Newbie question on tubing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-11-2001, 09:36 PM   #1 (permalink)
Member # 6808
I've decided that I want to go full exo. I saw the thread on the price of DOM tubing and now I'm all confused. What are the differences in DOM, HREW, and erw. Thanks guys.
Doug
I don't think the Jihadists are correct when they call America "The Great Satan", but I think we are capable of being a very *good* Satan.
For a man to love his country his country ought to be lovely. And Self-esteem begins with the pride of independence, of earning one's way, of being a citizen who can support his family and doesn't need charity or welfare and doesn't look for "entitlements"; without that you cannot have a republic - Jerry Pournelle
After the uprising of the 17th June The Secretary of the Writers Union Had leaflets distributed in the Stalinallee Stating that the people Had forfeited the confidence of the government And could win it back only By redoubled efforts. Would it not be easier In that case for the government To dissolve the people And elect another? -
"The Solution" by Bertolt Brecht
1991 Suzuki Samurai
Stock height
Stock t-case
No lockers
BROKE
killingthemonkey is offline   Reply With Quote
Old 11-11-2001, 10:08 PM   #2 (permalink)
fatkid's Avatar
Member # 4862
HREW, hot rolled electric weld
DOM, drawn over mandrel (aka seamless)
I'm not quite sure how much the process increase the strength of the tube but it increase the price of the tube by about 3x's, I've heard about 10%.The only tube work that we've had to do in DOM is SCCA sanctioned rally cars. That's kind of why alot of people think it's not really needed.
Ask some of the metal guru's
fatkid is offline   Reply With Quote
Old 11-12-2001, 05:21 AM   #3 (permalink)
Member # 6808
Thanks, fatkid. Name some of the metal gurus now. I'm assuming you mean people on the board.
Doug
1991 Suzuki Samurai
Stock height
Stock t-case
No lockers
BROKE
Old 11-12-2001, 10:53 AM   #4 (permalink)
fatkid's Avatar
Member # 4862
Tin Bender is one
Old 11-12-2001, 02:01 PM   #5 (permalink)
FU2
Tin Bender's Avatar
Member # 901
Sorry, here's the long version.......
This grade of mechanical tubing is the fifth of six types classified in ASTM A513. Produced from steel strip by cold forming, electric resistance welding (E.R.W.) and cold drawing to finished dimensions, D.O.M. is the most versatile and widely sold mechanical tubing grade. With an appreciation for the product's flexibility, the reason for this is easily understood. D.O.M. can be produced with outside diameters as small as .125", as large as 15" and everything in between. The wall can be as thin as .010" or near .700" thick. Carbon chemistries range from A.I.S.I. 1006 to 1060. A variety of thermal treatments can be applied to alter the mechanical properties and machinability. The E.R.W. process guarantees the weld to be as strong or stronger than the rest of the tube body. The origin from flat strip results in a more concentric product than cold drawn seamless.
D.O.M. is used for a tremendous variety of machine parts where closer tolerances and higher mechanical properties are needed. Hydraulic cylinders, spindles, jacks, rollers, motor housings, elevators, air hammers, and shafts are just a very few of the applications utilizing D.O.M. tubing.
Thanks for the spot NOW RUN!!!!
Tin Bender is offline   Reply With Quote
Old 11-12-2001, 02:05 PM   #6 (permalink)
FU2
Tin Bender's Avatar
Member # 901
"CDSM"...............
"Cold drawn" as it is often called, is the precision half of the ASTM A519 specification. Once the dominant type of mechanical tube in the market, cold drawn seamless now plays a reduced but still important role. While D.O.M. has replaced seamless in nearly all standard shelf sizes common to both products. Cold drawn seamless is produced by the piercing method. A heated billet moves through pressure rolls as it is driven over a stationary mandrel to produce a hot finished seamless tube. This hollow is then cold drawn through a die and over a mandrel to precision finished dimensions.
Old 11-12-2001, 02:25 PM   #7 (permalink)
FU2
Tin Bender's Avatar
Member # 901
4130 Tubing is often referred to as "Chrome Molly" tubing. This jargon term is derived from the chromium and molybedum concentrations present in the metal itself, which run in the area of .80-1.10 for Chromium and .15-.25 for Molybedum.
