2 questions in one post - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-13-2001, 10:45 PM   #1 (permalink)
Member # 3653
Q #1-- hey, i got the locker in, but lost my markings for the holes on the bearing retainer/adjuster, how do i re-adjust the ring/pinion clearence? i asked a local diff. shop and they want $97 to do it. do i gotta face it and pay or is there a way i can do it myself?
Q #2-- what do you guys have for front upper shock mounts? i want to run as long as possible and with an eyehole rather than the stock stud.
thanks a lot in advance guys
-justin
it'll be done in two weeks...HAHA
(oh shit, i said the loud part quiet and the quiet part loud)
The Two Week Rule... close enough to keep everyone hoping it'll be done, yet far enough away that they'll forget it's been two weeks
Rock Forever
(Work Whenever)
izooki13 is offline   Reply With Quote
Old 12-13-2001, 11:36 PM   #2 (permalink)
Member # 1408
Send a message via AIM to RockRanger
Not sure on sammi's but alot of toyota and a few ranger people use mid 80's f250 shock mounts. They are like 15 each from the ford dealer. The part # has been posted a bunch bet you could find it on the toy board
Matt
93 Ranger on 37"s
RockRanger is online now   Reply With Quote
Old 12-14-2001, 02:58 PM   #3 (permalink)
Roksamy's Avatar
Member # 752
Gear set up
You can adjust your backlash using a magnetic base dial
indicater and set for .007- .009 thousandths for oem gears.
Try get back into the existing pattern or improper/premature wear will occur. Don't take it from me , though. Call Sean
aka gearman at River City Diffs (916)852 7109 -Josh
got a jeep and a yota. I hate myself.......Wrong Way Wheelers. Camino, CA
Roksamy is offline   Reply With Quote
Old 12-14-2001, 04:39 PM   #4 (permalink)
Member # 3653
hey thanks, but for the ford upper shock mounts--i thought those were the stud-type shock....although i could be wrong. and thanks for the diff advice!
has anyone heard the putty trick for pinion/ring lash? something like you put the putty in the ring gear and spin her (after it's all tightened up) and maesure how much the pinion squished the putty. im not sure of this procedure tho. just wondering if it is accurate and it works.
thanks dudes
-justin
Rock Forever
(Work Whenever)
Old 12-14-2001, 06:31 PM   #5 (permalink)
zuk88's Avatar
Member # 3785
Here's mine..... RRO extended (mounted backwards) with some LONG Doetsch Tech Pre-runner shocks.
http://zukin.homestead.com/files/frontmount.jpg
[B]'88 ZUK[/B]
Toy axles,4.30 r&p, spool rear, EZ front,4.16 t-case, 2" YJs, Sky Mfg hy-steer, 33" thorns, and fuzzy seat covers.
zuk88 is offline   Reply With Quote
Old 12-14-2001, 07:17 PM   #6 (permalink)
TNToy's Avatar
Member # 5776
Well, the ford shock towers are eye type. I know some guys have used them on Sammy's (and about everything else) but here's a pic of some on a Toyota:
<img src="http://www.tennessee4x4.com/toyota/images/r-c-fordshock2.jpg">
Part number at Ford dealer is E5TZ-18183-A and they range from $12-15 each.
[size=1]ASE Certified Master Automotive Technician
Toyota Certified Expert Technician
Volvo Certified Expert Technician
Suzuki Certified Master Technician
IDPA Certified Master Cardboard Killer[/size]
TNToy is offline   Reply With Quote
Old 12-14-2001, 08:25 PM   #7 (permalink)
Member # 8111
gears
Hey guy just got done seting up new gears factory backlash
.004-.006 but if your between .005-.010 you should be ok
2nd get some gear marking compound and mark the ring gear on a few teath front and back rotate pinion around 4-5 times and watch for an even wear mark centered between heal and toe of ring gear not to worried about the flank marking as long as you did not remove pinion I can email you a setup sheet if you want it
good luck
Your right I own the Fucking Place
All Rock 4X Fab Products Made IN THE USA!!!
Rock 4X Fabrication,Inc 1-847-672-9653
Rockrat is offline   Reply With Quote
Old 12-15-2001, 08:30 AM   #8 (permalink)
***Glitterbomber***
CragRat's Avatar
Member # 6483
See here -----> Link
" Put on your seatbelt .... I want to try something "
AxleSnapper Bulletin Board
AxleSnapper Website
CragRat is offline   Reply With Quote
Old 12-15-2001, 12:01 PM   #9 (permalink)
Member # 3653
awww sweet, thanks guys. ive got rears up front with M/L's and i can get the 9012's on there? kewl!
thanks a $hitload guys
-justin
p.s. NOT A NEWBIE NO MORE!!!!!! YIPPPEEEEEE!!!!!!!!!!
Rock Forever
(Work Whenever)
