tooling for making a drag link(remer) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-24-2003, 08:00 PM   #1 (permalink)
Member # 18997
does anyone know what company or where i can get one from? i made one from scratch but its not the smothest edge and want a little more wear life outa it...its to match the stock zuki tre...thanks..
the-t-man is offline   Reply With Quote
Old 09-25-2003, 08:19 AM   #2 (permalink)
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
They cost $60 to $150 depending on what you get. I've been threatening to buy one since spring.
Yj4rox knows several palces to buy, a buddy at NAPA can order them through NAPA cheaper than most I've seen.
Did you search or ask over in Gen4x4? I have seen that info posted there several times.
The penalty for punching someone in the mouth is way too high in our society.
www.MountaineerOffroad.com
SilverZuk is offline   Reply With Quote
Old 09-25-2003, 08:32 AM   #3 (permalink)
YJ4RoX's Avatar
Member # 1930
www.mscdirect.com
they have the tapered reamers you are looking for.
good luck.
YJ4RoX is offline   Reply With Quote
Old 09-25-2003, 09:42 PM   #4 (permalink)
Member # 18997
yea i checked out that place msc direct couldnt find one very little tappered reamers... and i phoned and the guy didnt know a hole lot of what he was talking about ...anyways someone has to know a specific brand name and model # please.........
Old 09-26-2003, 04:01 PM   #5 (permalink)
Member # 15708
Send a message via Yahoo to GA_ZUKI
i myself have been LQQKing into this for my own reasons
this is what i have come up with. i would have to use this on
a drill prill to control the tapper but you get the idea
they have others but they are for softer meatal or for hand reamers and i want to use the drill press. it is from www.mcmaster.com page 2301
Widely used for heavy metal construction work, these reamers enlarge and align holes for rivets and bolts in structural steel members such as I-beams, angles, channels, and plates. Ends are pointed for easy entry into out-of-line holes. Spiral flute reamers have a left-hand spiral and right-hand cut. Not intended for reaming tapered holes.
Straight-Shank Reamers— Have a straight shank with three flats, except where noted. May be used in portable electric and pneumatic
GA_ZUKI is offline   Reply With Quote
Old 09-26-2003, 05:05 PM   #6 (permalink)
Member # 10934
Try Enco Tools. www.use-enco.com. They specialize in tooling for mills& lathes
I might be a newbie but I`ve read this board for a looonnnggg time!(I just have`nt had a smart ass comment yet)
okezuki is offline   Reply With Quote
