help need a pic - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-24-2003, 01:21 PM   #1 (permalink)
Member # 14194
help need a pic
cuold someone try to explain or post a pic . When doing a shackle reversal on a Zuk and using rear springs up front how shuold the re-located bone-shackle hang? When at rest shuold the bottom of it angle towards the rear tire, and if so how much. Thanks to n e 1 in advance.
Number 22 off the line. 1983 SJ410- still going.
whats his name is offline   Reply With Quote
Old 06-24-2003, 01:36 PM   #2 (permalink)
rotozuk's Avatar
Member # 8965
The shackle should be about 90 degrees to the leaf spring. This gives you the least amountof body sway when you load the shackle in a turn or off camber.
But most do not have this ideal angle. I don't.
Sorry no pics.
-Wayne
rotozuk is offline   Reply With Quote
Old 06-25-2003, 01:07 AM   #3 (permalink)
Member # 14194
did I weld the shackle mount in the wrong position? should it be straight up and down instead? when it flexes it can still come back about 1 1/2-2 inches, so is it worth it to re-do it?
Old 06-25-2003, 01:13 AM   #4 (permalink)
Member # 14194
the front
this is the front and those are stock rear Sam springs(no commments on welds please i'm ashamed already) so looking at the 2 pics did I fuk this shackle reversal up?
Old 06-25-2003, 04:47 AM   #5 (permalink)
Member # 8111
Looks good
Your right I own the Fucking Place
All Rock 4X Fab Products Made IN THE USA!!!
Rock 4X Fabrication,Inc 1-847-672-9653
Rockrat is offline   Reply With Quote
Old 06-25-2003, 01:20 PM   #6 (permalink)
Member # 14194
So by that, I take it that the way my shackles are hanging is cool?
I've seen your fab work Rat, so coming from you I appreciate the positive comment. Those rear shackle hangers I made from 2 inch square tube cut down and beveled then my b-in-law put em in the galving tank at work and I rockgaurded them to blend with the frame.. The fronts I will cut off one day and redo, they were done by the original owner who made a scabby mess out of the reversal when it was first done(nothing square nothing welded right) So although its not optimal ,the angle those shackles are hanging should be reasonable eh?
Old 06-25-2003, 01:24 PM   #7 (permalink)
Member # 7753
Yeah, it's reasonable, the springs are quite flat so the shackle won't move back much, mostly forward.
Slowzuki is offline   Reply With Quote
Old 06-25-2003, 02:50 PM   #8 (permalink)
Member # 14194
these are the mounts I made before installed
Old 06-25-2003, 09:50 PM   #9 (permalink)
TNToy's Avatar
Member # 5776
But that gives you lots of room for compression travel, and unless you're running a long shackle, you may run out of travel on droop.
The rule of thumb I've typically heard is that a 30* angle gives you equal amounts of shackle-travel (swing) for compression and droop, a close-to vertical angle gives you more load carrying capacity, and a more raked-back shackle angle gives you a smoother ride. I can vouch for that last one.
Also of note: If a vertical shackle was best for handling, then why does almost every factory vehicle (Toy, Jeep, etc) have a 30-45 degree angle from the factory?
[size=1]ASE Certified Master Automotive Technician
Toyota Certified Expert Technician
Volvo Certified Expert Technician
Suzuki Certified Master Technician
IDPA Certified Master Cardboard Killer[/size]
TNToy is offline   Reply With Quote
