firebird mc problems - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-18-2003, 07:07 AM   #1 (permalink)
Member # 12481
i searched but didn't really give me the answer i needed.
i run a firebird mc with d44's and disk in the rear. plumbed all new lines and no proportoining valve. bench bleed the mc and bleed the hell out the lines.. when i first did the swap the back brakes would lock up and not the front. thought everything was good to go. then started getting in off camber situations and the pedal would go away. so i gravity bleed the brakes. every since then the brakes have sucked ass. bench bleed the mc and they got better. but still not like before. i figure that i still need to lift each tire and bleed as well.
couple of questions.
1. i've got air blowing and sucking between the mc and the booster. will this effect anything. do i need to silicone that up?
2. i've got the front brakes running off the big port in the mc and rear off the small. is that right?
thanks.
psf4x4 is offline   Reply With Quote
Old 06-18-2003, 08:07 AM   #2 (permalink)
NC Zuk's Avatar
Member # 12060
Send a message via Yahoo to NC Zuk
Isn't there a hole in the bottom of the master cylinder that needs to be plugged? I know that I read this somewhere
RIP MSG Art Lilley, you will never be forgotten...
NC Zuk is offline   Reply With Quote
Old 06-18-2003, 08:18 AM   #3 (permalink)
Member # 12481
thats news to me. any idea where you read that? here are what so i can search it. anybody else heard of this. i'll check when i get home. thanks
Old 06-18-2003, 10:41 AM   #4 (permalink)
High5's Avatar
Member # 1700
for the rear brakes locking up and not the front is the lack of the propotioning valve. i did not use the propotioning valve on my new rig and now i can lock up the rears pretty easy and the fronts never do. i plan on adding an adjustible p-valve in the future.
High5
IT'S 1TON O' FUN!
High5 is offline   Reply With Quote
Old 06-18-2003, 02:57 PM   #5 (permalink)
Member # 13446
I used the firebird mc too and yes there is a hole in the base of the MC that needs plugged. You can hear the air when you cycle the brake pedal. Plug that up and it will help.
I can lock my front brakes but not the rear....
FLY NAVY!! Support Our Troops!!
USN 1994-present
sh996 is offline   Reply With Quote
Old 06-19-2003, 03:47 AM   #6 (permalink)
Member # 12481
i got home i lifted each tire up and bleed the brakes that way. found a quite a bit of air in the back. still no pedal worth a crap. when i was doing this i noticed a lot of metal shaving in the mc floating around. i would imagine its from the sleeve and spool in the bottom of the mc. i'm going today and getting another mc since there only about 23 bucks. i'll find out where this hole is on the new one before i install it. i also plan on putting rtv around where the mc bolts to the booster. hopefully after all that and a good bleed of everything i'll be good. i'll let ya know. thanks for the help sh996.
thanks for that little bit of info high5 i had no idea why the rear locked up and front didn't
chris
Old 06-19-2003, 07:43 AM   #7 (permalink)
Member # 12481
they make to master cylinders for the firebird that look the same. one is for disk front and rear drum. they also have one for all 4 disk. i used the one with the drum rear last time. which ones is everybody using. the 4 wheel dick mc sounds like it would work better but is the bore the same as the mc w/ rear drum. anyone?
Old 06-19-2003, 08:23 AM   #8 (permalink)
High5's Avatar
Member # 1700
since you are running discs at all 4 corners i'd go with the one that was made for 4 wheel disc. just my op.
High5
IT'S 1TON O' FUN!
Old 06-19-2003, 08:40 AM   #9 (permalink)
Member # 8061
What year Firebird 4whl disc ? I,ll be looking for a M/C soon. Thanks, MIKE
'72 Bronco FG 44/PowerLok 9"/Detroit D20 NP435 35's 4 Discs/Coils/Links
GarWood PTO Winch 302 Isky/Offy/Holley
'00 XJ Supercharged
'97 TJ
Geo Buggy Project
YM2610D Yanmar
Mike@Accurate is offline   Reply With Quote
Old 06-19-2003, 10:28 AM   #10 (permalink)
Member # 13446
Mine is out of an '80 firebird.
USN 1994-present
Old 06-19-2003, 10:36 AM   #11 (permalink)
Member # 12481
4wheel disk or front disk rear drum. i just went and order the 4wheel one. if it's not the same bore size as the rear drum then i'll just get that one.
high5............once again
Old 06-19-2003, 11:49 AM   #12 (permalink)
Member # 13446
I'm pretty sure its the 4 disk one since I've got disk brakes all the way around, but I honestly can't remember. Good luck.
USN 1994-present
Old 06-19-2003, 11:53 AM   #13 (permalink)
Member # 12481
thanks...........i looked up the mc on the napa site. it said the bore size was 1"&1/8. so it will work. i'll find that damn hole and plug it when i get it in the morning. how did you plug it. silicone or what?
Old 06-19-2003, 11:58 AM   #14 (permalink)
Member # 13446
I used silicon, but I need to check it to make sure it held. It's a pretty large hole to fill. I think JB Weld or something like it would work better.
USN 1994-present
Old 06-19-2003, 12:14 PM   #15 (permalink)
Member # 12481
is it the hole thats right below the bore?
Old 06-19-2003, 03:10 PM   #16 (permalink)
Member # 13446
Yep, that's the one. I didn't notice it till after I installed it, so I had to seal it from the outside.
USN 1994-present
