Zuke engine problems - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-23-2003, 07:42 PM   #1 (permalink)
Member # 21454
Question Zuke engine problems
I've got a 86 Sammie with a Swift throttle body injection system. I did the unthinkable and let it sit for about 2-3 months without starting. I can get it to fire up easy enough, but when I put it under any load, and get the RPM's to around 2500-3000, she starts cutting out pretty bad.
I figured it was probably the fuel at first, possibly condensation, but I'm starting to lean towards the electrical end of things.
I noticed that the vaccum advance valve line was not attached to the manifold. Are these normally connected to the manifold, or the air cleaner? I assumed with this being disconnected, that it could be some of the problem, but I've yet to find any area on the manifold that it could connect to.
I bought the rig over a year ago from a guy who did most of the mods on it, including the injection system.
By the way, I have new plugs, wires, and the distributor and rotor are in excellent shape.
Any ideas at all would be greatly appreciated.
86 Zuke, 32" Swampers, Custom Coil rear suspension, Suzuki Swift TBI, On-board air, GRS1 t-case, Sidekick hybrid rearend, full roll cage, Warn 8000lb Multi-mount winch, custom half-doors,
The list goes on
bluezuked is offline   Reply With Quote
Old 07-23-2003, 09:20 PM   #2 (permalink)
Member # 18487
Send a message via AIM to Tintop
fuel pump
Tintop is offline   Reply With Quote
Old 07-24-2003, 10:52 AM   #3 (permalink)
Member # 21454
Originally posted by Tintop
fuel pump
I thought about that one too, but it seems to be working fine as far as I can tell. It's an electric in-line.
The list goes on
Old 07-25-2003, 03:24 AM   #4 (permalink)
Member # 16978
i would check to see if you have a clogged injector its a good possibility they will make them run bad and cut out
zukzilla4x4 is offline   Reply With Quote
Old 07-25-2003, 03:36 AM   #5 (permalink)
Member # 11626
If your vacuum advance isn't hooked up, it won't like RPMs above about 2500. It should go from the advance unit to the left side of the intake manifold. That should fix the problem.
If not...fuel filter?
Goof is offline   Reply With Quote
Old 07-25-2003, 08:54 AM   #6 (permalink)
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
Sounds like fuel starvation.
Pump
Filter
Air leak
Bad/pinched fuel line
Don't know much about the throttle body.
The penalty for punching someone in the mouth is way too high in our society.
www.MountaineerOffroad.com
SilverZuk is online now   Reply With Quote
Old 07-25-2003, 10:28 AM   #7 (permalink)
Member # 21454
Thanks guys, I'm going to tow into my shop tomorrow and start going through it top to bottom. I've been searching all over the manifold for a place to plug the vacuum advance hose into to no avail.
It's got an in-line fuel filter that I'm going to change out also, but I figured that this wasn't the problem considering it was running great before I let it sit. I've been racking my brain trying to figure out what the hell it matter with it. If I'm successful, you guys will be the first to know.
The list goes on
Old 07-25-2003, 10:40 AM   #8 (permalink)
Member # 9474
You sure that no rats made a condo out of your air box?
Former samurai owner........
I AM IN NOW WAY RESPONSIBLE FOR MY SPELLING!!!!!
FLEXYSAMMY is offline   Reply With Quote
Old 07-26-2003, 10:44 AM   #9 (permalink)
Member # 17151
That's actually VERY true! Almost every Samurai that I've bought that's been sitting for some time has had some group of small furry critters making a condo in there. They really seem to like the air vents in the dash. Once in that area of the car they tend to chew on the wires for some ungodly reason...
Capn_Crunch is offline   Reply With Quote
Old 07-26-2003, 11:29 AM   #10 (permalink)
Member # 7882
it is your vacuum advance FOR SURE!! if you don't have it plugged in, it wont run right!!
[url]http://phonese.cx/user/spence/[/url]
My life from my phone's perspective.
spencurai is offline   Reply With Quote
Old 07-26-2003, 04:50 PM   #11 (permalink)
Member # 21454
well, I've went all over it, and can't seem to find the source for the vacuum advance hose. I disconnected the fuel filter and shot air though it. It's flowing fine. I ran it up the street and discovered that it does seem to be running a little better, but the strange thing is that in 1st gear, you can rev the R's up to over 4000, but as soon as I put into 2nd, she starts gagging at anything over 2000. This leads me to believe that it probably is a problem with the fuel pump, hence you use more fuel at the same R's in a higher gear under load correct?? If it was the vacuum advance, wouldn't the hesitation become apparent in neutral or first, rather than just when I put into a higher gear? Vaccum should be determined by strictly the R's, right?
Is there any good ways of determining whether or not the fuel pump is pushing fuel at an adequate amount of pressure? I really don't want to go buy another one if I'm not for positive that the one that I have is shot.
Ohh, by the way, here's a little safety tip I learned today the hardway. Don't leave your watch on when you're working on your rig. While disconnecting my fuel filter, I inadvertently touched the positive battery post to my watch. She arced like a bastard and melted the links of my watch band together. Managed to leave a nice ring around my wrist with blisters and missing flesh.
Other than 2nd degree burns, and a nonrunning zuke, I've had a great day
The list goes on
Old 07-26-2003, 09:34 PM   #12 (permalink)
Member # 16978
no fuel consumption doesnt change with gears.load on the motor does the higher gear the bigger the load to keep the speed.still sounding like an injector to me ....
Old 07-26-2003, 11:21 PM   #13 (permalink)
MRfuelish's Avatar
Member # 12376
try putting in a full tank of super, the shelf life of gas is not the best these day's and a can or two of gas additive!
MRfuelish is offline   Reply With Quote
Old 07-27-2003, 02:06 PM   #14 (permalink)
Member # 21454
I put fresh gas and STP fuel injector cleaner in there too.
The list goes on
Old 07-29-2003, 05:24 PM   #15 (permalink)
Member # 21454
I'm thinking that the injector sounds the most plausible at this point, but where would I get some good info on cleaning them out, other than adding additives in the gas that don't seem to be helping any?
I siphened the tank and replaced it with super and added STP's best fuel injector cleaner. Let it idle for about 45 minutes. Ran it around the block several times, but it still sputters and gasps when I try to go past first gear.
I also was skimming the net and found some info that said that the Swift TBI does not have a vaccum advance unit, so maybe this is why I've been unable to locate the connection anywhere.
Anyone know how to clean those damn ejectors???
The list goes on
Old 07-29-2003, 05:31 PM   #16 (permalink)
Member # 16978
thats what ive been trying to tell you.just replace it its the easiest thing to do