"Chrome Molly" tubing or 4130 Tubing is best for applications where a high strength to weight ratio is needed or desired. Typical tensile strength for 4130 is approximately 90-95000 PSI.
BUT a "drawn" tube OR "Welded" tube will offer a close 75,000-85,000 tensile.
AND with a ERW HERW you don't have to worry about Relieving your joints.
Now with that said, .250 wall is WAYYYYYYY overkill for a CAGE!!!! and HERW .120 wall is fine....
Old 11-12-2001, 03:02 PM   #8 (permalink)
FU2
Tin Bender's Avatar
Member # 901
Broken down version.........
moly is cool, but a BIG pain in the ass....
DOM is cool, but WAY to much $$$...
weld'd is PERFECT for make'n cages and stuff, just keep the seam inside the bend to be x-tra safe....
Old 11-12-2001, 03:21 PM   #9 (permalink)
FU2
Tin Bender's Avatar
Member # 901
Here are some more useless specs.....
ASTM A513 Type 1
Hot Rolled Electric-Resistance Welded (ERW) Carbon Steel Mechanical Tubing
ASTM A513 Type 2
Cold Rolled Electric-Resistance Welded (ERW) Carbon Steel Mechanical Tubing
ASTM A513 Type 5
Drawn Over Mandrel (DOM)
ASTM A513 Type 6
Drawn Over Mandrel Special Smooth ID (SSID DOM)
ASTM A512
Cold-Drawn Buttweld Carbon Steel Mechanical Tubing
ASTM A519
Seamless Carbon and Alloy Steel Mechanical Tubing
Old 11-12-2001, 03:38 PM   #10 (permalink)
FU2
Tin Bender's Avatar
Member # 901
Just let me know when to stop!!!!
*deep breath*
ERW pipe is made from strips of hot-rolled steel, which are passed through forming rolls and welded. While seamless pipe is traditionally stronger and more expensive than ERW pipe, ERW technology is improving and the technique now accounts for approximately 48% of annual tonnage shipments of oil country tubular goods
Old 11-12-2001, 03:40 PM   #11 (permalink)
FU2
Tin Bender's Avatar
Member # 901
SEAMLESS PIPE (SEAMLESS TUBE)
Tubular product made from a solid billet, which is heated, then rotated under extreme pressure. This rotational pressure creates an opening in the center of the billet, which is then shaped by a mandrel to form the pipe or tube.
Old 11-12-2001, 04:20 PM   #12 (permalink)
J-Dogg's Avatar
Member # 2471
The metal guru has spoken......
J-Dogg is offline   Reply With Quote
Old 11-12-2001, 04:37 PM   #13 (permalink)
FU2
Tin Bender's Avatar
Member # 901
Can I stop now?
Old 11-12-2001, 04:51 PM   #14 (permalink)
DSI
DSI's Avatar
Member # 920
Send a message via Yahoo to DSI
Originally posted by Tin Bender
Can I stop now?
nope, sorry
Thanks to the companies that make it happen: Bilstein Shock Absorbers, Trail-Gear, Trent Fab, PRP Seats, Raceline Wheels, PSC, MJ Motorsports
DSI is offline   Reply With Quote
Old 11-12-2001, 06:27 PM   #15 (permalink)
Member # 4279
a guy could get a education here thanks Mr Bender....
bobaki is offline   Reply With Quote
Old 11-12-2001, 10:33 PM   #16 (permalink)
fatkid's Avatar
Member # 4862
Like I said,
Old 11-12-2001, 10:36 PM   #17 (permalink)
Member # 6808
Tin Bender,
Thanks for answering this newbies questions. Next one though. I have decided to go full exo. Also, I want to cut the back into a flatbed. Well, me and my room mate are having a disagreement on the diameter of tubing to use. I was thinking a full 2". He says 1 1/4" is good enough. Your thoughts?
Doug
1991 Suzuki Samurai
Stock height
Stock t-case
No lockers
BROKE
Old 11-12-2001, 11:02 PM   #18 (permalink)
Member # 4279
I was told almost the same thing,and was con vinced enough to buy the dies,now I just have to use them....
Old 11-12-2001, 11:08 PM   #19 (permalink)
FU2
Tin Bender's Avatar
Member # 901
Going exo is a big step.... It's alot of work but well worth it in my opion..
