leaf spring angle?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-27-2003, 09:25 PM   #1 (permalink)
Member # 21905
leaf spring angle??
to get the right camber angle, does the leaf spring have to be level with the ground, or does it have to be on some sort of an angle?
does this make sence?
im puting rear sammy springs up front of my sas kick, i have made and welded the rear hangers already, and im wondering how far down i need to make the front one to mount my shackle...
on that note, the best angle for the shackle is a 90 degree with the leaf spring?
i think i read that somewhere.....
if the water in the river goes calm, dont drive in it.
sir.lance is offline   Reply With Quote
Old 10-27-2003, 09:56 PM   #2 (permalink)
Member # 11626
You want your axle to have a 3-6 degree positive caster. It will help you keep driver straight.
Shackle angle, I usually aim for 20-30 degrees at rest.
Goof is offline   Reply With Quote
Old 10-29-2003, 05:54 AM   #3 (permalink)
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
This link expalins it far better than I can.
http://www.off-road.com/suzuki/tech/slterm.htm
The penalty for punching someone in the mouth is way too high in our society.
www.MountaineerOffroad.com
SilverZuk is offline   Reply With Quote
Old 10-30-2003, 10:46 AM   #4 (permalink)
rotozuk's Avatar
Member # 8965
I cheat, and take measurements off a vehicle I know is good. Then duplicate those spring mounts locations to my vehicle.
So in your case, duplicate the Samurai front when used with a M/L and rear spring. Just ignore the M/L and treat the bend in the link as the shackle mount.
Yes, 90 degrees to the frame is considered ideal for on road manners. I usually add a little more angle away from the axle so I get a bit more down travel. But do not over do it! It can be tough to figure this one out as the shackle angle is not loaded while building.
-Wayne
rotozuk is offline   Reply With Quote
Old 10-30-2003, 12:32 PM   #5 (permalink)
Member # 22191
Send a message via MSN to Crab Bait
I've seen shackels on a Chevy with super soft 'ALCAN' spring set-up actualy tilting toward the axle when un-loaded.
Zuki Owners; Engineering Innovation not Repetitious "Tuesday" Imitators
Crab Bait is offline   Reply With Quote
Old 10-30-2003, 12:44 PM   #6 (permalink)
rotozuk's Avatar
Member # 8965
I'm not a fan of Alcan springs for this reason. We have several of these springs in the club, and the only ones that have a correct shackle angle are the Toyotas (becuase All Pro set the specs for spring length, etc.) and the guys that had enough balls to yell at Alcan and get them to replace the short spring pack. Most of the Alcans that have not been replaced have a shackle angle that is 90 degrees to the ground when just sitting on level ground. The funny thing is that Alcan has done this for YEARS! And they still have not learned to fix the damn problem with their math.
-Wayne
