Questions on fab of rocker guards - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-04-2003, 05:21 PM   #1 (permalink)
Member # 16702
I was thinking about welding up a set of rocker guards for my zuk and I have some questions on how I shoud go about it. I was looking all over the internet for ideas and yes I did the search. I was wondering how rocky road outfitters can make their rocker guards completely bolt on. I dont really want to weld anything to my frame. I was wondering if any of you have pics of your rocker guard set ups for some more ideas. Thanks
I understand the whole jeep thing... Thats why I bought a Samurai
gadzook is offline   Reply With Quote
Old 04-04-2003, 06:08 PM   #2 (permalink)
Pappa Smurf's Avatar
Member # 12401
Send a message via AIM to Pappa Smurf
which rocker gaurds
Toyota axle parts www.pirate4x4.com/forum/showthread.php?p=8789642#post8789642
Pappa Smurf is offline   Reply With Quote
Old 04-04-2003, 06:09 PM   #3 (permalink)
Member # 10364
Send a message via AIM to schuss
Re: Questions on fab of rocker guards
its not hard, on the body mount wings there's ample space to drill and bolt. Schrock's are the same way. I'd go with his if I were you, amazing quality, they fit great and look great. They mount through the body and those mounting wings.
common sense is for the foolish
schuss is offline   Reply With Quote
Old 04-04-2003, 08:33 PM   #4 (permalink)
Member # 14547
What's wrong with welding them on????????????
AZRocks is offline   Reply With Quote
Old 04-04-2003, 08:52 PM   #5 (permalink)
Member # 11626
Some places it is illegal to weld to your frame. Not a big deal...unless you get caught
The ones that use the mounting wings sound good. The key is to remember that they don't need to transfer all the weight to the frame, just some. The rest can get spread to the rocker panel (the key being spread over the WHOLE rocker) and you won't dent anything.
Goof is offline   Reply With Quote
Old 04-05-2003, 05:34 AM   #6 (permalink)
Member # 7742
its illegal to speed and tear the tag off your mattress too, so whats your point?
samiguy is offline   Reply With Quote
Old 04-06-2003, 11:19 AM   #7 (permalink)
Member # 16702
I dont really know where the "Body Mount Wings" are on my zuk. I know that I am an idiot newbie but coud you point me in the genereal direction.
Old 04-06-2003, 11:46 AM   #8 (permalink)
Member # 12401
look inunder the driver side and 2 c channel looking thing is sticking out with body mounts on them and that were u mount the
Old 04-06-2003, 04:12 PM   #9 (permalink)
Member # 16978
hell my frame has been welded on so much now you cant tell what hasnt been just weld them on and be done with it
zukzilla4x4 is offline   Reply With Quote
Old 04-07-2003, 01:05 PM   #10 (permalink)
rotozuk's Avatar
Member # 8965
You can always weld on a couple of bolts to make it look bolted on.
Shit, what state wont let you weld to your frame? I hope mine isn't one of them!!
-Wayne
rotozuk is offline   Reply With Quote
Old 04-07-2003, 01:10 PM   #11 (permalink)
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
I welded mine to the frame.
I first welded a piece of 1/4 inch plate to the frame and then welded black pipe to the plate.
Black pipe is hard and brittle, my thoughts were I would rather have the pipe break off on a hard hit, than stay attached to frame and twist the rails. More than likely it will break at the weld.
I haven't had any problems with them. When I do tear them off, I will probably just use angle iron and bolt it to the body.
The penalty for punching someone in the mouth is way too high in our society.
www.MountaineerOffroad.com
SilverZuk is offline   Reply With Quote
Old 04-07-2003, 05:00 PM   #12 (permalink)
Member # 16702
Thanks for all the suggestions. I was thinking of drilling on my frame. Im not sure if this is crazy. I was planning on drilling through the front body mount wing and on the rear through the the square bracket that supports the stationary end of the rear spring. Tell me now if this is crazy and will hurt the structural integrity of my rig. I was planning on drilling two holes in each. Any input would be great. Thanks
Old 06-11-2005, 04:21 PM   #13 (permalink)
Member # 36515
My idea was to put 3/16" steel 90 angle 3x3 inches directly on the rocker.
But I'm working on figuring how and where to bolt it..
any suggestions?
Dyevzuk is offline   Reply With Quote
Old 06-12-2005, 03:04 AM   #14 (permalink)
Non Urban's Avatar
Member # 21175
any suggestions?
