leaky brakes (also the fun game of "name that part")
I just started going through brake fluid *very* quickly. Fortunately there is a big puddle where I park on the passanger side right above this part:
![]() I crawled under and took a picture rather than trying to discribe it It's near the back as you can tell by the drive shaft in the top of the picture.I tried to lossen and retighten the brake lines hoping one was loose, but the fluid seems to be coming out of the part itself. What is the name of this part so I can ask a parts store for a new one? |
Member # 14812
Proportioning valve assy, but after pricing new you may want to look for used one.
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc. |
Member # 5776
Have any of you Sammy guys tried simply taking the prop. valve out of the brake circuit? Buddy of mine runs his toy that way and it actually seems to stop better. And he's not the first Toy owner to do that.
Just curious.
[size=1]ASE Certified Master Automotive Technician Toyota Certified Expert Technician Volvo Certified Expert Technician Suzuki Certified Master Technician IDPA Certified Master Cardboard Killer[/size] |
Member # 22456
I almost did until I realized what it did. Figmo runs with out that thing with not much trouble. He also has front disks in the rear though. I think I will take it out when I do the Toy swap an my friends Samurai.
http://community.webshots.com/user/uglyzukling |
I have run without it with rear discs and rear drums. It will work fine without it. I also did away with one of my rear brake lines. Makes it simpler.
This was discussed less than a week ago. Learn to love the search function. It really is your friend. Paul
"If it doesn't fit, get a bigger hammer" |
#6 (permalink) | |
Member # 8111
Your right I own the Fucking Place All Rock 4X Fab Products Made IN THE USA!!! Rock 4X Fabrication,Inc 1-847-672-9653 |
#7 (permalink) | |
Paul
#9 (permalink) | |
Member # 8111
#10 (permalink) | |
Member # 12382
take it out
i was haveing problems with my brakes last winter, and i just removed it and put some short steel lines in too replace it...
i dont think its a big deal if your running 31,s or bigger tyres... the rear brakes are pretty weak with stock tyre size let alone going to larger tyres......
steamy pile on 33,s |
#12 (permalink) | ||
Hophead
Sure, there are 49 other states in the Union, but they are smaller, wussier, and the people talk funny. Quote:
#13 (permalink) |
Member # 22456
Just put a splitter block at the frame next to where that Proportioning valve goes to get it to 1 line and then split off at the axle. I like this way better than two lines coming down, less crap to get hung up on the rocks.
