crawl ratios - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-28-2003, 06:13 PM   #1 (permalink)
Member # 21557
crawl ratios
What is considered to be a good crawl ratio for rocks?
Brad Juan is offline   Reply With Quote
Old 12-28-2003, 06:29 PM   #2 (permalink)
fatkid's Avatar
Member # 4862
with a 1.3L and some 36's I think @150:1 range works for me.
[url]http://www.myspace.com/jerrywsparks[/url]
fatkid is offline   Reply With Quote
Old 12-28-2003, 06:57 PM   #3 (permalink)
tipover's Avatar
Member # 7265
Send a message via AIM to tipover
Minimum of 120:1 with 33. Bigger than 33s, I agree with fatboy.
tipover is offline   Reply With Quote
Old 12-28-2003, 08:10 PM   #4 (permalink)
tanzuki's Avatar
Member # 15771
Send a message via ICQ to tanzuki Send a message via AIM to tanzuki Send a message via Yahoo to tanzuki
If you are doing some serious rock you'll need a tire that's 35" or bigger. And with that size of tire you'll need atleat 100:1. Alot of yotas are getting away with a dual cases and 5.29 r&p which is only about 100:1 with a 37" tire but there motors are a little more torquey. I run 36" with 125:1 and find I could still use a little lower gear in some places, but for the most part it's pretty damn good.
YO YO HA!!!
tanzuki is offline   Reply With Quote
Old 12-28-2003, 09:41 PM   #5 (permalink)
fatkid's Avatar
Member # 4862
My crawl is 223:1, but it too slow for alot of things, I typically use 2nd and 3rd when Im in low low. Or for most things I don't really need low low, low high works wich is about 108:1.
Old 12-28-2003, 09:44 PM   #6 (permalink)
DSI
DSI's Avatar
Member # 920
Send a message via Yahoo to DSI
zuk is 82:1
buggy's 64:1 (auto)
Thanks to the companies that make it happen: Bilstein Shock Absorbers, Trail-Gear, Trent Fab, PRP Seats, Raceline Wheels, PSC, MJ Motorsports
DSI is offline   Reply With Quote
Old 12-28-2003, 10:23 PM   #7 (permalink)
Member # 21557
I will be running the 1.3 motor stock with 4.1 in the T case and 5.89 in the R&P's and I'm hoping to have the right gearing for a 35" tire. What do you guys think? not low enough? Thanks
Brad
Old 12-29-2003, 09:06 AM   #8 (permalink)
tanzuki's Avatar
Member # 15771
Brad
You'll be fine most of the time. You might find if you get into some technical areas it may require some clutch slippage.
YO YO HA!!!
Old 12-29-2003, 09:10 AM   #9 (permalink)
Member # 9474
Brad
Not sure if you said or not but what kind of axles are you using?
Former samurai owner........
I AM IN NOW WAY RESPONSIBLE FOR MY SPELLING!!!!!
FLEXYSAMMY is offline   Reply With Quote
Old 12-29-2003, 09:19 AM   #10 (permalink)
Member # 18487
Send a message via AIM to Tintop
he'll be runnin waggies i think.
Tintop is offline   Reply With Quote
Old 12-29-2003, 09:53 AM   #11 (permalink)
Bobzooki's Avatar
Member # 9419
On my Sidekick, I do pretty well with 31's and only about 38:1 (stock drivetrain, except for 5.83:1 R&P's). I power out occasionally, but do OK for the most part.
Once I change my Xfer case gearing to over 4:1 (1.8:1 is stock), I'll be at about 93:1. That should be plenty for most anything I'm interested in at Moab, and around Colorado.
2012 Tahoe 24' Fish-N-Fun Tritoon, w/115hp Merc
Tow Rig: The Battlestar Galactica
Bobzooki is offline   Reply With Quote
Old 12-29-2003, 01:35 PM   #12 (permalink)
Member # 2752
Brad
That should be fine. It is around 90:1 (if I did the quick math in my head right ) I am 125:1 and have no troubles. When I was at 90:1 with 33's, I rarely had troubles either. Sami's are so light and the carbed motors lug down and stay strong, which helps a lot.
You may be hurting on the street a little though as far as top speed goes. Top speed should be around 60 mph if that 1.3 will get you there. My 8-valve 1.6 had trouble climbing hills at 60 mph (also my top speed) because of a lousy carb. Adding the EFI solved that though.
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, .............
Hey, if this rig is for wheelin', what are all these animal parts doin' in here?
Tusker is offline   Reply With Quote
Old 12-29-2003, 07:44 PM   #13 (permalink)
Member # 17420
1.6L, 5:12 R&P, Toy "Turbo" Tranny, using an SOS RingR, Dual Toy t-cases w/1 stock, 1 with 4.7 in a Tracker with 33" tires..........237-1 crawl ratio.
2007 Campbell Buggy w/LS-1,Hughes PG, Atlas 5.0, Hi9- FOR SALE
polkabully is offline   Reply With Quote
