Member # 12480
Who's running Yota axles with NO vibes
So a show of hands then I'll ask more Q's. Who on here is running Yota PU axles on a Samurai with a Samurai t-case without a way streached out wheelbase and the stumper,.....NO DRIVELINE VIBRATIONS?
"Yeah,.......so whut if I DO have a buncha junk veerikuls in my yahd?" |
Evil Twin
With NO CV (2 joint shaft) and no pinion angle its possible to not get a lot of vibes, assuming you in range on operationg angles.
wth a CV you only gonna get so good do to the off set and the pinion rolled up. you can cancel the up/down angle with the CV, but the side/side will always be there... I have the later and its great on the trails and is drivable for my weekend romps, and i can easily get to/from the trail heads with out ratteling my cage.... (you catch that pun) -yag
Mike Yager - Jeep TJ Build Up - Ecotec, Toy axles etc.. Ecotec - Technical Info E450 Ambulance VRAY (YAger RV) VRAY 2006 E450 - Ambulance Cummins Diesel Swap |
Member # 4500
42*cv's are your friend
Shane [COLOR="DarkRed"][FONT="Comic Sans MS"][URL="www.hbrk4x4.com"]HBRK4x4.com[/URL][/FONT][/COLOR] [URL="http://www.yyracing.com/"]Y&Y Racing, LLC[/URL] [URL="http://www.we-rock.cc/team_list.php?wts=show&wvalue=181"]We-Rock #208[/URL] "Team HBRK" thanks our sponsors. Driver: Shane Yost Spotter: Todd Young |
#5 (permalink) | |
Member # 12480
Member # 10979
I dont have any, but I have a Taco axle that is cut down 3" on the pass side.
![]() Jim
Jim Shrake [URL=http://www.shrockworks.com][COLOR=red][B]www.ShrockWorks.com[/B][/COLOR][/URL] Armor! - Bumpers, Sliders, Skids |
#9 (permalink) | |
Member # 12480
#10 (permalink) | |
Member # 12480
#11 (permalink) | |
Well I got it from Dave at Asian auto, and it took like a week. My pinion was shot from the donor axle I got, and it is not caused from the shaft. |
#12 (permalink) |
Member # 8111
Well here is a list of guys I have sold adapters too this is not the hole list but what i have entered in to the data base so far
Toy axles with adapters no complaints that i have heard Neale Geis Jim Ar Tim N Corey b Doug J Doug I Bought 2 full pairs Graeme T Kris K Terry Wi Roger W Gene A Erik F John R Lonny R Paul P Matt M Brad J Dave S Nick A Josh P Steven S Kale L Cody F Thomas M Casey J Douglas R Figmo Roadless Gear I dont believe he has his on yet Lawrence F - still has a slight vibe CAN it be done YES
Your right I own the Fucking Place All Rock 4X Fab Products Made IN THE USA!!! Rock 4X Fabrication,Inc 1-847-672-9653 Last edited by Rockrat; 08-11-2003 at 08:20 PM. |
#14 (permalink) | |
Member # 8111
Your right I own the Fucking Place All Rock 4X Fab Products Made IN THE USA!!! Rock 4X Fabrication,Inc 1-847-672-9653 |
#15 (permalink) |
Member # 4862
I'm here, I been in my garage doing some top secrete work. But really, I just can't count the time I have posted and reposted on the same subjects. So I just keep out the spam and keep it clean in here.
[url]http://www.myspace.com/jerrywsparks[/url] |
#16 (permalink) | |
Member # 8111
#17 (permalink) |
Member # 12480
Well, I guess I just need to get a different adapter or try another Toyota d-shaft. The thing that I don't like about the adapters that I had made up is they didn't make the circle in the middle of the adapter that protrudes out & into the Samurai t-case. Wouldn't it be centered good enough with just the four bolts that hold it on?
#19 (permalink) |
I just got done putting toy axles under my dads zuk. Used the same d-shaft spacers and a stock shaft. I turned the samurai flange 90 degrees to the holes in the toy flange and drilled them out to 5/16's
I got very lucky. It is as smooth as glass at all speeds.
87 Suzuki Samurai 4x4, Stock motor, Toy P/S, Transmission, 4:16:1 t-case, Dana 44's f/r. SPOA w/YJ springs. 35" Boggers. |
#20 (permalink) |
Hillbilly Houndsman
Member # 13420
Obviously your adapter or shaft is the largest part of your problem. You took them off and it got better. The CV may be worn out if it vibrates very hard under load and not much at all when at cruising speed. Either that, or axle wrap is causing your shaft to bind.
You might want to take your CV shaft to a local shop and have them check it for you, and possibly rebuild it. If your adapter is not within a few thousands of being centered, it will cause bad vibes. I think factory specs on a d-shaft is 0.005”, and I have had guys tell me that you should be able to feel that depending on the vehicle. When I drilled my t-case flange, I measured and marked with a scribe from three separate point of reference, punched it, and drilled with a hand drill laying on my back in the driveway. Two holes ended up being about 1/16” or less off from my reference marks. I had to clearance all the holes to make the d-shaft fit. Bottom line is that it vibrated so bad that I shifted to 2nd once, quickly shifted back to first, turned around and idle back to the house. I ordered a Rockrat adapter to solve the problem, instead of finding another flange and risk screwing it up too. Bottom line is, if your adapter, d-shaft, or anything else in your driveline is out of tolerance the vibrations will literally disintegrate your rig. (Ever had a U-joint destruct and limp home on it, same thing). Good luck and keep us posted on your solution, no matter how simple or complex it is. I’m getting ready for a toy axle swap and am gathering info.
The penalty for punching someone in the mouth is way too high in our society. www.MountaineerOffroad.com |
#21 (permalink) | |
Hillbilly Houndsman
Member # 13420
OR The tolerance of the bolt vs. hole used allowed the D-shaft and flange to move a few thousands of an inch. To avoid this use a shoulder bolt and interference fit.
#22 (permalink) |
Member # 2752
Bill, it sounds like your CV is toast. When I first put my Yota shaft in, it was sooooo bad that idling it in first gear I got BAD vibes and clunks. I took it to the driveline shop and they put a spicer CV in. Now, I have absolutely no vibes.
The other issue is pinion angle. You should be running the pinion about 3* or 4* below dead flat with the driveshaft. I am sure you know that, but I didn't see anyone mention it.
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, ............. <>< <>< <>< Hey, if this rig is for wheelin', what are all these animal parts doin' in here? |
#23 (permalink) | |
Member # 10979
#24 (permalink) | |
Member # 4500
We did have some problems mating a 1310 toy flange to it, so we went back to our other flange..
#25 (permalink) | |
Evil Twin
The centering ring does just that, the adaptors will do this for you or machine out the opening on a stock large flange t-case flange. The bolt only are there to supply clamping pressure. -yag
