hi speed cut out help me! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-28-2004, 01:38 PM   #1 (permalink)
lobtorock's Avatar
Member # 16139
i changed over to the 1.6 16 valve GEO (96) and at high rpm's
my junk want 's to cut out it happens at 5000 to 6000 rmp's
plug's wire's all new the motor has olny 56000 miles on it
much help is need thank's
www.adultswim.com
lobtorock is offline   Reply With Quote
Old 01-28-2004, 02:44 PM   #2 (permalink)
Member # 8687
What type of fuel pump are you using? Maybe it's running out of gas at high rpms.
The word "jones" is a slang term meaning to crave, want, or desire; or, to feel withdrawal from an activity of passion. The general slang meaning is often associated with addictive substance habits but can be applied on a more universal scale.
jones is offline   Reply With Quote
Old 01-28-2004, 10:09 PM   #3 (permalink)
Member # 26247
It's called a rev limiter. It hits at 5500rpm. Gives the symptoms that it's bogging out and running like shit.
Now i know why they were invented
Suzuki's are alot like women.
If you don't service them once in a while they won't let you go wheeling!!!
[url]www.zookpower.ca[/url]
Fullload is offline   Reply With Quote
Old 01-28-2004, 10:34 PM   #4 (permalink)
Member # 21905
why in the world would you need to go to that high of an RPM? the tourqe band is what? between 3000 and 4000 rpm?
going over that amount is pointless
imo
if the water in the river goes calm, dont drive in it.
sir.lance is offline   Reply With Quote
Old 01-29-2004, 04:07 AM   #5 (permalink)
Member # 22754
Glad to see you here Full. Has the fuel pressure regulator been changed? Have a look at that.
88 Sami on 35"X-terrains, 411's, crusher axles, longfields, locked, 1.6 16v,8274 warn, 410 t case, custom cage, custom bumpers, 72 LJ20 Suzuki, 86 HJ60, 91 FJ80 locked......[url]WWW.ZOOKPOWER.CA[/url]
lil beast is offline   Reply With Quote
Old 01-29-2004, 02:35 PM   #6 (permalink)
lobtorock's Avatar
Member # 16139
imo
"hum quick run for the weeknd's in moab 3 or 4 time a month " rev limter how do i rip that out !
fuel presure regulator i will look as for fuel pump
trail toughf high presure fuel pump.
i will try all ofr them keep them comeing thank's
www.adultswim.com
Old 01-29-2004, 08:14 PM   #7 (permalink)
Member # 22754
Foe the fuel pump use an 87 ford bronco II or f150
Old 01-30-2004, 02:13 AM   #8 (permalink)
Member # 26247
How do you get the rev limiter out? You don't. Unless you have some tecno wizard to reprogram the e-prom inside the ecm.
But i think you learn how to re-gear the truck somehow, or add a locker. You should leave it in there before you blow up that motor, or even worse fly off the edge of no mans land when you lanch it and get hurt.
Oh yeah. lil beast i'm here. Lurked long enough to know. Knowing what ? who cares.
Old 01-30-2004, 03:13 PM   #9 (permalink)
Member # 22754
LOL i sure as hell dont
Old 02-02-2004, 11:47 PM   #10 (permalink)
lobtorock's Avatar
Member # 16139
ah i do have gears and lockers is this a joke ?
could it be any thing with the two sencers for the o 2's
and the ecm .?
www.adultswim.com
Old 02-03-2004, 11:08 AM   #11 (permalink)
Member # 7882
I find it kind of hard to believe that the rev limter is that frickin low. Someone needs to verify that it is indeed the rev limiter because that is just way to low of an RPM range....my jeep 4.0 limits at that range and it isn't DOHC!!!
[url]http://phonese.cx/user/spence/[/url]
My life from my phone's perspective.
spencurai is offline   Reply With Quote
Old 02-03-2004, 12:11 PM   #12 (permalink)
Azrckcrawler's Avatar
Member # 3550
5500-5700 seems about right, I'll check and see if I have the original tach when I get home. I guess i depends on what you are used to, my DD has a redline right around 3 grand, so 5500 seems pretty high.
[URL="http://www.azrockcrawler.com/_images/btgdvd/btgvol4dvd/btgvol4dvd.html"]Built to Grind 4 DVD - 2 Hours of Arizona and NM Rockcrawling
[/URL]
Chassis Plans for the Do-It-Yourselfer
[URL="http://www.azrockcrawler.com"]www.azrockcrawler.com[/URL]
BTG Rockcrawlers
Azrckcrawler is offline   Reply With Quote