I originally did that with 4x4, 1/4 inch diamond plate and it worked very well spreading the weight along the the body from wheel well to wheel well for a couple of years until the day I dropped down HARD right behind the front wheel. It bent the bottom of my tub up about 1-2 inches leading back and tapering off about the middle of my door. I had to beat the sh!t out of my door jam to fit my door back on. Needless to say I have since ran 2 inch hitch tube along the body mounts to the frame.
[COLOR="Red"][SIZE="4"][B]IF YOU DON'T STAND BEHIND OUR TROOPS,[/B][/SIZE][/COLOR]
[COLOR="White"][SIZE="4"][B]PLEASE, FEEL FREE TO[/B][/SIZE][/COLOR]
[COLOR="Blue"][SIZE="4"][B]STAND IN FRONT OF THEM![/B][/SIZE][/COLOR]
Non Urban is offline   Reply With Quote
Old 06-12-2005, 11:51 PM   #15 (permalink)
zukman27's Avatar
Member # 41559
I welded 4x4 angle to my rockers I have jacked the whole side up quite a few times with the high lift jack it holds fine. Also covers up smashed rockers great
The Second Amendment is the reset button.
zukman27 is offline   Reply With Quote
Old 06-13-2005, 12:10 AM   #16 (permalink)
Member # 15738
one of the best mods i done to my new zuk was to cut the rockers off
and then weld some sliders up higher
i have about an extra 4-5 inches more clearance now
redzook is offline   Reply With Quote
Old 06-13-2005, 02:26 PM   #17 (permalink)
Member # 36515
This is what I'll do!
While I was taking the mesures for cuting the angle, I found HOLE in my rockers and floor. Baby need cares and new armor
Old 06-13-2005, 02:45 PM   #18 (permalink)
Member # 43278
redzook--or anybody with his idea have any pics---sounds like a good idea--
I assume that you cut the rockers to the botton on the floor, then simply put some 4x4 angle on---am even close??
budgetsami is offline   Reply With Quote
Old 06-13-2005, 03:27 PM   #19 (permalink)
Member # 36515
Someone show me is idea.
He tooks 2x4 tubing 3/16 thick to replace his rocker. He welded them flush with the floor on the 4 inches side.
Old 06-13-2005, 08:27 PM   #20 (permalink)
Non Urban's Avatar
Member # 21175
Yeah it worked great for me too. Just wait until you slip off a rock and land hard on them. Like me....LOL Jacking it up and slamming down on a rock are worlds apart.
Old 06-13-2005, 09:16 PM   #21 (permalink)
Member # 8174
Send a message via MSN to Bill4rest
Kenny are those attached to the frame
Bill4rest is offline   Reply With Quote
Old 06-13-2005, 09:56 PM   #22 (permalink)
Non Urban's Avatar
Member # 21175
They are now Bill.
Old 06-14-2005, 09:55 AM   #23 (permalink)
Member # 8105
This way is not as strong but the clearance you get is great. After a few years of beating on the truck, the rockers are pretty foul, but so is the rest of the truck. If I had a to do over I would fully weld the angle to the sheetmetal instead of just stitching it.
http://www.abusivemotorsports.com/st...ection=2&id=16
Troy Wiora
Senior Test Pilot
[url]www.AbusiveMotorSports.com[/url]
Philthy is offline   Reply With Quote
Old 06-14-2005, 10:50 AM   #24 (permalink)
poi-dog's Avatar
Member # 12987
Send a message via AIM to poi-dog
Here is some awesome info/thread on the the zuwharrie.com forum on making some sturdy & good looking rockers w/ boxed material. They fill up the void after cutting out the damaged/rusty lower rocker panels.(http://bbs.zuwharrie.com/content/top...058d48392c7eaa)
But for some reason, the pics don't pull up for me any more? Perhaps, can ask them to e-mail them to you or repost them.
aloha! ......renny
www.whatreallyhappened.com/HAWAII/hawaii.html
www.alohaquest.com
1989 chevy v30 crewcab 4X4
1987 samurai(soon VW 1.9L TDI/Toy xmsn)
[COLOR=Red]eh, no call me won coconut or pineapple, I not won fruitcake![/COLOR]
poi-dog is offline   Reply With Quote
Old 06-14-2005, 03:31 PM   #25 (permalink)
Member # 36515
I think 3/16 is way enough!
1/4 is overkill and HEAVY
I'll go with 3/16 thick and 3x3
