toy flange on zuk case??
will it work??? searched, and didn't find ne thing... have to put a flange on the rear of a zuk case and wondered if a toy flange would work...
87 samurai in the building stages, low budget spoa and 1.6 swap for now |
Member # 8111
Nope the toy flange is way to large of inside Diameter it would wobble around on the spline like a toothpic in a french hore
Your right I own the Fucking Place All Rock 4X Fab Products Made IN THE USA!!! Rock 4X Fabrication,Inc 1-847-672-9653 |
Member # 8111
You need any info on that toy to zuk stuff email me at rugrattss@attbi.com the pm has not been very reliable and its empty
#6 (permalink) | |
Member # 8601
Re: toy flange on zuk case??
LMK r@m |
Member # 16454
send me a pic I am interested Fatboy1097@aol.com
#8 (permalink) | |
Member # 416
Member # 8111
You want something like these or the french women
Your right I own the Fucking Place All Rock 4X Fab Products Made IN THE USA!!! Rock 4X Fabrication,Inc 1-847-672-9653 Last edited by Rockrat; 05-02-2003 at 05:16 AM. |
#10 (permalink) | |
Member # 8601
r@m |
#12 (permalink) |
Member # 8111
Yep that an 86 shaft mated to the small flange t-case and pinion
#13 (permalink) | |
Member # 12247
Keep the rubber side down ! |
#14 (permalink) |
Member # 8111
yes they do, only way to put them all the way through is to notch the zuk flange were it would come through. they have sold like hot cakes and not a complaint yet and I have been running them on a dd for 3 months and avg 185 miles a day with a v-6 for the power plant..
#17 (permalink) |
Member # 8111
Thanx man just picked up another set of 40 of them from the machinest tonight and 1/2 are sold already.
#20 (permalink) | |
Member # 8111
#21 (permalink) | |
i have one sitting in my garage from i think a 82 possibly ..arent the all the same from 79-85?? it looks like you just bolted it in there without any length mods i hope looks like you are running wrangler springs also cool
85 toyota P.U.caged, Bobbed, chevy rears, 529's ,rearmains up front, spools, crossover steering, limited to 33's till I get longfields, changing birfs on the trail sucks. |
#22 (permalink) |
Member # 5776
FYI, the solid axle Toyota's front CV shafts have a double cardan joint that will take more angle than an IFS toy's shaft. But you can clearance the IFS shaft's CV joints to allow just as much movement.
![]() http://www.4x4wire.com/toyota/tech/cvmod/ http://www.pirate4x4.com/forum/showt...threadid=89428
[size=1]ASE Certified Master Automotive Technician Toyota Certified Expert Technician Volvo Certified Expert Technician Suzuki Certified Master Technician IDPA Certified Master Cardboard Killer[/size] |
#23 (permalink) | |
Member # 8111
79-85 as tntoy said have rouhly 30 deg in the cv vs.15 of an IFS truck. Mike the customers truck in the pic used what he had.. The adapters work on any toy front cv from 79-85 to bolt to small flange zuk. There is also a total of 4 different bolt patterns between these yrs 2 from 79-83 2 from 84-85 the adapter takes into an account for anyone of them. generally the 79-83 is a direct replacemt no shortening depending on your lift 84-85 was tad longer. Also we can adapt Toy rear shafts into the front of a zuk with the adapters
Your right I own the Fucking Place All Rock 4X Fab Products Made IN THE USA!!! Rock 4X Fabrication,Inc 1-847-672-9653 Last edited by Rockrat; 05-14-2003 at 05:04 AM. |
#24 (permalink) |
Member # 16608
Kd7srj, The bottom two are mine, it's an 86 IFS shaft shortened 4.5 inches, I didn't have to clearance anything. It works fine. Those are wrangler springs with drop shackles in back. no binding and 0 vibes. I have better pics of it on the ground in use, but I'm to dumb to get then on here
'88 Zuk |
#25 (permalink) | |
Member # 8111