Frosty rolled twice on bald mount'n on LeRoys first trip out!!! (not flops, complete rolls) Just to "test" the new exo out. All I can say, is he drove it there on the HWY, and he drove it back home, windshield intact and the cage not completely finish'd... (it needed some 1-1/2 brace'n in the rear)
Why would you want to go with 1-1/4?? Your not give'n up more than an inch and a half in width so that wouldn't be it...
Your not give'n up much in the way of weight...
In my opion, 1-1/4 is WAY to small to LOOK good...
It's not as strong as 2"...
If 2" just seems to big, I wouldn't go ANY SMALLER than 1.5 x .120 DOM or 1.75 x .120 weld'd...
The most important thing is to remember to cross brace right behind the cab to the FRAME...(99% of "rolls" are sideways)
And gusset the A-pillars to help the front to bach shift..
DON'T build your exo to keep the body from get'n dented, build it to keep your head off the rocks
people do thing different and thats great!!! If everyone were the same life would suck!!!
Old 11-12-2001, 11:17 PM   #20 (permalink)
fatkid's Avatar
Member # 4862
The 2" we used for the sammy took a hard hit before it was even done and it didn't even tweek in the slightest bit.
Old 11-12-2001, 11:26 PM   #21 (permalink)
Member # 6808
Thanks for the input guys. I'm going to bed now. Look for more newbie questions tomorrow or the next day.
Doug
1991 Suzuki Samurai
Stock height
Stock t-case
No lockers
BROKE
Old 11-13-2001, 12:38 PM   #22 (permalink)
TNToy's Avatar
Member # 5776
TinBendy,
You rock! What would you say are the most common flaws in an exo cage? not enough bracing for lateral rolls, not enough against front-to-rear forces?
I guess I'm asking... What are the things you almost always see WRONG with the exo-cages people do to their own rigs in their shop?
[size=1]ASE Certified Master Automotive Technician
Toyota Certified Expert Technician
Volvo Certified Expert Technician
Suzuki Certified Master Technician
IDPA Certified Master Cardboard Killer[/size]
TNToy is offline   Reply With Quote
Old 11-13-2001, 01:44 PM   #23 (permalink)
FU2
Tin Bender's Avatar
Member # 901
IMO...... and it's just that..
I DON'T want to come across like some smart ass know it all, and if I have, i don't mean to...
It's something like "DRM phobia"
IMO, the biggest thing is the lack of cross lateral cross brace'n...
I know some guys can't afford to lose, or choose not to lose the space, like in FatKids sammy... that is why it's made of 2"x .120... Insted of 1.5 or 1.75 x .120.. It's a give and take..
Good mounts are another thing....
Go right to the frame if you can...
If not, make a DAMN good mount/standoff..
Kinda like "The house is only as good as the foundation"
And lastly, A little practice with the welder go's a LONG WAY......
take a bunch of scrap tube, and practice weld'n it up.. Most people can lay a damn good bead straight flat and level, but once out of position
It's not hard, just get use to welding vert and over head, until you get comfortable.
Take your time, there is no race to get it together, and you'll be ALOT happier with the end result... :A cage you can be proud of, and one that you KNOW will take a good hit...
PS!!!!!
KNOW WHEN TO STEP AWAY FROM THE BENDER!!!! Do you remember EB BRONCO
Sometimes, it's easy to get carry'd away...
Old 11-13-2001, 02:17 PM   #24 (permalink)
TNToy's Avatar
Member # 5776
Yeah... I remember that jungle-gym Bronco. Hard to forget.
We need a "BoneHead 4x4 Discussion" forum for all the stuipd shitzu people do to build a rig.
Thanks for the reply. Good stuff... and I definitely understand DRM-Phobia.
Old 11-14-2001, 10:32 AM   #25 (permalink)
***Glitterbomber***
CragRat's Avatar
Member # 6483
I would love to do an Exo cage on my tin top 86' but, How would you get good cross-bracing and still not penitrate the body, block the rear door or cross the windshield ?
Dave
" Put on your seatbelt .... I want to try something "
AxleSnapper Bulletin Board
AxleSnapper Website
CragRat is offline   Reply With Quote
