 17151
Do the 1.6-16V. You'll be MUCH happier. I have 2 Zuks, 1w/8V and 33 inch tires and 1w/16V stock height. I can peg the speedo in the 16V - figure I'm doin' about 110mph. I can hit about 80 in the 8V on a looooong stretch.
Capn_Crunch is offline   Reply With Quote
Old 02-20-2003, 09:01 AM   #9 (permalink)
Member # 16401
Send a message via MSN to kd7srj Send a message via Yahoo to kd7srj
5.13's 35" radial claws 1.3 stock except for a thorley and a hi-flo cat 60 mph per gps in 4th gear redline
85 toyota P.U.caged, Bobbed, chevy rears, 529's
,rearmains up front, spools, crossover steering, limited to 33's till I get longfields, changing birfs on the trail sucks.
kd7srj is offline   Reply With Quote
Old 02-20-2003, 10:05 AM   #10 (permalink)
Member # 8601
My LWB Sam: 5.12s, stock engine with Aisin carb, stock t-case. I can pull 120-140 km/h all day if I want. We don't have the mountains that you west coasters do though.
SWB: 4.62s, header, Mikunnis, 31s. Point and shoot to any speed or gear until the engine over revs and blows up.
If you are starting with a clean sheet of paper go EFI 16V. That's what I'll be doing.
r@m
Root Moose is offline   Reply With Quote
Old 02-20-2003, 10:46 AM   #11 (permalink)
Member # 5832
[QUOTE]Originally posted by Vermin
[B]GRS1 tcase + 5.38's + 33's = serious rpm for freeway action. And no, it's not photoshopped.. but the speedo is off about 8mph at that speed. GPS said 81mph.
cool picture
81 mph and you are no where near redline that's great, you're just getting warmed up!
I'll have to try and dig up my pic
Moose- the rev limiters are handy things in the efi models
UZI 9mm is offline   Reply With Quote
Old 02-20-2003, 12:25 PM   #12 (permalink)
Member # 2752
I have an 8-valve 1.6 with a VERY sick carburator. I have GRS3, 5.29's and 35's., and I can't get over 45 mph without flooring it, and if I hit the slightest little climb or headwind I have to floor it and still loose speed sometimes. But as I said, my carb is very sick. It is running super lean, and overheats (well, gets very hot anyway) even with a new 3-core radioator, new water pump, and new thermostat. As for wheeling at slow speeds/rpm's, it pulls very strong though. You almost can't stall the thing. Bobaki has the same engine setup with GRS2, 3.73's, and 32's and his rig is an absolute screamer. His runs so well that he gave me his EFI setup ( ) to use on my 8-valve and left his alone. I'll be installing the EFI next month.
I agree with Moose though. If you are starting from scratch, go with the 16 valve. If however, you already have an 8-valve, they run pretty strong with a good carb. Petroworks sells rebuilt carbs for $395. This is steep, but they have a bunch of electronic guts that probably can't be fixed by a do-it-yourselfer. I was quoted over $800 for a brand new carb
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, .............
Hey, if this rig is for wheelin', what are all these animal parts doin' in here?
Tusker is offline   Reply With Quote
Old 02-20-2003, 12:27 PM   #13 (permalink)
Biohazard
Gozuki's Avatar
Member # 3088
I will jump in since I was the one going 80 with 38s. I have 5.38s in the axles, GRSII tcase, and a little work on the 8v. I was going 80+ for hours on I5, verified by GPS. So ... One other thing about the 8v 1.6 is that you can smog it without a ref.... It is visually identical to the 1.3 if you run the carb. The only difference is the deck is 1" taller, and the 18 yr old at arco sure wont see that... I have smogged mine twice now, once at a gas staton, once at a test only station and passed both times with flying colors. It is true the 16v has more HP, but there is a lot of work to get it right, and a lot of hoops for us Cali guys to jump thru for EFI.
Originally Posted by fatdan460 View Post
it leads to real abuse, like guys who will smack a broad in the head
For Sale!! F150 5x135mm wheels!!
Wanted, Ak parts, kits or whole rifles!
Gozuki is offline   Reply With Quote
Old 02-20-2003, 12:41 PM   #14 (permalink)
Member # 8729
Send a message via AIM to marcutah Send a message via Yahoo to marcutah
I drive a 16v 1.6 In my 95 tracker. Stock gearing (5.12 stock).
Stock T case, im not sure how far off my speedo is going from 215 - 31" tires. Im guessing 5-8 mph. I can pus 75 displayed if no headwind of hill, 5th is worthless on a hill.
It was my to my knowledge that T case did nothing for 2wd on road manners. Am I wrong?
91 Tracker 6" Calmini lift 32x11.50 BFG MT TA
Locked rear!
marcutah is offline   Reply With Quote
Old 02-20-2003, 02:05 PM   #15 (permalink)
Biohazard
Gozuki's Avatar
Member # 3088
Sammy tcases are underdriven 1.2 to 1 stock, lower for the super low tcase gears. I think the 6-1 cases are underdriven 1.6 to 1.....
Old 02-20-2003, 02:39 PM   #16 (permalink)
Fabster
Randy's Avatar
Member # 3069
Im parting out a 90 tracker with 1.6L 8v,5spd, t-case and 5:12 gears. I know that this is not the for sale board but its likely to get noticed here. please PM for more info
Thanks for the support
Currie Enterprises
PSC Steering
BFG Tires
Reid Racing
King Shocks
BTR wheels
LAT Racing Oils
Baja Designes
K&N
CBM Engines
Bulldog Winch
2013 KING
Bomber Fabrication http://www.facebook.com/pages/Bomber...4102610?v=wall
Randy is offline   Reply With Quote
Old 02-20-2003, 04:39 PM   #17 (permalink)
Member # 8284
I think stock high range is 1.4, 4.16 gears hi range is 1.58 reduction, I forget the 4.89, etc...
So, hi range, stock, effective "axle" ratio is 3.73*1.4=5.22, steeper than a tracker's stock hi range,
4.16 t-case gears: 3.73*1.58 (hi) =5.89, ...
DemoMike is offline   Reply With Quote
Old 02-21-2003, 12:28 AM   #18 (permalink)
Member # 8729
That confuses me...
if I get the 4 to 1 T case gears it will increase my freeway performance?
Other than Changing my Diffs to 5.88 (calmini) from 5.12 (not a hell of a lot of difference) What are my options to increase my highway performance on the 1.6 16v.
I Have yet to do a 2 inch exhaust, i do however have the cold air intake made. Until I get a snorkle.
Locked rear!
Old 02-21-2003, 08:38 AM   #19 (permalink)
Member # 8284
Originally posted by marcutah
That confuses me...
4 to 1 gears do not change the hi range ratio in a tracker case that I'm aware of, but they do in a Samurai case.
Old 02-23-2003, 07:47 PM   #20 (permalink)
Member # 16401
stock sammi lifted onto jackstands in 5th gear!!!!
[/B][/QUOTE]
