SM465 in Zuk? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-27-2003, 03:16 PM   #1 (permalink)
Member # 9098
SM465 in Zuk?
Anybody seen a samurai with a SM465 trans swapped in? If so, did it still use the NP205 T/C?
Anybody got pictures?
Flipper is offline   Reply With Quote
Old 12-27-2003, 10:23 PM   #2 (permalink)
Member # 16720
I think that tranny and case would weigh more than stock sammy.
GreenPig is offline   Reply With Quote
Old 12-28-2003, 06:33 AM   #3 (permalink)
Member # 5744
Send a message via AIM to ManglerYJ
I am sure an NP205 will not fit between the frame rails. Not sure on a Dana300, but I do have a SM465 to Dana300 Novak adapter for sale for $300 plus shipping....
90 YJ with 305 TPI Chevy/ SM465/ Dana20, SOA on Scout Dana44's on 36x12.50 SX's with a Lock Right in the rear
visit [url]www.carolinarockshop.com [/url] today, tell em Mangler sent ya!
ManglerYJ is offline   Reply With Quote
Old 12-28-2003, 07:59 AM   #4 (permalink)
Member # 7882
are you looking for a tougher tranny, or are you looking for the lower first gear...you lost out running the lower first gear when you have to use a t-case that is 2:1 at best.
[url]http://phonese.cx/user/spence/[/url]
My life from my phone's perspective.
spencurai is offline   Reply With Quote
Old 12-28-2003, 09:02 AM   #5 (permalink)
Member # 9098
Cheap, tough and available transmission that will bolt up to a 90* chevrolet motor were my reasons.
First gear & low will be right at where my GRS1 is now....but with more motor.
Old 12-28-2003, 09:24 AM   #6 (permalink)
Member # 7882
your original post did not state that you were swapping a motor, just a trans.
Old 12-28-2003, 10:37 AM   #7 (permalink)
Member # 9098
Yep, my samuari motor is in sad shape. It was real tired BEFORE I hydro-locked it. Now it has a coolant leak on the intake side close to where the head and block meet. I can't really tell what is leaking, but I don't think it is worth fixing anymore.
I wish I could stumble upon a light weight engine and transmission that made serious horsepower. Some sort of aluminum V6 would be cool.
Old 12-28-2003, 01:38 PM   #8 (permalink)
OKIE ZUK's Avatar
Member # 14812
Russ Hogan run these trannies in all his Samis with RX-7 motors. Uses the stock t-cases also. One of them runs two front Mog axles with 44" TSLs.
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc.
OKIE ZUK is offline   Reply With Quote
Old 12-28-2003, 01:47 PM   #9 (permalink)
Member # 9098
Any pictures? ...or links or whatever?
Old 12-28-2003, 08:01 PM   #10 (permalink)
MRfuelish's Avatar
Member # 12376
look into a sm-420 smaller and a lower 1st gear and reverse!
MRfuelish is offline   Reply With Quote
Old 12-28-2003, 09:11 PM   #11 (permalink)
OKIE ZUK's Avatar
Member # 14812
Flipper, Check with Okcrawler on this board for pix. He runs Disney a lot and is good at taking pictures (digital).
